Go Back   Home > Forums > Source & Line > Digital Line Level
Old 15th March 2012, 09:23 PM   #11
DjSinae is offline DjSinae  Canada
I wonder if something like
LiquidSonics - Filtrate | Linear Phase Paragraphic EQ for VST, RTAS and AU
would be a good way to go.. since it's FIR running on CUDA (nvidia video cards)
latency should be lower
the goal is less latency possible for me..
it could stay on the same computer... (no need for another to process the digital signal)
Old 16th March 2012, 07:27 AM   #12
Default Motu828 xover
not there is no way to have less latency. A certain FIR filter length has always a certain number of tabs. This defines the delay. Its just mathematics. No hardware can turn the time back. The Hardware therefore does not play a role (just medicre differences) in delay.
The easiest to deal with delay, if you delay all other singals as well. Then you do not notice the delay. There is actually no other solution.
To minimize delay use IIR filters not very steep ones.
Old 2nd April 2012, 09:57 AM   #13
_henry_ is offline _henry_  Australia
hi,
i got the motu 828mk2, i was wondering which TRS to use? stereo or mono for balanced interconnect to the amps?
im excited to try them out.
cheers
henry
Old 2nd April 2012, 05:05 PM   #14
Hi
the TRS out on the back are all balanced. Now if you connect a mono TRS you will get unbalanced, right to connect to cinch
If you use balanced TRS connectors, the they are balanced, go for example to XR inputs of amp.
The only stereo TRS are in front (Main, headphone), they are unbalanced ans stereo (one TRS Stereo for Left and right)
If you have the choice go balanced.
Peter
Old 2nd April 2012, 05:14 PM   #15
hi peter,
can u point me out to balanced TRS connectors? or is it the Stereo TRS like neutrik Np3x?
thanks
henry
Old 2nd April 2012, 06:29 PM   #16
Default TRS Stereo (balanced) XLR
here for example a cable.
pro snake 17582/3,0 SW Audio Cable - Thomann UK Cyberstore
Thomann has a whole bunch of cables (I could not find pinouts though, may be they are somewhere).
I have almost all my cables from Thomann, it just works, choose the right connectors on both ends (be careful also male, female must be correct).
in the manual of my RME Fireface UFX on page 97 (english version) you see the wiring of TRS balanced and XLR.
They are standardized, you should find it also on the net
Peter
Old 3rd April 2012, 01:48 AM   #17
hi peter,
thanks for the link. unfortunately uk is far from my place. but i get the idea of the balanced TRS.
cheers
henry
Old 3rd April 2012, 01:58 AM   #18
twest820's Avatar
Hmm, coulda sworn I implemented one a while back. I suspect it's not compatible with the OP's needs, however.
Old 3rd April 2012, 06:45 AM   #19
the uk-link is just to see an implementation. Look for such a cable nearby.
Peter
Old 12th April 2012, 11:56 AM   #20
hi peter,
today i want to test the motu 828mk2 with mac osx using puremusic itunes.
i bought mono 1/4" to rca cable, as my amp is unbalanced.
i connect to the output 1-2, but got no sound.
can u help me / show me, how u use the motu for playback?
cheers
henry
MOTU Ultralite Hybrid mod jhoffm34 Digital Source 0 22nd September 2011 02:28 AM
DSP + passive XO hybrid? tommus Multi-Way 4 9th July 2011 02:23 PM
Motu mk1 issue please heeeelp!!! ChristianFP Digital Source 1 6th August 2009 01:59 PM
PC recording Motu, Onyx, RME, Saffire??? Zero Cool Digital Source 1 13th March 2007 01:03 PM
FS: MOTU Micro Express MIDI Interface theAnonymous1 Swap Meet 1 26th January 2007 05:39 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
