Go Back   Home > Forums > Source & Line > Digital Line Level
Old 17th December 2011, 08:53 PM   #1
Default ARC passive IV ciruit question
I was looking at some high res pictures of the ARC DAC8. They use this passive circuit for IV then it just goes into the Ref3/5 preamp circuit. I have all the component values except R7 and R8. The color bands suggest that the value is 475 something. 47.5R or 4.75R etc. It looks like it comes from a -15v supply that is used for the CCS for the preamp. Any idea why it is there and what the proper value would be.
Old 17th December 2011, 08:55 PM   #2
Audio Junkie
Zero Cool's Avatar
I'm not sure what you are looking at but an ARC Dac8 does not have ANY tubes!
It's not about what you can BUY...It's about what you can BUILD!
Old 17th December 2011, 09:15 PM   #3
A wild guess would be that they might be using it to grid-bias the tube. As in, directly grounding the tube cathode and using a negative bias supply to the grid. If you can determine that the 6H30 cathode is tied directly to ground, then that is probably the explanation. If so, then the correct value would be whichever resistance correctly biases the 6H30 via the -15V voltage-divider formed by that unknown resistor and the 10k resistor connected to the DAC output.
Ken
Old 17th December 2011, 09:42 PM   #4
Oops, I meant the CD8. The Cathode is not grounded. It is supplied by the CCS.
Old 18th December 2011, 01:22 AM   #5
Another example of fine DIY. Putting negative current from -15V supply in the DAC output... nice. Whatever DAC is that, I bet it's internal curent sink is not happy.
Fobia of capacitors makes "monsters".
Old 18th December 2011, 06:11 AM   #6
Is not a DIY circuit. He said it was from one of ARC's digital products. In addition, the top T.I. DACs (the PCM179X series) feature a quiescent D.C. output current of up to -6.2mA, which could be sunk into ground, or a virtual ground, or a negative supply through the right resistance. Perhaps, this ARC design is using one of these T.I. DACs.
You're hardly even thinking anymore, Sonic, you're becoming just plain reactionary.
Ken
Old 18th December 2011, 08:01 AM   #7
tvi is offline tvi  Australia
tvi's Avatar
See pic
The border between the Real and the unreal is not fixed, but just marks the last place where rival gangs of shamans fought each other to a standstill. Robert Anton Wilson
Old 18th December 2011, 10:27 AM   #8
qusp is offline qusp  Australia
Sometimes a square peg fits a round hole just fine
qusp's Avatar
i hope there is decoupling under the board, if not thats got to be one of the crappest dac layouts i've ever seen! what good are those caps all the way over there?
Old 18th December 2011, 04:49 PM   #9
Okay, that makes sense. This 6H30 is undoubtedly configured as a differential pair with a CCS tail. Which means we can't determine what the grid-cathod bias voltage is from the too little information we presently have. Which further means that I don't see a way to be sure what the multiplier value is for that unknown 475 resistor.
Since you are hoping to clone this ARC circuit from so little information you are free to provide some of your own design parameters. Such as, arbitrarily setting the 6H30 cathodes near ground level, which could mean a grid-cathode bias of about -10 volts, depending on the operating conditions you want for each triode section. That unknown 475 resistor then would become 4.75k.
Ken
Old 19th December 2011, 10:45 PM   #10
Could I just replace the resistor with a pot and then adjust it until the DC sunk into the supply? At what points would this be measured, signal to ground or between the + and - legs of the balanced signal? Would there be any risk to the tube section or DAC during the adjustment?
need data on ARC 4700 and ARC 4800 woody Solid State 2 14th August 2011 04:08 PM
bjt amplifier ciruit shaineice Solid State 0 26th December 2008 03:27 PM
IV Simulation Question PigletsDad Digital Source 1 7th April 2008 12:41 PM
Page generated in 0.11028 seconds (86.11% PHP - 13.89% MySQL) with 11 queries
