Bitstream and bass
Bitstream and bass
Old 4th June 2004, 07:01 AM   #11
Fin is offline Fin
Fin's Avatar
Originally posted by JohnW
Try a large Oscon, say 100uF to 470uF with a working voltage greater then 3V
The pin must also be decoupled with a ceramic cap - say 100nF.
Thanks John - would a Rubycon ZA be any good for this job?
Fin
Old 4th June 2004, 08:17 AM   #12
JohnW is offline JohnW  Czech Republic
JohnW's Avatar
Hi Fin,
I find that whichever cap you have in the Vref (and any other position) you always hear there sound signature.
Due to the varied circuit operating conditions (the Vref position requires decoupling at both Low and High frequency), the only way to find out if a cap type will sound ok is to try.
Ive not tried ZAs in the 7323 Vref position, but I would you could even go as high as 1000uF, but it will take say 1 minute for the CD player to reach its full output level on power up.
Better to use the external Vref circuit I posted earlier - then the choice of capacitor becomes far less sensitive.
John
Time is my worst enemy!
Old 4th June 2004, 08:27 AM   #13
Fin is offline Fin
Fin's Avatar
Thanks again John
I'll have a look at your circuit and try to work things out (no background in electronics). Might go with a good quality cap for now - so I can start listening to music again - while I study some more electronics.
Fin
Old 13th August 2004, 03:02 PM   #14
Dr.H is offline Dr.H
Default Vref and SAA7350
Completed the JohnW Vref circuit described in the following threads and used it to supply the high impedance Vref pins on SAA7350.
http://www.diyaudio.com/forums/showt...4&pagenumber=3
Bass is tighter and more defined, especially the really low stuff. Also interesting and somewhat unexpected is the improvement in soundstaging.
Easy to build and worthwhile. Should just note that the 5534's require decoupling caps at their power supply pins. Leave these out and the beast oscillates.
Old 12th September 2008, 07:24 AM   #15
jnewbold is offline jnewbold  Australia
Default Which pin is Vref?
I know this is an old thread but I have a Rotel RCD965BX in near new condition. I have had it since new and have been using it as a transport for an 8 X TDA1543 NOS DAC I built a couple of years ago.
Can somebody please tell me which pin on the SAA7323 chip is the Vref pin under discussion here. I look at the 7323 data sheet and can't see a pin labelled "vref"
However I see VREFL (pin 7) and a VREFR (pin 3) which are the reference voltage inputs for the analog channel grounds, and are normally connected to pin 16 VRO (internal voltage reference output). Both these pins are decoupled by 47uF BlackGates and 47nF ceramics.
I also see pin 17 VRC (internal reference voltage high impedance node requiring an external smoothing capacitor) On the 965BX this is decoupled by a 4.7uF Black Gate and 47nF ceramic.
Is pin 17 (VRC) the Vref pin described in this discussion? if not, what pin should I be looking at?
Thanks for your help.
Joe
Bitstream and bassHide this!Advertise here!
Meitner/Museatex Bitstream DAC Help! ungie Digital Source 4 3rd September 2008 04:17 PM
PCM or Bitstream on a dvd player? karellen Digital Source 4 14th June 2007 11:44 PM
MASH Bitstream,which is better? wvwvwv Digital Source 0 30th July 2005 07:25 AM
Parallel bitstream converters ? Bernhard Digital Source 0 22nd March 2005 03:12 PM
FS: Museatex Bitstream DAC dimitri Swap Meet 0 15th January 2004 08:44 AM
