Go Back   Home > Forums > Source & Line > Digital Line Level
Old 18th November 2011, 08:12 PM   #1
Default how to combine 2 DAC channels? (mono with DSD1792)
I'm building a 3 way digital crossover. The DAC part is planned to be handled by two DSD1792 chips. So one of the stereo chips is only used half.
The datasheet says the SNR improves a few dB when operating in mono, so I could do that, but I don't know to connect the outputs in this case. Simply tie the current sources together?
My I/V stage is the textbook opamp circuit.
Thanks,
Jörg
Old 18th November 2011, 08:20 PM   #2
The answer to your question is contained in Fig.36 of the DSD1792 datasheet, page 33. That solution is for balanced output.
http://www.ti.com/lit/ds/symlink/dsd1792.pdf
For a very nice little single-ended output op-amp based solution, I suggest the circuit of Fig.30 in the AD1853 DAC datasheet, page 16. Don't forget to adjust the vaue of the I/V feedback resistors to account for the 4x greater output current of the DSD1792 over the AD1853.
http://www.analog.com/static/importe...ets/AD1853.pdf
Ken
Old 18th November 2011, 08:48 PM   #3
Single ended is required.
The TI circuit would need another differential amp to achieve that, versus the AD folks indeed connect the current outputs (I was rather joking when suggesting that).
I'm tempted to think a 3rd opamp in the chain is not gonna improve things?
Jörg
Old 18th November 2011, 10:00 PM   #4
If you use good OpAmps there is nothing to worry about. I would go on the route with 2 separated I/V converters and summing voltage circuits after that - just to keep with the TI schematic (fig 32). There are good reasons (related to internal design of the DAC) to separate the I/V stages and not to connect the outputs directly toghether.
Look on the schematic of Denon DVD-5910 for a proper stage for the DAC (PCM1792 is almost identical). You don't need to use exactly the same OpAmps... I would ditch the NJM2068 for LM4562. Even the OP275 I would try to replace it with LM4562 (slightly less slew rate but better noise and less distortion).
Old 18th November 2011, 11:02 PM   #5
Jörg
Also, take note that Analog Device's i/v circuit is referenced to the +2.78V AD1853 Vref, while I believe that for the DSD1792 the i/v circuit should be referenced to ground.
Ken
Old 19th November 2011, 05:19 PM   #6
Yes, I've seen that.
Thanks for the schematic excerpt. In front of the final adder is more filtering than I've planned for. The rest is similar. What's the sample rate there? I'll have 96 kHz, hopefully the filtering doesn't need to be so fancy.
In the one DAC I've modded so far (Musical Fidelity V-DAC) the results were good with LME49740 for I/V and OPA2134 for adder / line driver.
How to combine the left and right channels with out making everything mono? Boscoe Solid State 15 6th February 2011 03:16 AM
Combine 4 amplifier channels into one? thylantyr Solid State 5 4th March 2008 07:43 PM
Xtreme Noob - Summing Channels For Mono 3875 CarlosT Chip Amps 37 30th November 2006 12:36 AM
6 mono channels UCD180AD petervv Class D 1 19th December 2005 08:23 PM
who listened to DSD1792? vincent_brient Digital Source 8 9th March 2005 05:27 AM
Page generated in 0.11262 seconds (80.09% PHP - 19.91% MySQL) with 11 queries
