Go Back   Home > Forums > Source & Line > Digital Line Level
Old 31st December 2011, 11:11 PM   #11
amc184 is offline amc184  New Zealand
amc184's Avatar
Originally Posted by UV101 View Post
... Surely the second filter would have no comprehension that the i2s has already passed a filter?
Yes, as far as the data having been altered is concerned. However, it's an oversampling filter, the output I2S bus runs four times as fast as the input one. This will cause problems as the SAA7220 can't run that fast, as well as the relationships between the I2S clocks and the master clock being altered.
Inside Classic Audio, my blog on repairs, modifications and anything else to do with audio.
Old 31st December 2011, 11:57 PM   #12
To my ears the SAA7220 can be part of an excellent sounding CD system.
The last couple of days I worked on, and compared, the digital output of my old Rotel RCD955-AX, which is based on Philips chips (SAA7220-TDA1541A), with a more ambitious Kenwood DP-X9010 CD transport (Sony CXD1125 demodulator chip).
After optimizing the quality of the SP/DIF signals in both players (the pulse transformer in the digital output line of the Rotel was removed as it completely destroyed the quality of the signal) and listening to each "transport" the last days I prefer the Rotel/Philips, sounding more fluid and less harsh compared to the Kenwood.
DA converter is the really excellent Metrum Acoustics Octave, a non oversampling type which does not use the well known "audio" chips, and puts out a signal without needing an analog output stage. This converter is quite "hot" at the moment after a review at 6moons, and to my ears it deserves every right to be so; this combo provides me with by far the best and most musical CD playback, and that's with the SAA7220. Sound surpasses everything I heard until now, including Sabre, BB and AD (non) oversampling and or upsampling types.
NOS Mini DAC Octave
My conclusion: it's all in the implementation.
Old 1st January 2012, 12:14 AM   #13
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
Just worth mentioning here that the SAA7220's filter isn't in circuit in such a set-up, only its error-interpolation and SPDIF modulation functions.
When a measure becomes a target, it ceases to be a good measure. C.A.E. Goodhart
Can I connect a DIR9001 to spdif of saa7220? hugomeekes Digital Source 0 28th February 2011 05:01 PM
Can I connect a DIR9001 to spdif of saa7220? hugomeekes Construction Tips 0 15th February 2011 11:16 PM
Saa7220 sparks from ground pin (killed a saa7220 ?) ash_dac Digital Source 26 26th March 2006 02:32 PM
A question on SPDIF Bronze Digital Source 1 9th December 2004 02:57 PM
CDROM SPDIF question splus Digital Source 1 28th December 2003 08:15 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
