Anyone tried this Ebay dac?
Old 5th March 2012, 12:13 PM   #11
i2k92 is offline i2k92  Indonesia
Check the picture on this : eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
There's 2 empty pads behind the pulse transformer. Perhaps that's the way to connect the USB module to the main board. If that's the case it will be able to accept the Tenor board without any modification.
When you receive the board pls check where the USB module connects to the main board.
Old 5th March 2012, 03:28 PM   #12
solviken is offline solviken  Norway
Will do Might take some time,as i live in norway and takes time getting things from ebay! But il'e get back to you once i get it!
But dont we have to make som changes to the Tenor board? since its originaly usb to coax?
EDIT: Found the same dac from another seller! You can see on the last picture that it goes a wire from the usb board down into the 2 holes!! http://www.ebay.co.uk/itm/Assembled-...item1c246d99fe
Old 5th March 2012, 04:33 PM   #13
Redshift187 is offline Redshift187  Canada
Originally Posted by solviken View Post
Whats I2S Good for?
S/PDIF uses one signal for the data and clock (one wire plus ground). I2S splits that all out into bit clock, left/right (word) clock, data and sometimes more (at least 3 wires plus ground).
I2S is generally preferred within devices since the clocks are given and don't have to be "decoded" from the signal like with S/PDIF.
Consider a DAC like the one you purchased. The PCM2704 converts the USB audio data to S/PDIF, then the DIR9001 converts from S/PDIF to I2S, then the WM8741 converts the I2S to analogue. If it used a PCM2706, it wouldn't need to convert to S/PDIF, and the DIR9001 would be unnecessary (for the USB input).
What the DIR9001 adds that the PCM2706 can't do is S/PDIF (and optical) input at 24bit. The PCM2706 can do S/PDIF (and optical) at only 16-bit.
Tyler
Old 5th March 2012, 04:57 PM   #14
Arius is offline Arius  United States
Ugh, both the PCM2704 board and Lars Audio board are typical of EBAY (Made in PRC). The board layout is terrible - decoupling, grounding, routing. It looks like the only thought was for placement to suit the eyes (nice tidy lines of parts) rather than for the electronics.
But hey, it's not expensive and if you like the sound, go for it.
Old 5th March 2012, 10:48 PM   #15
EDIT: Found the same dac from another seller! You can see on the last picture that it goes a wire from the usb board down into the 2 holes!! Assembled WM8741 DAC Board CS8421 Up-Sampling -Support Coaxial optical USB input | eBay
The only mod on the Tenor board is to replace the RCA with wires that goes straight to the 2 empty pad on the DAC board. I'm testing the Tenor board, I'll let you know the result.
That's what matters
BTW, some chinese boards are not that bad. I read somewhere that the famous Gigawork CS4398 DAC (there's a huge thread about it here) was used by Decware for one of their product (with some mods here and there).
Old 6th March 2012, 01:54 AM   #16
bear is offline bear
expert in tautology
bear's Avatar
I bought one of the OP referenced DACs... cheap enough, eh? I thought to myself there are maybe 4 versions all similar to this one, I should blow $250 and have 4 DAC boards and see if any of them sound worth a darn! If one does, not bad, a good sounding DAC for $250 bux!
But hey I will get that one in a couple of weeks and turn it on, see what it does!
It will either sound good or like doggie poop I expect. The seller was supposed to email me a schematic - no sign of it yet. Maybe it will be in the box. I hope.
Should I get it up and running I shall report back to the mother ship.
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 6th March 2012, 01:57 AM   #17
Pano is offline Pano  United States
Pano's Avatar
Cool! Lets us know what you find.
Old 6th March 2012, 03:31 AM   #18
expert in tautology
bear's Avatar
a crushed manila shipping bag with a flattened cracked board inside?
_-_-bear
_-_-bear
Old 6th March 2012, 04:09 AM   #19
qusp is offline qusp  Australia
qusp's Avatar
yes, and they were universally criticized and ridiculed for that decision; supporting all chips on adapter PCBs + pinheaders is just one major problem with these layouts that cannot be overcome with mods
Old 7th March 2012, 04:58 AM   #20
expert in tautology
bear's Avatar
Yeah but the thing is $50USD... the chips would probably cost you more if you had to go acquire them separately... this one has no pinheads
_-_-bear
_-_-bear
Anyone tried this Ebay dac?Hide this!Advertise here!
Recommend me an eBay DAC. GloBug Digital Line Level 24 28th May 2013 06:08 PM
Ebay dac with: DAC TDA1541, AD1865, AD1955, PCM63, & CS4398! sharpi31 Digital Line Level 2 10th January 2011 08:03 AM
which ebay DAC do I want? nullstring Digital Line Level 10 20th July 2010 07:37 PM
Any experience with this ebay-dac-kit?(searching a diy-dac) xTr3Me Digital Line Level 2 31st December 2009 12:07 PM
DAC outboard from Ebay ttan98 Digital Source 0 22nd August 2007 03:24 AM
Copyright ©1999-2017 diyAudio
