Go Back   Home > Forums > Source & Line > Digital Line Level
Old 2nd December 2011, 09:21 PM   #1
Default Filtering PCM 1794 analog output
Hi Folks ! Does anybody know how much filtering ( caps ) is needed at the output of PCM 1794 ? I use 220 pf. across + and - output. Used a Dexa Discret opamp and one of the channels oscilated and burned. The same happened two times for a friend this week.
Old 2nd December 2011, 10:02 PM   #2
5th element's Avatar
Why not follow the datasheet? The PCM1794/2 isn't designed to see a capacitive load on its outputs, they are designed to see zero load impedance, that is be connected to a virtual ground. Buffer the outputs with a suitable I/V converter and then perform any filtering you wish, either as part of that buffer, or after it.
I would recommend including a suitable low pass as part of the I/V converter so as to filter out the high frequency stuff and prevent the active device from trying to act on what could be much higher stuff then it can comfortably work with.
As to the size of the capacitors in the network, this is dependent on the network itself, but the corner frequencies that you should have as a target are listed in the data sheet too along with the recommended filters.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
PCM 1794 Architecture/Concept?? bear Digital Source 19 16th June 2011 07:01 PM
output for DAC(PCM 1794) cka3o4nuk Digital Line Level 0 16th July 2010 07:33 PM
Looking for a DAC tube output for 1794 meezger_seep Digital Source 3 28th November 2008 07:37 PM
PCM 1792 vs. PCM 1794 vs. DSC 179x? capslock Digital Source 3 25th September 2003 03:36 PM
Page generated in 0.06808 seconds (72.67% PHP - 27.33% MySQL) with 10 queries
