| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
Sorry to start a thread about I/V op-amps. Too many threads about them plus I'm not really trying to revive any specific discussion.
Just FYI for the readers: Stereophile Feb 2012 reviewed the Bricasti Design M1 D/A Processor. DAC is AD1955 (with DSP implementing external filter) in mono differential mode. I/V opamps are AD843. Buffers are discrete transistor based. Results: "Class A+", "State-of-the-art measured performance" The I/V opamp itself isn't fancy but was carefully chosen and voiced. AD843 | 34 MHz, CBFET Fast Settling Op Amp | Operational Amplifiers (Op Amps) | All Operational Amplifiers | Analog Devices Slew rate: 250V/us Input noise: 19nV/rt Hz Settling time: 135ns to 0.01% Please let this be informational only - if you feel strongly about one method of I/V over another (resistor, common-base transistor/FET, your fav opamp), there is no reason to force anyone else to like your taste. As for the technical merits of each method, they have already been debated far and wide. Thanks. PS: I have no affliliation whatsoever with any of the above mentioned companies. Last edited by Arius; 7th February 2012 at 03:42 PM. Reason: Added PS |
#2 |
I am playing now with a few OpAmps (for the I/V stage). My next test subject looks promising:
AD8099. Stable at Gain +2. Noise: 0.95nV/vHz, 2.6pA/vHz Slew rate: 475V/µs Settling time: 18ns to 0.1%, 30ns to 0.01% Distortion: 2nd Harmonic -92dB @ 10MHz; 3rd Harmonic -105dB @ 10MHz -3dB bandwidth: 700MHz (G=+2) I have on my bench a ADA4897-1 that is stable at Gain +1: noise: 1 nV/√Hz, 2.8 pA/√Hz distortion: −115 dBc @ 100 kHz, VOUT = 2 V p-p −3 dB bandwidth (G = +1): 230 MHz slew rate: 120 V/μs settling time: 45 ns to 0.1%; 90ns to 0.01% I did try before to "make" my own discrete OpAmp stage (BJT, JFET, combination) and I realized that I am not capable of even getting closer of values like above ones. Last edited by SoNic_real_one; 7th February 2012 at 05:22 PM. |
#3 |
I realize the app notes for instrumentation application of high speed DACs do emphasize settling time but it really isn't quite the same importance for digital audio reproduction
in audio reproduction we want/need low pass filtered output to reject the "steps", image frequencies, any noise shaping high frequency modulation if you take the current technology "sweet spot" as ~96 k sample rate converters with substantial internal upsampling then ~40 kHz low pass is required with order depending on upsampling ratio and any noise shaping even doubling the sample rate and low pass frequency still gives ~ 2 uS time constants - nS settling time really is irrelevant as a prime I/V performance spec for audio reproduction like slew rate, settling time can be an indirect indicator of certain op amp qualities that may be helpful - but the actual requirements of 40 kHz or even 80 kHz low pass filtered digital audio reproduction at 2 Vrms consumer line levels doesn't require SOTA max slew rate or settling time per se what is really needed for audio I/V conversion is Linear treatment of the DAC Iout while performing the required low pass filtering there a 2 parts of the linear requirement: low delta V at the DAC out - depending on internal details Iout DAC have limited output compliance V, bigger V causes nonlinear loss of the modulated current in protection diodes, switch on-resistance modulation, collector/drain nonlinear Zout - often not rigorously speced but Order of 10 mV seems a good target without a tighter spec or measurements indicating otherwise and Linear treatment of the DAC Iout in the I/V circuit - in the face of high current slew rates and tight input V spec - incorporating low pass filtering in the op amp I/V design gives better linearity even "the best" op amps can't meet both requirements with just R feedback - feedback C greatly reduces dynamics at the I/V input - simple sim does show this clearly additional topology improvements are available "noise gain" C to gnd at the I/V input is a start- again sims illustrate the principles even if not detailed enough for strictly predictive results The ADA489x, AD8099 are something new - the "highly linear input" stage properties are poorly advertised but his is a real breakthrough for BJT input linearity with large input Vdiff - just what we should want for DAC I/V Last edited by jcx; 7th February 2012 at 06:50 PM. |
#4 |
IMO Linearity is derived principally from a fast feedback loop. A slow loop will induce errors in following the signal and intermodulation products.
Also, limiting the SR at the output of a DAC with capacitors (even if they are in feedback loop) will trow off the compliance voltage. If the DAC current source was ideal, sure you can do that safely. But it's not. Last edited by SoNic_real_one; 7th February 2012 at 07:53 PM. |
#5 |
you really are just "shooting from the hip" aren't you - you haven't read reference I gave in the other thread, thought hard about the problem, the points I've made, tried sims to illuminate the issues
#6 |
So let say that you are right and it doesn't matter how fast or slow are the OpAmps.
Why people bother to try tubes, resistor I/V? Or why even the DAC manufactures mention the slew rate and settling time in the aplication notes on datasheets? Just dump a capacitor on outputs and you are good to go... PS: I don't belive too much in spice simulations for anything more complex than a couple of transistors. Last edited by SoNic_real_one; 7th February 2012 at 08:56 PM. |
#7 |
now you're posturing - I never said slow op amp are good for I/V - you have also blown off suggestions, guidance from Thorsten on DAC I/V - clearly you aren't interested in the learning opportunities here
you may consider any further of my comments in threads you’re participating in as directed to the general readership |
#8 |
Thorsten is on my ignore list. Because there is nothing to learn from him: resistive I/V and tubes rules. Selling to a niche. Thanks but no thanks, I don't sacrifice noise for speed!
I don't understand what you want, you just attacked the ideea of fast OpAmp for I/V without providing anything in place (besides "the capacitors are great"). You say that 2uS is "enough", that might be fine with you... I don't want nothing that is below listed current settling time for a given DAC. Maybe I need to learn, but how about engineers that design DAC's - they need to learn too? Tell all those guys here that are looing into discrete stages that they are wrong too... And even your example above - why do you think is looking for tubes and resistive I/V? http://www.ti.com/lit/ds/sbas097/sbas097.pdf - page 9 http://www.ti.com/lit/ds/sles117a/sles117a.pdf - page 19 Last edited by SoNic_real_one; 7th February 2012 at 11:08 PM. |
#9 |
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
It looks a jolly nice part until you look at its settling transient. Guess that's messy in large part because of the gain peaking (+3dB) at G=+2.
You're going to need a series RC on the DAC output to keep the noise gain high, preferably higher than +2 to mitigate the peaking. Curious to know how it sounds
I think ideas are what you want to get rid of. I don't really like songs with ideas. - Leonard Cohen |
#10 | |
The specs seem to have little to do with how they sound. I'd advice you to give discretes another try. Last edited by b1o2r3i4s5; 8th February 2012 at 02:48 PM. |
| 2x Gain pure op-amp headphone amp idea | Dxvideo | Headphone Systems | 30 | 10th September 2011 02:05 AM |
| op-amp + op-amp buffer combinations | eccdbb | Chip Amps | 2 | 22nd July 2011 04:13 AM |
| Poor power output, op amp based headphone amp. | dannybeckett | Solid State | 13 | 27th September 2010 08:31 PM |
| Who has tried a current boosted op-amp (with a transistor) as a chip-amp buffer? | sardonx | Chip Amps | 18 | 19th March 2005 12:23 PM |
| New OP-AMP for Music Man HD-130 bass amp | Kevin McCready | Solid State | 0 | 7th September 2002 11:35 PM |
| Page generated in 0.12627 seconds (83.15% PHP - 16.85% MySQL) with 10 queries |
