What's Wrong With my Wadia
Old 27th November 2011, 07:27 PM   #1
JedS is offline JedS  South Africa
Default What's Wrong With my Wadia
My Wadia DigiMaster X32 DAC has outsmarted me.
This unit is connected via co-ax to a Wadia WT3200 transport.
When the DAC is power on it plays correctly for between 5-7 mins. It then develops a splutter. The bitrate indicator light begins to fade in and out and finally the light and the music disappear. However the unit is still powered. All other selections such as the input selector lights still change and it can be turned into standby.
If the unit is then allowed ten mins disconnected from the mains, it will play correctly for between 5-7 mins again.
More interestingly if this unit is disconnected from the transport and it is turned on to decode, it will indicate the relative bitrate selected as it would connected (this is normal). It then remains on for between 5-7 mins until the splutter begins and the light disappears.
I have her lid off to check for anything obvious, but it is time to get messy. The unit is unmodified and previously untouched.
Please help me save her.
Bitrate lights are seen on the left. The selector button is to the left of the last of the three lights.
Old 27th November 2011, 07:37 PM   #2
poynton is offline poynton  United Kingdom
poynton's Avatar
Sounds like a regulator or something in the PSU section is overheating
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 27th November 2011, 07:42 PM   #3
That simple? I have not run it for longer than it takes to reach its stutter.
Old 27th November 2011, 08:24 PM   #4
poynton's Avatar
Take the lid off and refit loosely.
Switch on and wait for it to go wonky.
Switch off (remove plug from mains) and quickly remove the lid.
Check the regulators with your finger tip for one that is overly hot.
Also look for 'bulging'capacitors or ones showing signs of leakage ontothe PCB.
Andy
Old 28th November 2011, 07:12 PM   #5
The issue seems partially heat related.
When the lid was removed, the DAC played for ten mins. Double the time normal time. However after allowing it half an hour to repeat this test, it was determined not to work. The bitrates selector light does not indicate anything.
She has entered the silent age.
There was no obvious heat discrepancy between the rectifiers (she uses 7805CT and 7905CT rectifiers)
There is only one big cap (6800 uf 25v) and this cap seems in good order. Two smaller caps (1000 uf 25v) finish up a what appears to be a fairly simple PSU.
Help help help!
Old 29th November 2011, 11:46 AM   #6
marce is offline marce  United Kingdom
There may be local supplies for some IC's a schematic would help.
Old 1st December 2011, 07:00 AM   #7
renaudagnes is offline renaudagnes  France
Maybe you can see with these guys here, it seems they know perfectly what this kind of baby is made of.
www.tvcaudio.com
Old 1st December 2011, 07:11 AM   #8
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Calling these "rectifiers" - not a good sign. Instead of asking in forums just get someone qualified to look at it.
What's Wrong With my WadiaHide this!Advertise here!
Wadia 6 nelsondog Swap Meet 0 15th February 2010 05:32 AM
Replace Dac in Wadia evo 6 Digital Source 5 31st December 2008 02:10 AM
Wrong Voltage / current on BoZ... or Wrong Measuring ? gionag Pass Labs 8 14th May 2008 11:24 AM
Wadia Swift Current? Cameron Digital Source 4 2nd June 2004 07:04 AM
Copyright ©1999-2017 diyAudio
