| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#41 |
Previously: Kuei Yang Wang
Location: Somewhere nice on planet earth where censorship of Ideas is frowned upon
#42 | |
ThorstenL explained very well. If you still want input buffer for your CS841x receiver, you will need DIY approach. Schematic can be found HERE. |
#43 |
diyAudio Moderator Emeritus
He does not have a CS8414 anymore, please reread the fist post/thread starter. It is about adapting the WM8805 PCB to the DAC board now AFAIK.
Won't you be excommunicated by the politburo at "the other side" for linking to their website ?
It's only audio Last edited by jean-paul; 15th November 2011 at 06:49 PM. |
#44 |
Yes, thank you, Jean-Paul.
I misunderstand he have malfunctioning WM8805 upgrade board and he is dissapointed. I assumed he want to switch back to CS8414 since he can not distinguish any remarkable sound improvements. Last edited by stormsonic; 15th November 2011 at 07:41 PM. |
#45 | |
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Looks to me the fastest way to acquaint myself with the WM8805 which over here is priced under $1.5 so really rather a bargain.
When a measure becomes a target, it ceases to be a good measure. C.A.E. Goodhart |
#46 |
Hello,
Thanks for all the suggestions. I purchased this PCB a few years ago and it was at the time the only PCM1704 PCB I could find. I selected the components and built this DAC while enjoying the learning experience and expected the circuit to not be perfect. At that time, all PCM1704 circuits I found were pretty much the same +/- few things. I appreciate all the input and will implement the buffer bypass and other suggestions shortly. I'm also looking forward for the Cen/Sen/Zen I/V (another thread). I might also test a TUBE output option as I have heard another similar dac with tubes and it sounded noticeably better. |
#47 |
Looking at the PCM1704 datasheet there are quite a few 4.7uf and 47uf capacitors. Therese are about 15mm away from the ICs right now. Should they be closer? What about the .1uf and 100uF bypass ? Should they be on the PCM1704 daughter board as close as possible?
Thanks, |
#48 | ||
And of course, they should present... Ciao T |
#49 |
Thanks,
Also noticed the TORX178 optical receiver output HIGH is at 4v, too high for the WM8805. I searched but did not find any info on TORX to WM8805 circuits. Seems that Torx178 was made in the times of TTL/CMOS crystal receivers. I'd like to keep an optical in for my video player (not that critical). What resistor(s) should I use to attenuate it? PS: After removing the Buffer Circuit the WM8805 is working correctly. I'm going for a comparison listening session soon and will report. ![]() Thanks for the help! |
#50 | |
Ciao T |
| FS: NOS Quad TDA1543 + CS8414 SPDIF DAC Board | pftrvlr | Swap Meet | 5 | 8th June 2010 12:00 AM |
| FS: NOS Quad TDA1543 + CS8414 SPDIF DAC Board | pftrvlr | Swap Meet | 3 | 20th April 2010 07:06 AM |
| FS: NOS Quad TDA1543 + CS8414 SPDIF DAC Board | pftrvlr | Swap Meet | 0 | 26th July 2009 08:28 PM |
| Micro Jacks and Micro Pins for board-board connection | jazzist | Parts | 1 | 12th May 2008 03:02 PM |
| Selling CS8414 to CS8412 converter board | spencer | Swap Meet | 8 | 1st May 2007 07:08 AM |
