Metrum Octave Dac - What are the Chips used - Page 34 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 15th April 2012, 04:11 PM   #331
Originally Posted by ThorstenL View Post
Actually, the true solution is to decouple the DAC's master clock from short term variations of the source clock, no matter if the source is common mode noise or any other one. In principle BTW this is quite trivial, even though in practice it is quite challenging.
Ciao T
Yes, managing an NCO, for example, to match the exact long term average frequency of the source oscillator, but at the DAC, is probably the best, but also sophisticated, solution. Such an implementation is, unfortunately, probably not an option for the more advanced diy audiophile.
Ken
Old 15th April 2012, 04:18 PM   #332
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Originally Posted by Ken Newton View Post
Yes, but even with that objective, having 150 ohms of resistance between component grounds would greatly limit ground loop current flow between those components, compared with having only the resistance of the unbalanced cable's 0-Volt conductor.
The biggest ground current flow I've measured is in the region of a few 100 uA (this at 50Hz), so I can't see how 150R would make much of a dent in that. Unless it was originating from a lowish source impedance. Mains wiring is the means of coupling CM noise between components, via interwinding capacitance of trafos.
I realise the digital sources I use are down at the lowest end of the market, and their el-cheapo SMPSUs impose some not insignificant CM currents, but these arrive having passed few a few hundred pF of (transformer) coupling capacitance at most. So source impedance tends to be quite a bit higher than 150R at the frequencies they operate at (a few 10's of kHz).
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Old 15th April 2012, 04:29 PM   #333
Originally Posted by abraxalito View Post
Very definitely. Use of a single all-encompassing ground fill is not a really high-end solution. Check out the Berkeley Alpha DAC for superior grounding practice.
Well... that's weird because on the other hand you defend the technical know-how of the said designer/engineer. How that can be - is he good enginner or a bad one?
Is the same story again. Like when the Philips designers show you the appropiate use of their DAC's - with OS. You hail them for designing a good DAC, but you assume that they are completelly idiots about OS.
Actually they have a parallel capacitance and resitor (for electrostatic safety) that have some 4.7...10 nF and 2...4.7 Gohm. Your argument is still valid thou.
Old 15th April 2012, 04:36 PM   #334
abraxalito's Avatar
I've praised his audacity in designing with a chip which isn't a mainstream audio part - that's not really defending his technical know-how is it? More recognising his creative flair and marketing aptitude. The world of engineers isn't a black and white one though, so engineers have degrees of competence.
No I just claim they either didn't listen to Bitstream carefully enough or they did and have cloth ears There's nothing intrinsically wrong with OS in my estimation - its a matter of implementation. Noise-shaping is another matter entirely though. Perhaps you're dwelling too much in the world of your own polar (black vs white) thinking - get out a bit more and see how the world is a spectrum of colours?
Old 15th April 2012, 04:44 PM   #335
In my polar world I saw engineers bad of good. Doctors bad and good.
Because if a person cares about what is doing, it will teach itself in all the aspects of that job.
Missing some basic knowledge tells me that his skills are low-grade. Mainly due to not caring to be informed and I... won't trust it with nothing else that is higher level on knowledge scale.
But that's me and my experience in this world.
PS: Philips engineers decided that bitstram is good enough to spend hundreds of millions $ in developing and manufacturing. You think they are so dumb (compared with your ability) that didn't listen to their products or the are deaf (compared again to your ability). Hmm... isn't that a little too much ego showing?
I think that there are bad things about S-D but there are also bad things about MB. They know that too, that's why the present day DAC's are a combination of both. They tried 10 bit, 7 bit, now looks like they settled to some 4 bit.
Old 15th April 2012, 04:48 PM   #336
abraxalito's Avatar
Well in my estimation he got a working DAC out the door and its receiving rave reviews across the board. That's not 'low-grade' - his PCB layout skills could definitely be improved but then again he's not selling this DAC in the high-end marketplace. So perhaps he wanted to keep something in reserve for his upcoming v2.0 at a high-end price-point?
Old 15th April 2012, 04:52 PM   #337
I'm not sure that I exactly follow which CM currents you believe need to be suppressed on the 0V line? Are you only refering to SMPS induced high-frequency reactance? Most practical size CM filters do nothing at lower frequencies, such as 50Hz. Balancing an unbalanced input seems the most practical and least inexpensive means of improving CMRR via a transformer coupled input, especially at low freqiencies. Perhaps, I'm failing to understand your concern?
Ken
Old 15th April 2012, 04:52 PM   #338
Or... you are wrong about the grounding
Old 15th April 2012, 05:00 PM   #339
abraxalito's Avatar
I'm not sure that I exactly follow which CM currents you believe need to be suppressed on the 0V line? Are you only refering to SMPS induced reactance?
Any currents which impose voltage drops between notionally identical 0V reference points in the circuit. SMPSUs are the main source, but the digital logic inside a transport can add much higher frequencies to the SMPSU payload, albeit at a lower amplitude. Then there's the possibility that external devices on the mains (like LCD TVs with their large CCFL SMPSUs) might impose more crud. We'd ideally not want any of this stuff to make its way between the 0V points of the design via coupling through the SPDIF input.
Old 15th April 2012, 05:10 PM   #340
Not to mention that if he is the one-man shop I've seen reported, he's unlikely be an expert at all facets of product design, development, and production. Too much to expect of one person, I should think.
Ken
dac chips kiwi88 Digital Line Level 2 5th August 2009 02:25 PM
dac chips for trade tubedude63 Swap Meet 1 25th May 2007 10:04 PM
Looking for 6 x TDA1545A DAC chips WALTER BURKHARD Swap Meet 2 5th April 2007 10:24 PM
F.S.: various Dac-chips Cobra2 Swap Meet 4 23rd November 2004 10:00 PM
Best DAC chips 5th element Digital Source 7 7th June 2004 04:08 PM
Copyright 1999-2017 diyAudio
