| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
Would this output stage work successfully for an AKM4396 DAC chip?
#2 | |
1) I never like when voltage output DAC datasheets say that they can drive 1k or 2k ohm loads. No doubt they can, but why load the DAC output more than necessary? I'd prefer to see a much larger load, maybe 20k ohms with 270pF in shunt. Noise will be a little higher, but I'd rather trade noise for distortion. 2) Depending on the load presented by the next stage, you might eliminate that MOSFET output buffer altogether.
Ken |
#3 |
Thanks for quick reply, will do.
How about grounding for the system would this be good. Common star ground for all PSU's. Heater (-) and mosfet buffers resistors on separate ground to main gnd Tube Shield and 47K resistors on separate ground connected to main ground also connected to chassis, with RCA jacks not isolated from chassis. DAC PCB ground connected to star ground and grid stopper resistors and capacitors connected to DAC PCB ground. |
#4 |
FINAL PCB
#5 |
Not enough filtering. Look in the datasheet at their LPF circuits (page 34, 35, 36) and ask yourself why the engineers that design the DAC show more than 1 pole filter (that you have now).
Are they stupid? Then probably you should not use their product. |
#6 |
Filtering, filtering, filtering....some time less is more.
Audio engineers some time like too much graphics... Happy Christmas. Marco |
#7 | |
Ken |
#8 |
Could I use 3 diodes in series with the AKM's outputs, to prevent the possibility of a grid to anode short destroying the AKM chip.
#9 |
What should the CCS current be for this circuit
| cs43122 tube output stage help - based on cdenhancer II design | ackcheng | Digital Source | 21 | 19th March 2006 02:37 AM |
| Tube Output Stage | Mighty Mouse | Tubes / Valves | 3 | 24th August 2004 08:08 PM |
| 12v tube output stage for cs43122 based dac? | mbcouple | Tubes / Valves | 10 | 14th August 2004 01:47 AM |
| need help on tube output stage.. | tone | Digital Source | 2 | 19th March 2003 04:52 PM |
| Page generated in 0.10418 seconds (80.63% PHP - 19.37% MySQL) with 11 queries |
