DAC with only optical input
Old 24th February 2012, 11:03 AM   #1
Wishborn is offline Wishborn
Default DAC with only optical input
Hi, I'm looking for a diy Kit DAC on ebay. I wont be needing anything else than optical and would keep the amount of stuff to a minimum.
Do you guys know of any such? What is the thing to look for...
regards
Old 24th February 2012, 05:35 PM   #2
jstang is offline jstang  United States
You can add optical easy enough.
I think you will find that most board kits do not have it.
Jk
Old 24th February 2012, 05:40 PM   #3
ok.
you got any starting point, what to look for and quality of such?
Old 24th February 2012, 05:47 PM   #4
Twisted Pear Audio
Old 24th February 2012, 05:49 PM   #5
we are talking TOSLINK Optical Input Module
this signal can do directly to my preamp?
Old 24th February 2012, 05:52 PM   #6
Nope, that toslink is for use between the dac and transport. The dac is outputting analog signals.
Jk
Old 24th February 2012, 06:01 PM   #7
hmm seems like I have missed something.
So computer outputs 16bit 96khz toslink receives and put it to a DAC?
Old 24th February 2012, 07:29 PM   #8
Your computer is the transport.
What outputs do you have from the computer?
The dac will take a digital format input and convert it to analog output. The digital input might be co-ax or tos-link or USB or others.... The analog outputs are usually RCA jacks. And those connect to the preamp.
Some preamps have a dac built in. Which then would have some type of digital input.
Jk
Old 24th February 2012, 09:04 PM   #9
Shamron is offline Shamron  Norway
Shamron's Avatar
Hi. This is a friend of Woshborn (He's sitting here with me, i'm just not fond of logging in and out of accounts) ;-)
He's got an iMac with optical (toslink) out will use a preamp after the dac. He's interested in knowing what's considered the "best" diy dac out there at the moment. Gigawork sells the common "large" one from the 2000+ post thread on these forums, but he also sells a more compact dac consisting of two pcb's. One dac board and a separate psu board. He thinks that the large one is too large and I personally don't like the word "compact version" as it makes me believe there are compromises in the circuitry.
His needs are optical ONLY and 24bit/96Khz. Do you guys have any reccomendations for him that you personally have experience with?
Also, does anyone have any experience with using these compared to using a single chip opamp? : eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
It sure looks awesome and the "wow-factor" itself almost makes it worthwile, but i notice that it's using Dale 1% resistors and that makes me believe this solution is more accurate and less "compromicy" than using a single chip.
Answers are highly appreciated as we are two that wonders about these questions.
Wishborn and Shamron.
Old 24th February 2012, 10:26 PM   #10
Well the problem is that going with home build kit.... Implies you have done your home work.
People will give you a lot of suggestions....but you will stil need to do your home work.
Reason is that personal opinion of sound quality will come into play.
Jk
DAC with only optical inputHide this!Advertise here!
Optical digital input to SAA7341 decoder/DAC danhar707 Digital Line Level 4 22nd March 2011 11:35 AM
High performance DAC mDAC-2v(USB, Coaxial, Optical input) ck210 Vendor's Bazaar 4 6th July 2010 09:19 AM
Jambo DAC - DIY USB/Optical/Coaxial DAC kit now available! Jambo Digital Source 8 20th August 2008 09:41 AM
Trying to add an optical input Albertone Digital Source 3 2nd January 2007 02:22 PM
TORX179 Toslink optical input sunrise Digital Source 5 30th January 2006 02:56 PM
