Any good TDA1541A DAC kit? - Page 45 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 29th December 2012, 01:40 PM   #441
Yes... Seems so...
Btw following your threads on Nos Filters (which went in the direction of recording quality) and the tda1543 ozone over at WBF.
What is your take on tda1387? I actually believed thia may be the mysterious uda1305at used in the amr cd777. At least its multibit, compared to cc of the tda1305...
TDA1541a-S2 / 6072a / MediaplayerDac -- Michell Gyrodec -- Aikido Preamp -- Pass F5 -- Audio Physic Tempo 2SE -- Yamamura Cabling
Old 29th December 2012, 01:45 PM   #442
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
I like the TDA1387 but it takes about double the power of the TDA1545A so I'll use this one when I need lowest power. I'm using TDA1387 on Ozone because power isn't an issue and its I2S just like TDA1543 so no mods are needed to the digital stuff. I rather suspect that the cd777 uses TDA1545A because its a bit more flexible in programming the bias current and I know Thorsten likes to run it a bit hotter than normal
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Old 29th December 2012, 03:18 PM   #443
At least we both suspect uda1305 is a little trick (not referring to tda1305)... but rather referring to the "second grade" multibit dacs like 1387/1545/1543 (dont think it is 1543 though)
Old 29th December 2012, 03:31 PM   #444
abraxalito's Avatar
No, its highly unlikely to be 1543, I seem to recall the measurements looked too good for that. Also when the output stage is valve, the designer can afford more glitches because a valve has better HF linearity, hence no major drawback to using CMOS over bipolar I'd have thought. So it would be an extremely odd choice if it were the 1543.
Old 29th December 2012, 04:51 PM   #445
dacen is offline dacen  Norway
For those of you that are into TDA1541. This unit Nakamichi DAC101 intended for car audio has an interesting dual TDA1541 S1 single crown in differential mode. They show up on Ebay from time to time. I bought one for $100,- and who knows what a little tweaking and modification can reveal.
Old 29th December 2012, 05:12 PM   #446
abraxalito's Avatar
It could certainly use substantial modification - fancy blowing away a perfectly good DAC by using 5532 I/V
Old 29th December 2012, 05:17 PM   #447
That is exactly what I mean. Its a very good basis for modification. The first thing I have removed is the DC-DC converter (12v to +-15v)and substituted with a traditional power supply
Old 1st January 2013, 09:45 PM   #448
Default My layout
Here is the layout I am working on. It is simpler than the full reclocker that has been suggested. I have a layout with the full reclocker, but am not really happy with it, also, with the reclocker circuits others are working on, I'm not sure it is necessary. Also, the source I would be using for the time being is usb using a 12mhz clock. So this is a simple one incorporating some of the recommendations from this thread. What do you guys think. Any changes that should be made, or is it worth a try.
Chris
Old 2nd January 2013, 07:54 PM   #449
Default Latest
Latest version with some PS optimizations.
Old 2nd January 2013, 08:59 PM   #450
qusp is offline qusp  Australia
qusp's Avatar
you need to modify your u.fl pattern to include a routing keepout area in the middle. also I wouldnt bother with the rear pad, its normally not used. I dont know enough about the TDA1541A to comment otherwise i'm afraid
Raindrop Hui TDA1541A DAC Kit wushuliu Swap Meet 25 21st November 2013 11:07 AM
which clock for analogmetric tda1541A dac kit Chilli6565 Digital Source 4 6th May 2010 01:41 PM
FS: AYA DAC Rev 2.0b TDA1541A Non-Oversampling DAC kit or complete krishu Swap Meet 0 17th December 2009 10:33 AM
Recommend a DIY tda1541a dac kit? boidos Digital Line Level 2 6th August 2009 02:43 PM
TDA1541A Chineese DAC KIT UV101 Digital Source 8 10th February 2009 11:46 AM
Copyright 1999-2017 diyAudio
