XO using MOTU 828mk3 hybrid
Old 12th April 2012, 12:21 PM   #21
pschelbert is offline pschelbert  Switzerland
Default Motu828hybrid
yes
two ways how to use it.
1) no VST just in and out.
so use MotuCuemix, the softwareconsole which comes with Motu828.
There you have:
inputs
mixes
outputs
connect any input, look by switching on "meters" if there is something coming in.
I yes, okay
mixes: now go to mixes. here you have to unmute the inputs you want. Control with "meters"
then last go to output. Also meters, then you should see there also where you have singals on output. It must where you connct TRS jacks.
2) use with VST-host.
There you can monitor in the VST host your audiointerface. Then <you have to crosswire in VST (by software dragging lines) input of audiointerface to output of audiointerface. and then you got the signal to output you want. Monitor again in VST host. I have just to right-click on hte Motu-symbol to get monitor of all inputs and outputs.
Old 12th April 2012, 12:52 PM   #22
_henry_ is offline _henry_  Australia
hi peter,
thanks for the quick reply.
i like to use puremusic as it has built in active crossover. do u have any experience with this?
im planning to use fabfilter plugin in puremusic for EQ purposes.
the strange thing is i didnt see any level indicator, means there's no signal coming in.
as for the settings, MOTU have mix1-4 (BUS??), which i turn on all
what kind of VST that u used?
cheers
henry
Old 12th April 2012, 01:44 PM   #23
i can configure output in osx MIDI setup, but cant get any sound thru puremusic.
is it possible puremusic problem? i did set the output in puremusic on MOTU 828.
henry
Old 12th April 2012, 01:57 PM   #24
Default Motu828
Hi Henry
no I dont know puremusic, as I do not use Mac.
However this puremusic must have a configuration of sound devices. There you can select Motu828mk3 and the desired output channel (TRS, SPDIF etc.)
In MotuCuemix you will see the signals looka at "meters"
Old 12th April 2012, 02:14 PM   #25
hi peter,
i actually using motu 828mk2, not the mk3.
which vst ur using now?
Old 12th April 2012, 02:25 PM   #26
Default Motu828
I use Mout also with Cooledit püro, Sony Soundforge, Foobar2000, Winamp , Plogue Bidule (VST) and all that works perfect.
Old 12th April 2012, 02:36 PM   #27
Default Motu828mk3
Hi
I use the VST host "Plogue Bidule"
VST plug ins a lot different ones as they suit:
easyQ: equalizer: RS-MET
SIR: SIR Audio Tools / SIR2 / Product Details convolver
Wavesurround: from wavearts
crossover: from RS-MET
accourate, www.accourate.de filter-design for SIR convolver
Bluecat gain from: www.bluecataudio.com/.../Product_GainSuite/
Old 13th April 2012, 02:43 AM   #28
hi peter,
thanks for the info. the problem with me now, is although i have windows PC, but i dont have firewire card.
i will try to solve the mac issues first, if its really dead end, then i guess i should try PC.
cheers
henry
Old 13th April 2012, 06:22 AM   #29
Default Motu828
Hi Henry
it should work the same way with Mac. VST etc is also available for mac.
For Mac often the selection of software is lower and you have to pay more
XO using MOTU 828mk3 hybridHide this!Advertise here!
MOTU Ultralite Hybrid mod jhoffm34 Digital Source 0 22nd September 2011 02:28 AM
DSP + passive XO hybrid? tommus Multi-Way 4 9th July 2011 02:23 PM
Motu mk1 issue please heeeelp!!! ChristianFP Digital Source 1 6th August 2009 01:59 PM
PC recording Motu, Onyx, RME, Saffire??? Zero Cool Digital Source 1 13th March 2007 01:03 PM
FS: MOTU Micro Express MIDI Interface theAnonymous1 Swap Meet 1 26th January 2007 05:39 PM
