Anyone tried this Ebay dac?
Old 15th March 2012, 11:37 PM   #31
solviken is offline solviken  Norway
So i have been going over the board now, all the solderings etc etc.
And i found to empty holes( supposed to be empty from the ebay photos), one that says 10k and another that says S9014 ive attached a photo below. with marking!
Do you know what these are?.. And what their purpose would be? PLease can someone easy my curiosity :P
Old 15th March 2012, 11:47 PM   #32
SoNic_real_one is offline SoNic_real_one  United States
The 10k resistor looks like is controlling the base of the transistor S9014.
Cannot see where is comming from in that angle, or what the transistor was supposed to do (on the other side of the board).
The connectors are probably for a different analog stage - maybe discrete components (HDAM clones are popular with chinese builders).
Old 16th March 2012, 03:20 AM   #33
I have taken som new photos, maby you can see it now. Jepp it might be for a Hdam.. the pinns are right for it...
The 10K is comming out of the CR9001 chip.
Old 16th March 2012, 05:23 AM   #34
i2k92 is offline i2k92  Indonesia
Solviken, thanks for the photos. Now I'm sure that it can be modified easily to accept other analog output stage.
Originally Posted by Insighter View Post
i2k92, maybe tenor have better jitter reduction than spdif chip?
I'm not sure but I think the tenor sounds better because my software can access the USB port using kernel streaming protocol which is generally known to be better than Wasapi used by my PC onboard coax output.
Old 16th March 2012, 05:31 AM   #35
qusp is offline qusp  Australia
qusp's Avatar
sorry yeah i assumed you were talking about the sockets. empty holes dont appear to be connected to the dac at all, maybe a transistor for pulling a logic pin up on the upper chip?
Old 16th March 2012, 10:52 AM   #36
That resistor comes out from "error" pin of SPDIF receiver - probably will "mute" on error the HDAM module, if installed. The associated (missing) transistor has the emitter connecter to GND so it will be pulled "low" when DIR9001 is not locked on signal. The picture of the reverse side of the board is still missing, so is not telling where the collector pin is going.
Old 19th March 2012, 02:42 AM   #37
So i contacted the seller on ebay, and he explaind all the free pinns the 6 holes on each side of Wm8741 is for upgrading the dac with another WM8741 chip, and the 10k and S9014 is needed for this operation.
But my question will there be any improvment of upgrading to one more WM8741 chip?
Old 21st March 2012, 06:52 AM   #38
No one Knows?
Old 22nd March 2012, 12:36 PM   #39
PJN is offline PJN  United States
Adding anothe DAC chip supposidily improves the noise floor, may not be audible.
Old 22nd March 2012, 05:00 PM   #40
Paralelling DACs with voltage output (this case) might improve the THD level with some 0...6dB, usually 3dB (noise will be the same).
Anyone tried this Ebay dac?Hide this!Advertise here!
Recommend me an eBay DAC. GloBug Digital Line Level 24 28th May 2013 05:08 PM
Ebay dac with: DAC TDA1541, AD1865, AD1955, PCM63, & CS4398! sharpi31 Digital Line Level 2 10th January 2011 07:03 AM
which ebay DAC do I want? nullstring Digital Line Level 10 20th July 2010 06:37 PM
Any experience with this ebay-dac-kit?(searching a diy-dac) xTr3Me Digital Line Level 2 31st December 2009 11:07 AM
DAC outboard from Ebay ttan98 Digital Source 0 22nd August 2007 02:24 AM
