| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#221 |
Fck iPhone I lost my message. Will try to rewrite later on computer
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938 |
#222 | ||
Sonically, yes, the Octave sounds better than the DAC1.
It's this dynamic behaviour of the hearing threshold that really gets in the way of the interpretation of these measurements. "What you see is what you get" really doesn't work in this case. Quote:
Octave; 44.1 kHz; 19 kHz + 20 kHz sinewaves, 1:1; Octave; 96 kHz; 19 kHz + 20 kHz sinewaves, 1:1; DAC1; 44.1 kHz; 19 kHz + 20 kHz sinewaves, 1:1. Last edited by jitter; 7th April 2012 at 09:14 PM. |
#223 |
Previously: Kuei Yang Wang
Location: Somewhere nice on planet earth where censorship of Ideas is frowned upon
This is where trouble starts. Without having heard the Octave I'd still agree. The real question is, how do we reconcile this? The Non-OS Stuff I design does usually measure a little less extreme (in detail, not on THD+N) but it is still far from DAC1 levels or even the new Weiss. Do we really "like distortion that much", or do the common measurements simply fail to correlate with "good sound"? Ciao T |
#224 | |
To basically eliminate the need for an aliasing filter, we need DXD resolution, native or oversampled... and a R2R DAC ![]() A good paper: http://www.digitalaudio.dk/media/dxd...ution_v3.5.pdf
#225 | |
I think the answer is this: ...But something that gets intermodulated from a NOS filterless DAC must still affect the signal in the audible band and creates the "lively" sound mostly associated with NOS dac probably. To move much higher in the frequency spectrum this spuriae is the better solution. Also, the time distortion of sigma-delta dacs is NOT measured by conventional means.
#226 |
Thanks! The first two are what I was expecting from my tests, the DAC1 looks like you have only one frequency there...
#227 |
Please view the pictures in my previous post again. I discovered that, like Sonic remarked, not all of them were two sine waves. This has been corrected.
#228 |
The DAC1 is freakishly good. Seems that they are right about the 110kHz samplerate chosen for up-conversion. And their reason behind the chosen ASRC (AD1896) seems to be right. I won't touch an ASRC that is not DSP generated, but their implementation seems to work.
Hey, now that you like that much the Metrum, don't you wanna sell that garbage of DAC1? I can help you to take care of that poor old DAC
#229 |
Hahaha, who knows? Actually, I already have another purpose for it...
#230 | |
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
If you look closely at the AP plot - the red line gets thicker above 18kHz and doesn't follow the slope downwards. This almost looks as though it was touched up by hand. But it shows a mere 0.7dB droop at 20kHz which does not accord with either the theory or the tabulated measurements. Secondly the THD in the table looks uncharacteristically poor, even for a NOS DAC. I wonder if the imaging products got into the measurement? Just estimating by eye from the FFT I'd guess some 10dB lower than what's presented (-60.5dB). The wideband FFT for -10dB stimulus actually shows a test tone around -4dB and harmonics all below -83dB so its surprising that tabulated figure is so poor (-62.3dB).
When a measure becomes a target, it ceases to be a good measure. C.A.E. Goodhart |
| dac chips | kiwi88 | Digital Line Level | 2 | 5th August 2009 02:25 PM |
| dac chips for trade | tubedude63 | Swap Meet | 1 | 25th May 2007 10:04 PM |
| Looking for 6 x TDA1545A DAC chips | WALTER BURKHARD | Swap Meet | 2 | 5th April 2007 10:24 PM |
| F.S.: various Dac-chips | Cobra2 | Swap Meet | 4 | 23rd November 2004 10:00 PM |
| Best DAC chips | 5th element | Digital Source | 7 | 7th June 2004 04:08 PM |
