Real or fake?
Real or fake?
Old 19th February 2012, 12:19 AM   #11
Bernhard is offline Bernhard  Germany
Bernhard's Avatar
All removed from old cd players.
Chips from recent production could look different.
I have another 32 pieces in my DAC, some made in PhilipPines.
Old 19th February 2012, 12:59 AM   #12
SoNic_real_one is offline SoNic_real_one  United States
Looks like my sound card input cannot go below 0.096% THD on input. And loopback from line-out is even worse that playing a CD! Normal, the card has the crappy original OpAmps and a CL DAC.
I need a better ADC
And RMAA free does not analize wav with higher PCM than 44.1kHz and 16 bit. What other software can I use?
@Bernhard - do you have any PCM61P-K?
Old 19th February 2012, 07:05 AM   #13
bicefalo is offline bicefalo  Italy
May VISUAL ANALISER 2011XE be usefull to You.......
cheers.
Old 19th February 2012, 02:02 PM   #14
That's cool, thank you. However it lacks a feature that RMAA has. It needs to be able to save as wav a "test" signal, that I can burn and play on my CD player. Then record via ADC to be analyzed in the software. RMAA does that, but the free version accepts (loads) only 44.1kHz/16bit input from ADC, and that limits the capability. My ADC has a slow roll-off filter at that sample rate -6dB at 20kHz, so I really can analyze only to 15kHz.
Plus, from my preliminary results, looks like I need a better soundcard (better THD on ADC part).
Old 20th February 2012, 04:48 AM   #15
5th element is offline 5th element  United Kingdom
5th element's Avatar
Just use ARTA's spectrum analyser it will work with an external source, just set the input going and turn off the generator.
What ADC does the card use? That distortion seems unusually high, especially for what creative are marketing as a somewhat more upmarket card, usually they use decent converters.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 20th February 2012, 11:32 AM   #16
The "consumer" sound cards have usually given only the output specs (DAC). For X-Fi Platinum:
• Stereo Output 109dB
• Front and Rear Channels 109dB
• Center, Subwoofer and Side Channels 109dB
• Total Harmonic Distortion + Noise at 1kHz (20kHz Low-pass filter) = 0.004%
The ADC seems to settle THD=0.1% (at 44.1 kHz/16 bit) since two different players show the same value. I did try loopback on card and is even worse!? I will play latter with the other software, maybe is an operator error.
Old 20th February 2012, 03:26 PM   #17
Well I know that creative cards are notorious for using lots of processing so it could be shoddy DSP work that's destroying the linearity 0.1% seems too high and even higher in loopback mode? Something doesn't seem quite right.
Old 20th February 2012, 03:53 PM   #18
I did try to set the X-Fi DSP master clock to 88.1 and 96kHz and it didn't do any change in results - looks like the DSP induced THD is really lower than that (they claim -140dB).
I did try to set the recording rate to 96kHz, but then the RMAA complained that the resulting files are not "PCM standard" and cannot use them...
I will try today using the ASIO options in the Creative software and maybe other recorder than the stock Creative one.
Old 20th February 2012, 09:35 PM   #19
Bernhard's Avatar
Maybe input level not high enough ?
Old 20th February 2012, 11:17 PM   #20
Then switch and use ARTA instead, it is infinitely more flexible then RMAA. RMAA is a pain.
Real or fake?Hide this!Advertise here!
fake or real ? mgm2000ro Class D 6 14th December 2008 08:03 PM
Fake or Real? Elso Kwak Parts 20 28th May 2005 09:32 PM
Copyright ©1999-2017 diyAudio
