Choosing the right cap - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 29th February 2012, 06:22 PM   #11
SoNic_real_one, thank you, a lot!
This is REALLY helpful for my project. I have so much concern about routing, spending hours copying the schematic is frustuating.
Old 29th February 2012, 08:56 PM   #12
You're welcome. I don't see too many polite people on forums anymore
Old 1st March 2012, 02:02 PM   #13
Hey again,
Maybe I should start another thread, but since it is about the same datasheet I go on here.
I'm now wondering about powering and grounds. Maybe you've seen it coming .
http://www.ti.com/lit/ds/slas194/slas194.pdf
Page 25 and 26, opamps are powered by 5v, and wired to ground. I believe this is a "mistake". Opamps process analog signals, so they have to be wired to AGND. And their positive inputs are biaised to AVdd/2, so they must be powered by AVdd, which is 3.3v, not 5v. Am I right?
This is what TI did page 26 of this application note:
http://www.ti.com.cn/cn/lit/ug/slau057/slau057.pdf
Isolating analog and digital sections now:
I use an arduino mega, so power supply is regulated.The arduino provides me with 5v and 3.3v power supplies. 5v is my digital supply, and 3.3v the analog one.
I think I will only use one ferrite bead, placed between the two grounds. DGND will be directly wired to power supply ground, and will physically be close to it (to prevent high frequencies currents from returning into the analog part). AGND will be isolated by the ferrite bead.
What do you think?
Knowing that what I'm designing is an audio effect. So this is NOT hifi. And it will be my first pcb design with more than 10 components. So I'm not looking for perfection.
Sorry for english mistakes, everyone noticed I'm not a native ;+).
Old 3rd March 2012, 05:21 PM   #14
AGND is the same as GND. Bias is provided by VCOM (DAC output) or 2.5V (in the ADC input schematic), and is power by 5V. Is not a perfect, but is a easy arrangement.
Old 3rd March 2012, 07:40 PM   #15
The text says the maximum differential signal is 4V, so the op amps cannot be powered from 3V3. 5V is correct for AVdd, with 2.5V common mode.
cap for adding offset before adc - but which cap in signal path?? thesoundlab Parts 3 31st March 2011 03:50 AM
Choosing replacement coupling cap values studeb Analogue Source 3 15th February 2011 11:37 PM
Polar electro with bypass cap to replace nonpolar as coupling cap? at77 Parts 0 12th January 2010 02:05 AM
choosing cap values for aikido jayme Tubes / Valves 2 25th October 2006 02:09 AM
Low-ESR cap -vs- Normal cap with sunbberized. nina Chip Amps 11 11th September 2005 07:20 PM
Copyright 1999-2017 diyAudio
