Any good TDA1541A DAC kit?
Old 7th March 2012, 06:05 AM   #401
ThorstenL is offline ThorstenL  Germany
Previously: Kuei Yang Wang
Originally Posted by abraxalito View Post
I flirted with cap to ground but didn't much like the sound on TDA1543 or TDA1545.
At a guess, either wrong value, wrong capacitor type, ground routing issues...
In a differential system you should have one capacitor across +/- out and one each from each output to ground.
The series inductor I chose was one with a high SRF (above 200MHz) intended for use as a CM choke.
If this "coke" is a 4-terminal device and operates on differential outputs then it is not a "choke" in the traditional sense.
The problem with a choke following an I-Out DAC is that the DAC's voltage compliance (real or datasheet) will be massively exceeded... Luckily enough with the Philips parts and common mode only chokes this not much of an issue.
Ciao T
Old 7th March 2012, 06:11 AM   #402
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Yep, all issues considered and looked into at the time.
In a differential system you should have one capacitor caross +/- out and one each from each output to ground.
I generally dispense with caps to gnd (Y) in such and just keep the one X-type.
Yes and no - it has appreciable leakage inductance.
Yep - this is not a configuration I've been tempted to try - choke straight after I-out DAC.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 9th March 2012, 07:16 PM   #403
studiostevus is offline studiostevus  Netherlands
Originally Posted by s3tup
What about my grounds layout?
I didn't liked the capacitive/inductive coupling of DGND and AGND when they are on top of each other (2-layers), so i decided to move the DGND aside.
By doing this i halved the AGND impedance, got solid AGND layer
But i've got a half-circle loop between -5V and DGND pins with -5V PSU in between. The DAC chip is in center of EMI field produced by currents flowing from -5 to DGND and back given the "right hand rule" is true .
My latest layout (not yet built) also has the ground plane for the digital section next to the analog ground plane on the same layer. The tda is on the edge of the Agnd plane (though completely on that plane), and the dgnd plane connects on the entire left side of the tda to the agnd plane. Both planes are almost not interrupted.
One of my previous layouts had dgnd and agnd connect at the agnd pin of the tda only... Worked quite well.
Ecdesigns has, in his latest versions, completely abandoned this discussion: he uses one big ground plane now!
Old 9th March 2012, 08:02 PM   #404
StereoEditor is offline StereoEditor  United States
Originally Posted by gaetan8888
I've take a look today at the Stereophile web site and I can't find those tests.
Can you tell me, please, where they are in the Stereophile web site ?
They are in the March issue (print).
This review will be posted in the free on-line archives at Home Page | Stereophile.com next Thursday or Friday.
John Atkinson
Editor, Stereophile
Old 9th March 2012, 08:03 PM   #405
s3tup is offline s3tup
s3tup's Avatar
Damn i've gone thru 5 layouts, and still think i should scrap the current layout and redo it from EMC point of view /since i discovered EMC Information Centre - The EMC Journal (Free in the UK) .
"Balanced" PSU is BS, you need every cap stuck into low impedance ground to work, otherwise it will just pass the spike from V+ to "GND" without any filtering.
I2S wires should be done without DIP sockets to prevent EMC emissions due to impedance mismatch.
"I2S attenuator" should be done in 2 parts, with loading resistors near DAC and series resistors near DF.
Rethink the GND cutouts from "slot antenna" perspective.
And overall layout of connections/wires when the board goes into real-world application.
Ferrite beads and common mode chokes should be placed everywhere, at least on the points of I/O connections on the board, to prevent EMI emissions/fishing.
Every current should be returned to it's source, otherwise it will find it's way back thru air/other circuit paths affecting the performance of DAC surrounding.
Common ground for D and A sides of DAC is reasonable in many ways. Less EMC due to solid ground, the D and A parts of 1541 are probably capacitively coupled much better than our GND impedance. Therefore, the more impedance we add to GND pins, the less current the GND will catch, and more A to D interference will be there.
GND layers should expand to PCB edges, much futher than other wires, so GND could catch and return emitted EM fields.
Every EM transmitter is a receiver too, in same frequencies and same power, therefore, fighting EM emissions reward us with lower EM fishing too.
I know i'll end-up with solid single GND, and PSU layed-out on one side of the board
Old 10th March 2012, 04:42 AM   #406
regal is offline regal  United States
I picked up a red barron PCB 'cause I won't have time to build a PCB for a while.
I was planning on using SMD caps for decoupling by grinding the solder mask off the top layer ground plain. Then I saw that the i-outs are routed right under the TDA1541 cutting the groundplain in half.
I am thinking of removing the mask off that area under theath completely and soldering a thick piece of coper foil underneath the TDA. Going to be a PITA.
Old 10th March 2012, 05:09 AM   #407
Go for it.
Or just use my suggested Veroboard method. If you have enough silverfoil you can even make an all silver DAC that way...
Ciao T
Old 10th March 2012, 06:04 AM   #408
gaetan8888 is offline gaetan8888  Canada
John Atkinson
Editor, Stereophile
Hello
Thank you Mr Atkinson
Are you going to the Montreal Hi-Fi Show (Salon Son & Image) this year ?
Bye
Gaetan
Old 10th March 2012, 12:00 PM   #409
Pano is offline Pano  United States
Pano's Avatar
OT posts and insults removed. Warnings given. Keep it civil, gentleman.
Old 10th March 2012, 11:39 PM   #410
s3tup's Avatar
This one goes to production tomorrow, unless i'll find something to fix at mornin' coffee.
- Added some ferrite beads on power rails
- A bit of cutouts around PS ferrites to lower parasitic capacitance around 'em.
- Changed reg bypass caps to electrolytics, as LM317/337 have no love for low impedance on their outputs, but they want some caps to stay stable.
- Some graphics added.
- AGND/DGND could be stitched together with a bit of solder around plane edges.
- Pad for foil-screen grounding. You can glue a ribbon of foil around 1541, and solder it to the pad. Aaargh, DGND or AGND?! Okay, ive added the same "pad" on DGND side too. /not in pic/
- A tiny pad for I2S att resistors, pretty optional, as i had no place to mount them in a good way, and i didn't want to pass traces under resistor's belly due to parasitic capacitance. The resistors could be mounted on their side, between I2S pins and a spot on DGND.
Any good TDA1541A DAC kit?Hide this!Advertise here!
Raindrop Hui TDA1541A DAC Kit wushuliu Swap Meet 25 21st November 2013 10:07 AM
which clock for analogmetric tda1541A dac kit Chilli6565 Digital Source 4 6th May 2010 12:41 PM
FS: AYA DAC Rev 2.0b TDA1541A Non-Oversampling DAC kit or complete krishu Swap Meet 0 17th December 2009 09:33 AM
Recommend a DIY tda1541a dac kit? boidos Digital Line Level 2 6th August 2009 01:43 PM
TDA1541A Chineese DAC KIT UV101 Digital Source 8 10th February 2009 10:46 AM
Copyright ©1999-2017 diyAudio
