Go Back   Home > Forums > Source & Line > Digital Line Level
Old 19th December 2012, 03:28 PM   #201
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
At the second filtercap,is that at the ouput of the PSU?There it is 4.97v
Actually I just choose the first transformer I came across in the Elfa catalog..
And I had to slightly bend the pins of the transformer to make it fit on the pcb.
And the extra fuse holder...I forgott there was a fuse on the pcb but had drilled the hole on the back..so I thoght I just as well use it..
What happends if you twist the Spdif cable?
Regards Åke
Old 19th December 2012, 03:44 PM   #202
syklab is offline syklab  Hong Kong
I had to use this transformer and it actually fit nicely. It had to ship from US to HK but orignated from China.
FS16-150 - TRIAD MAGNETICS - BOBBINS TRANSFORMER | e絡盟 Hong Kong
Old 19th December 2012, 04:08 PM   #203
diyAudio Moderator Emeritus
jean-paul's Avatar
Hi Åke, I mean at the second 1000 uF cap.
It's only audio
Old 19th December 2012, 04:15 PM   #204
pchw is offline pchw  United States
Originally Posted by jean-paul View Post
Hi Fred, can you explain why you use 2 fuses in series ?
Double safety , no, just laziness
Nice build, how does the power supply perform ?
The PS performs very well, I had my second Dac board built last weekend.
I am able to compare various PS that I have built for this Dac side by side.
To my ear and my gears, this PS is better than all the souped up 7805/LM317 types of PS and is a touch below the Salas BiB 1.1. But considering the simplicity of packaging the PS and the Dac in one small chassis with such quality, it will be difficult to beat.
- Fred -
Old 19th December 2012, 04:26 PM   #205
jean-paul's Avatar
Thanks for the comment. I am glad you like it. LM723 is a good chip, better than most LDO regs. I knew some would laugh at it but quality was the parameter we choose it for. It seems we did the right thing
It's only audio
Old 19th December 2012, 04:54 PM   #206
Ryssen's Avatar
It is 15v
Q1 gets "fingertip hot"
Regards Åke
Old 20th December 2012, 07:49 AM   #207
jean-paul's Avatar
So you could have used a 2 x 7.5 V transformer. As long as the LM723 gets 9.5 V minimum it wil be OK. Mount a small heatsink or a piece of L shaped aluminium on Q1 just in case.
It's only audio
Old 14th January 2013, 11:03 PM   #208
Is it still possible to get the board and instruction to build this dac?
jgwtriode
Old 22nd January 2013, 10:21 PM   #209
Default Or the Eagle project files?
jgwtriode
Or will you post the Eagle CAD project files? THAT would be slick!! Then we could MOD it a bit... "it IS DIY"
Measurements of an ES9023 DAC fitzfish Digital Line Level 66 27th May 2013 12:56 PM
Bragi, WM8804/ES9023 DAC Neutrality Digital Line Level 9 22nd September 2012 11:10 AM
ESS ES9023 DAC rvrazvan Digital Source 18 3rd August 2011 06:58 PM
WTB: ESS DAC ES9023 2A3SET Swap Meet 1 28th June 2011 02:02 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
