ES9023 DAC PCB - Page 11 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 18th July 2012, 07:41 PM   #101
diyAudio Moderator Emeritus
jean-paul's Avatar
Wima Black Box are MKP10 made for OEM use in the Far East, at least that is what I read. I did not recognize them at first but syklab already answered it are Black Box types.
It's only audio. Member of the non modular PCB design committee
Old 18th July 2012, 07:45 PM   #102
massimo is offline massimo  Italy
Yes, I noticed later that there was another page to read
Old 18th July 2012, 07:46 PM   #103
jean-paul's Avatar
How is your build coming along Massimo ?
Old 18th July 2012, 07:53 PM   #104
Like you, I didn't receive the pcbs yet.... grrrr
And I would like to see your PS and BOM before placing an order for the components I need.
Old 18th July 2012, 07:59 PM   #105
jean-paul's Avatar
You are asking the wrong guy. But it is a somewhat polished standard text book LM723 design with PNP pass transistor. Nothing fancy but very good, we focussed on quality not fashion. Not many LDO's can match it I guess.
Got caught up in more important things but Subbu has the final design and he is busy testing it for you guys/girls.
Old 18th July 2012, 08:23 PM   #106
Do you have by any chance a part # for the Xrfm and the PNP pass bjt?
Are you going to use TH or SMD parts in the PS?
Old 18th July 2012, 08:36 PM   #107
jean-paul's Avatar
You want too much Massimo It uses both TH and SMD. It uses an EI30 transformer but we are having a hard time sourcing them in 115 V and 230 V versions with the same footprint and secondary voltage.
A BD140 will do. 2 x 1000 F 25 V too but we should wait till they have been tested and things may still change.
Old 18th July 2012, 09:08 PM   #108
skouliki's Avatar
Jean-paul do you know how much current the es9023 dac needs? I cant find any info about it (planning to build a Salas v1.0)
Old 18th July 2012, 09:17 PM   #109
OK, plenty of BD140 TFK NOS
Which EI30? How many VA? 6 or 9V AC? Single or dual sec? gimme the specs you're looking for and I might help you.
Generally print Xfrms they are quite standardized and Era, Hann and Block, just to mention some good ones, are interchangeable.
Old 18th July 2012, 09:22 PM   #110
jean-paul's Avatar
The first revision takes about 50 to 70 mA depending on which oscillator you use. I am really curious if a shunt supply will improve matters as the onboard regs do most work. I guess it won't do much in this application but please keep me informed if it turns out to be a better solution. It would be different if there wouldn't be onboard regs but I strongly advise to keep those as the tracks to the points they feed are short and well decoupled. It would not surprise me if added wiring would be detrimental, I am pretty sure it will be. I use Salas shunt regs in the DCB1 so I know their quality. However this is a device that carries higher frequencies so I would advise to use a shunt supply just for the 5 V if you want to use one.
Measurements of an ES9023 DAC fitzfish Digital Line Level 66 27th May 2013 01:56 PM
Bragi, WM8804/ES9023 DAC Neutrality Digital Line Level 9 22nd September 2012 12:10 PM
ESS ES9023 DAC rvrazvan Digital Source 18 3rd August 2011 07:58 PM
WTB: ESS DAC ES9023 2A3SET Swap Meet 1 28th June 2011 03:02 PM
Copyright 1999-2017 diyAudio
