Go Back   Home > Forums > Source & Line > Digital Line Level
Old 12th December 2011, 05:45 PM   #1
Default ES9023 and buffer before 10K pot.
Do you need a buffer after the outputs of the ES9023 DAC if you want to use a 10K pot at the DAC outputs to control the volume?
Going to use it as a source for my upcoming headamp with a 21K5 Ohm input impedance.
Thinking about adding an OPA2134 unity gain buffer if it is needed.
Old 12th December 2011, 07:00 PM   #2
diyAudio Moderator Emeritus
jean-paul's Avatar
No you don't but you could have discussed that in the thread about your DAC. Better keep questions concerning more or less the same subject in one thread for readability. A lot of people search later for data and finding it scattered in various threads is difficult to follow.
Check the specs what the minimum load can be. The data sheet says 5 kOhm so a 10 kOhm potentiometer is OK but it is better to put out 2 V an adjust the volume on the amp.
Less is more......
It's only audio
Replacing 50K pot with 10K pot KevinLee Parts 10 10th December 2007 03:50 AM
why not 10k pot jeapel Tubes / Valves 2 16th April 2007 10:27 PM
10k pot for T-amp ? kosta666 Class D 1 24th May 2006 12:52 AM
WTB: 10k pot vdi_nenna Swap Meet 0 2nd April 2005 02:03 AM
10K Pot for the BOSOZ raincheck Pass Labs 13 20th September 2002 06:22 PM
Page generated in 0.06170 seconds (72.18% PHP - 27.82% MySQL) with 10 queries
