DCX2496 problem - distortion with multiple outputs
Old 1st March 2012, 01:34 AM   #1
ComputerJLT is offline ComputerJLT  United States
Send a message via AIM to ComputerJLT
Default DCX2496 problem - distortion with multiple outputs
Ok i've developed a weird problem with my dcx2496.
a little back info - i have a dcx2496 running a stock power supply and stock dsp board but the output board is gone, i've gone direct spdif in to the oem trafo with a 75ohm terminating resistor in place of the 110ohm. Outputs are passive single ended using 6.8uf Dayton 250V audio grade caps from parts express (here) for ac coupling and i'm also using these 3.3nf filter caps.
so far so good but today when i went to crank it up i was getting horrible distortion and popping/crackling at moderate levels. no where near clipping my amp or distorting my speakers. Meters on the dcx are only about 1/3 way up then they start jumping/clipping as the noise starts. After playing with it i found if i have more than the 2 outputs i'm using enabled (even if they're muted it doesn't matter) then i get the popping and distortion. only way to get rid of the noise is to change the input on my 4 unused outputs to sum or C neither of which I am using.
Any inputs? is something starving the DACs for power?
The only thing i've done to this dcx since i did the passive out was try to power it with a modified power inverter. Per another users recommendation i modded a cheap power inverter to output 160v DC instead of modified sine ac (bypass the output h-bridge basically) and made sure it worked (and it did, no weird artifacts or overheating components after about an hour). I plan on using this dcx in my car with a carputer source (digital out only) is why i wanna power it with an inverter.
AFter I did that i plugged the dcx back into wall mains and all was well until today?
any ideas whats wrong or where i should look to see if somethings up? i have a 40mhz scope and decent DMM and am used to fixing car audio amps but idk where to look on this dcx. Maybe meter the 5v power to the DACs and maybe scope it see if i get nosie?
Old 1st March 2012, 04:34 AM   #2
Radugazon is offline Radugazon  France
Radugazon's Avatar
Try to disconnect and reconnect the multicable connector that remains (behind the 6 little electrolytical capas). maybe ????
Old 1st March 2012, 04:46 AM   #3
I forgot to mentiin I reseated all conectors and hard reset the unit, no change. Also reseated rcas and physically moved them in case they were picking up emi/rfi. I even added a wire from the dcx chassis to my amps negative/chassis same issue.... Ill meter and scope all the power supply rails tomorrow if I. Have time.
One more bit of info, 2 caps before the inductors in the psu were bulged and replaced when i got the dcx. I used slightly higher value and voltage caps.
Old 2nd March 2012, 12:41 AM   #4
So i changed sources and spdif cables and issue is gone. I have it playing with everything at -0db with some clipping on loud songs and no distortion. I guess that cables picking up rfi or something weird
Old 2nd March 2012, 04:22 AM   #5
Radugazon's Avatar
Good lesson to remember, but strange. When I do measurements I use sometimes a 6 meters cable plugged in the SPDIF input. 75 ohms load, no trafo, no problem, but the ground of all the system is very good.
DCX2496 problem - distortion with multiple outputsHide this!Advertise here!
Amp with multiple stereo speaker outputs hazymat Solid State 7 26th June 2011 11:47 PM
Multiple S/PDIF outputs jman11964 PC Based 1 12th February 2011 03:55 AM
Multiple digital outputs from a PC herm Digital Source 8 17th July 2008 10:24 PM
multiple dacs for DCX2496? Ang Digital Line Level 5 2nd June 2007 07:48 PM
decent pc soundcard with multiple outputs? zag0r Digital Source 6 10th May 2004 05:00 PM
