| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
Hi can anyone tell me if the spdif out on the 7220 is generated before or after the filter??? I don't ever remember seeing the answer posted on the forum before!
Happy Christmas
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk Restek Fantasy, Audio Aero Capitole MKII, Focal and Kimber
#2 |
#3 |
Thanks, I thought it would be ;-)
#4 |
If it was so, it would push the data rate to 4x of the original digital signal. Back then it was not fesable.
It's raw digital, all the filtering and OS is left for the receiver/DAC stage. |
#5 |
Ok so humour me........
What would happen if you fed the i2s out that was destined for the tda, into another 7220. This would then generate spdif based on the filtered data? Also I wonder how this would effect the sound at the tda? Not sure ive ever read about anyone trying multiple filters in line!
#6 |
I wouldn't expect it to work. The SAA7220 is designed to receive non-oversampled data, you won't be able to just stack them. However, a modern S/P DIF transmitter, such as the DIT4192, shouldn't have any problem converting the filtered I2S output of a SAA7220 into a S/P DIF stream, if that's what you're trying to do.
Inside Classic Audio, my blog on repairs, modifications and anything else to do with audio. |
#7 |
In my experience, SAA7220 does a fairly lousy job as OS filter. The number of FIR coeficients is limited (4x30 coeficients), based on what was technically fesable back then.
#8 |
Was more from a curiosity point of view than trying to achieve anything. Surely the second filter would have no comprehension that the i2s has already passed a filter??
#9 | ||
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
I think ideas are what you want to get rid of. I don't really like songs with ideas. - Leonard Cohen |
#10 |
I have a Phillips with the SAA7220 and TDA1541. Replaced the OpAmps (LM833). Sounds artificial, that dry "CD sound" that everybody talks about and they keep repeating since the 90's. Some blaim the jitter, some the filters, some the fact that was a rush 16 bit job from the 14 bit that they had in mind. Probably the limited RAM that SAA7210 has doesn't help either (Sony parts had double that ammount).
Based on the stories here, I did try the NOS on it - even worse, back to OS. I sometimes pull it out and try to listen to it. To me, it is boredom. Sure I can see the apealing side to it - BIG chips, BIG terminals, all trough-hole parts, any beginner can play with it. And whatever you do to it it still doesn't leave the feeling of "I'm done, perfect sound, now I can LISTEN the music". You keep on tinkering... PS: I did hear once a Denon DCM-560. I did like it (the sound) and wanted to know what was different. CXD2500 with 32kB RAM. SM5845 as filter. PCM61P as DAC. I almost bought it - then I realized that the price was too high for what it was. A nicer CD player than my Phillips. Last edited by SoNic_real_one; 31st December 2011 at 06:15 AM. |
| Can I connect a DIR9001 to spdif of saa7220? | hugomeekes | Digital Source | 0 | 28th February 2011 05:01 PM |
| Can I connect a DIR9001 to spdif of saa7220? | hugomeekes | Construction Tips | 0 | 15th February 2011 11:16 PM |
| Saa7220 sparks from ground pin (killed a saa7220 ?) | ash_dac | Digital Source | 26 | 26th March 2006 02:32 PM |
| A question on SPDIF | Bronze | Digital Source | 1 | 9th December 2004 02:57 PM |
| CDROM SPDIF question | splus | Digital Source | 1 | 28th December 2003 08:15 AM |
| Page generated in 0.10702 seconds (81.91% PHP - 18.09% MySQL) with 10 queries |
