Go Back   Home > Forums > Source & Line > Digital Line Level
Old 20th January 2012, 01:42 AM   #201
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
Originally Posted by SoNic_real_one View Post
You want to convince me that TDA1541 with max 4x OS capabilities will swing faster the outputs than the BB DAC's (rated at 8 and 16x) and the Phillips datasheet is wrong when it says the settling time is 1 micro second?
I think nowadays people use TDA1541A which has a plot of distortion vs freq at 8fs (fig4). Also what's the DNL spec for your beloved BB DACs - do you have it to hand?
When a measure becomes a target, it ceases to be a good measure. C.A.E. Goodhart
Old 20th January 2012, 02:20 AM   #202
regal is offline regal  United States
Well, to give you credit for something, I become curious to test the new, fast, low noise ADA4897-1 in my PCM61 DAC. I need an adaptor single-dual now...
Would this ADA4897-a make the issue of high input impedance of opamp I/V's with the dac rise time. Ie, would its input impedance not start to rise so far into the mhz that a DAC would never see it ?
Old 20th January 2012, 02:43 AM   #203
You made a funny
I was using BB DAC's as examples just because... they did build lots of r-2r dac's. BB developed many DACs in the ladder configuration - 16, 18, 20, another 20, 24 bit. Phillips developed... two r-2r: 14 and 16 bit.
And when BB was laser trimming their resistors, Phillips decided to continue their development of r-2r with TDA1543 - 16 bit with performance below 13 bit (-75dB)...
The DAC current is 1...2mA. Voltage 2V. That means 1..2 kohm resistance. I think the output impedance of the OpAmp that can drive 100 ohm at 1MHz and 80mA will be just fine. BTW it's a SiGe CMOS part...
Old 20th January 2012, 02:57 AM   #204
abraxalito's Avatar
You made a funny
I'm always hopeful that I can entertain as well as educate
Yep, but you missed out PCM53.
To borrow a phrase from Thorsten - this is patently untrue. You're as bad as him at digesting datasheets.
You're talking full scale THD figures here? What's the relevance to audio? Oh and yet another patent falsehood
Old 20th January 2012, 03:04 AM   #205
Sure, has no relevance when it stings
I guess you did read the fable with fox and the grapes?
Old 20th January 2012, 03:08 AM   #206
abraxalito's Avatar
Yep I've read it - did you notice incidentally that my chosen I/V converter has worse specs than -75dB at full scale? Regal's given me some stick about that
Old 20th January 2012, 03:29 AM   #207
Previously: Kuei Yang Wang
Location: Somewhere nice on planet earth where censorship of Ideas is frowned upon
I never claimed that the Philips Chip settles faster than the BB ones. Nor have I indeed made any of the other claims you attribute to me.
The BB chip is rated to settle to +/-0.0006% of full scale, which is +/- 2LSB for 16 Bit and +/- 4LSB for 18 Bit. As for 1uS, this is TDA1541, I was referring to the later and by far more common TDA1541A which is specified to settle TO +/- 1LSB (+/-0.0003%) in under 500nS. It is anyones guess what the settling time to +/-4LSb would be like...
Past that, settling time TO +/-1LSB is much longer than the RISE TIME. And the rise time is what may cause a feedback amp to slew. It is also important to note that almost all I/V circuits are integrators, placing additional demands on the op-Amp to charge/discharge the integrator capacitor.
Why?
According to you (post 186) 12V/uS slew rate is all that is needed. Maybe you should try a TL072 instead?
Ciao T
Old 20th January 2012, 03:40 AM   #208
Philips never build R2R DAC's.Philips DAC's have always used active switched current sources and multi-emitter transistor dividers.
Ciao T
Old 20th January 2012, 03:44 AM   #209
What part of which datasheet did I get wrong? My quip about the Fet switches in you favourite VGA? If they do not use switches, what do they use, do you have any reference that shows what is used?
Ciao T
Old 20th January 2012, 04:00 AM   #210
abraxalito's Avatar
Yep. Incidentally it was a little more than a 'quip' but we'll let that slide for now
Why would you believe what I say when you don't believe what ADI says? I'd only be quoting from that - that DS and the related parts using the same architecture plus ADI's design support materials are my only source.
Even if you didn't read the explanations the fact that the attenuation vs control voltage plots are smooth without step jumps might tell you something which undermines your FET switch opinion.
Raindrop Hui TDA1541A DAC Kit wushuliu Swap Meet 24 13th April 2011 01:04 PM
which clock for analogmetric tda1541A dac kit Chilli6565 Digital Source 4 6th May 2010 12:41 PM
FS: AYA DAC Rev 2.0b TDA1541A Non-Oversampling DAC kit or complete krishu Swap Meet 0 17th December 2009 09:33 AM
Recommend a DIY tda1541a dac kit? boidos Digital Line Level 2 6th August 2009 01:43 PM
TDA1541A Chineese DAC KIT UV101 Digital Source 8 10th February 2009 10:46 AM
Copyright ©1999-2013 diyAudio
