Go Back   Home > Forums > Source & Line > Digital Line Level
Old 5th December 2012, 10:19 AM   #181
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Just ordered some regs from Farnell,will clean the pcb and then test.
Regards Åke
Old 6th December 2012, 02:45 PM   #182
Ryssen's Avatar
I bought an ESD strap today,but he who sold it to me said to eart myself on the case that I was working on and not what i belived on a radiator or similar.
Is this the way to do it?
Regards Åke
Old 10th December 2012, 06:20 AM   #183
pchw is offline pchw  United States
Originally Posted by jean-paul View Post
Me too. I suspect the LM723 power supply PCB will fit in the enclosure which will be at least visually somewhat more appealing.
Indeed, lookie lookie, same cheap enclosure L First listen impression is also very good.
Cled is below the pcb, soldered at the led's pins.
- Fred -
Old 12th December 2012, 06:14 PM   #184
Ryssen's Avatar
Changed the dac chip and the regulator and now its working..
Listening from my computer Spdif out from my ASUS card and a discrete buffer after driving the HD650.
I think I want to listen some more before telling..
Will post some pics later.
Diyaudio:
Buffer:
ES9023 in box:
Regards Åke
Old 13th December 2012, 10:46 AM   #185
would you please tell me type of transformer that you used - seems much high VA than recommended
Old 13th December 2012, 03:21 PM   #186
Ryssen's Avatar
Do you mean me?
https://www.elfa.se/elfa3~se_sv/elfa...=0&q=56-100-27
Regards Åke
Old 13th December 2012, 03:43 PM   #187
thank you for reply
your trafo has higher VA than original recomended - much beter choise
how do you like your build
regards
Old 13th December 2012, 05:45 PM   #188
Ryssen's Avatar
Well,I connected it to my stationary computer from the Spdif on my Asus essence one soundcard,and it sounded okay...
Then I connected the DAC to my laptop wich has the Hiface USB to Spdif interface now it started to sound better infact it sounds fine,clear highs and deep bass.
I wonder why the Spdif on my stationary don´t sound so good?
Regards Åke
Old 14th December 2012, 08:05 PM   #189
Diyaudio:
Buffer:
ES9023 in box:
Wow good looking setup. What's the purpose of the buffer?
Old 14th December 2012, 08:14 PM   #190
Ryssen's Avatar
I use it to drive the headphones,maybe the ES9023 can drive the headphones,I havent tried it...yet.
Regards Åke
Measurements of an ES9023 DAC fitzfish Digital Line Level 63 10th May 2013 03:21 PM
Bragi, WM8804/ES9023 DAC Neutrality Digital Line Level 9 22nd September 2012 11:10 AM
ESS ES9023 DAC rvrazvan Digital Source 18 3rd August 2011 06:58 PM
WTB: ESS DAC ES9023 2A3SET Swap Meet 1 28th June 2011 02:02 PM
Copyright ©1999-2013 diyAudio
