Go Back   Home > Forums > Source & Line > Digital Line Level
Old 29th January 2012, 06:10 PM   #11
Hello Everyone ...
I think I detected my TOSLink problem but the issue is very peculiar. Initially I told, TOTX147 is working fine on my PCB cause I can see with SW ON/OFF, TOTX147 also gets ON/OFF. But I am thinking the problem is in TOTX, not in TORX. Cause,
- I removed TOTX from my Board PCB and connect a 3 PIN Header with the TOTX Position.
- Then place the TOTX on Breadboard and connect 3 wire (VCC, VIN, GND) from Breadboard to my PCB 3 PIN Header (of TOTX Position).
- Everything with TORX is working then.
I don't know why the TOTX only working when I am connecting it on Breadboard and not working when I am connecting it on the same 3 PIN of my PCB. Something is happening, when I am connecting TOTX on Breadboard via wires which is making everything work ...
The issue seems very strange
Any suggestion ....
Sakibnaz.
Old 30th January 2012, 08:40 PM   #12
Hello Everyone ... I got new TOSLink Parts (TOTX147PL and TORX147PL). My problem is mostly solved but one very abnormal situation I am facing.
- Initially TOTX and TORX not working on my PCB. So I removed TX and RX from PCB and solder 2 piece 3PIN Header on TX and RX Position so that I can test it from Breadboard with wire connection.
- Now I am observing system is working, only when I am connecting TOTX through wire. If I directly connect TOTX on PCB (on the same point where I connected wires) then its not working.
- Both TOTX and TORX is working when I am connecting TOTX with my PCB via Wires. When I am soldering the TOTX on my PCB.
In summery:
- TOTX LED gets ON/OFF by Switch press in both case. Either TOTX soldered directly or connected via wire.
- But TORX only giving VOUT .... when TOTX connected via wire on PCB. If TOTX directly soldered then no VOUT from TORX.
Any advice or comment please ...
Regards.
Sakibnaz.
adding toslink to receiver mizzl3 Digital Source 1 4th February 2011 12:58 AM
CDROM TTL signal to toslink receiver DECKY999 Digital Source 3 18th April 2008 12:39 PM
Where to Buy TORX179P Toslink Receiver, or Equivalent wup Parts 1 3rd June 2006 05:35 PM
Need to source TORX toslink receiver pixpop Digital Source 11 25th January 2006 01:13 AM
Toslink receiver drewmc Parts 6 24th January 2006 11:50 PM
Page generated in 0.07934 seconds (66.48% PHP - 33.52% MySQL) with 11 queries
