Go Back   Home > Forums > Source & Line > Digital Line Level
Old 19th August 2012, 09:10 AM   #211
I don't think it can can have two xo freq because each freq requires different code in the register. But perhaps it is possible to re-write the register ? Seems like another added level of complexity that may not bring any benefit due to the way the pll works. But maybe not, if the register has to be changed to handle 192 ? Or is there simply a mode change to get 192 to work ?
One thing I remember reading is that the device is pre-configured for a 12Mhz xo and that this will work for 32-96 khz, but if I wanted anything else the device register has to be changed. So of course, this is why the ebay boards use 12mhz and probably explains why 192 doesn't work.
On that tack, wouldn't a 24.576mhz clock be the best choice for 192khz material ? It might be the only rate that gives N and r as 8, and thus, best performance ?
IIRC wm8805 won't do 176.4 ?
Old 19th August 2012, 10:48 AM   #212
Sure. Since we have a microcontroller on hand, make it work! Otherwise the microcontroller is not really doing much - just initialising the WM8805 with preconfigured settings at each power-up.
So the WM8805 should inform the uC of any change of samplerate, then the uC should change the XO if the new samplerate requires it.
There just remains the issue of how the WM8805 detects and reports incoming samplerate.
That's exactly what I was suggesting/asking in my earlier post.
According to the datasheet, the WM8805 definitely supports 176.4. The problem is that it cannot discern between 176.4 and 192 - this is worse than the previous situation I explained where the "REC_FREQ" flag does not differentiate between 44.1 and 48, 88.2 and 96 - those are simply how the chip outputs samplerate information. But in the case of 176.4 and 192 kHz, the chip literally cannot identify one from the other - see page 29 of the datasheet.
One solution is user intervention - I imagine you would need to have some form of LCD display connected to the controller, and be programmed to display something like:
"176.4/192 kHz
Please select
1. 176.4
2. 192"
Kludgey? Yes. But I don't see any other way. We're limited by the capabilities of the WM8805.
Old 19th August 2012, 10:56 AM   #213
Oh, I should mention that I'm not desperate for a dual-XO solution, myself.
My main interest in S/PDIF is for feeding audio (stereo, not multichannel) from DVD/Blu-Ray/media-decoders into a hifi.
This is all either 48 or 96 kHz - so a WM8805 with 24.576 XO will be fine for me.
I just imagine that others who want a high quality S/PDIF receiver would want optimised clocking for both 44.1 and 48 kHz samplerate families.
Old 19th August 2012, 02:25 PM   #214
let me throw this out there, just for grins:
how about using 2 receivers? a cirrus one (that works in hardware mode, perfectly) and the wolfson. one would be there to 'help' the cpu know what the real freq is. the other would actually pass traffic thru.
I have half of it working, kind of. an 8416 chip in hardware mode that locks onto ALL the samplerates. it gives me a word clock output and that is fully trustable. from that, I can run a software freq counter on the arduino and display (or at least know) the SR. this much work today. my code for that much is here:
Open-source USB interface: Audio Widget
note, that there are 2 conceptual ways to know the samplerate. there's what's on the wire (in terms of real word clock freq) and then there's what's in the payload of the data packets (there's a samplerate that the sender encodes in the bitstream and also a word depth, iirc). problem is, I believe those are not fully trustable. I have heard of bad transmitters who don't encode the right 'rate' in the data but the data still 'works'. it might be cool to have a tool that shows the real and sensed rates. but the real rate is the only one we need and care about to decode audio thru the wolfson.
the cirrus is supposed to have higher jiitter and be a lower quality part than the 8805 but I don't mind having it HELP the cpu get the bit rate correct. its not a super expensive part and does not take up too much space (its a lot bigger than the wolfson but at least its lead pitch is easier to solder, lol).
another idea I had: take the RAW spdif stream, divide it down and freq count it, with its data and clock NOT decoded. yes, the freq will 'wander' a bit but it will be close to something that we can ID as 44,48,88,96, etc. a freq to voltage converter can do a rough approx and the cpu (arduino) can do an a/d and get a general idea of what the rate is. certainly it would know what rates its NOT at (if it gets a very low freq, it can't be the 96-192 rates, etc). it might be an accelerator for the processor that way.
still, I like the 8416 idea in that it works and works well. no hackery needed, just get the word clock, freq-count it and you're done. you then KNOW, for sure, what rate you are at, on the wire.
then simply set the wolfson given the info we learned 'out of band'.
not sure that multiple xo's is the direction I'd go in. sounds expensive, more pcb routing hassle, more clocks 'in the vicinity' that I don't really want and this isn't a dac and should not need multiple xo's.
I don't fully understand all the implications of selecting clock freq's in software mode, though. so I'm not the one to comment on that, per se.
My Photostream:http://www.flickr.com/photos/linux-works/
Old 19th August 2012, 03:04 PM   #215
what I'm hoping to use this chip for (8804/5), is the switch 'fabric' in an i/o selector box. there has to be a cpu there anyway, and also an lcd, IR receiver and serial back-end for remote web control. the 8805 does not even have to select inputs, for me; I'm happy enough handling the pure switching outside the chip. I mostly wanted the chip as a reclocker. its advertised as such, isn't it?
and I do absolutely need to support every valid sample rate. I don't have a lot of each, in my collection, but there are actually files out there and people are going to want to -play- them and not convert them to play them.
I've sent every valid rate into the 8416 and its word clock locks on, well, every single time. I know it sounds funny to leverage one part like this, but hey, it -will- give you a very fast and trustable 'this is whats on the wire' Fs. no need to talk to it, either! you could, if you want; but what I have working now is a 2-step, where the 8416 runs in unattended hw mode, it just locks on, I sniff its wordclock with an arduino and that counts freq in software (part of its 'sketch'). you then know the currently playing song's Fs.
Old 19th August 2012, 05:54 PM   #216
here's what I'm using (or, was using, just as I paused this project several months ago) for a test bed.
I was not going to use i2c to talk to the wolfson. my plan was to go SPI and use opto couplers to level-convert and also fully isolate the arduino junk from the wolfson (junk). that's what the lite-on chip is on the perf. the other 8pin chip is an rs diff line driver so that I can send something like aes3 out of a rear jack (TRS). this is going to my behringer dcx2496 and so I wanted something closer to 5v than half a volt.
to put the wolfson into spi mode vs i2c mode, you have to init the chip and hijack some of its pins, then give them back to normal use. sigh. I hate that. but I think its easier to set the chip into spi mode and I'm all setup to do that, anyway.
I did actually find that arduino wm8805 code and I did convert it (enough) so that it fits inside my existing arduino infrastructure. but I didn't yet translate the i2c calls to my own spi calls. I think that's the last thing that I left off on, before I went and got side-tracked on a bunch of other things
Old 19th August 2012, 07:31 PM   #217
Tam Lin is offline Tam Lin  United States
There is nothing to gain using a fancy oscillator with a frequency that is a multiple of the expected sample rate. The bit and word clocks output by the WM880x are always synthesized to match the incoming S/PDIF sample rate.
I recently considered the Wolfson part for a DAC I am designing but rejected it because the DPLL must be reprogrammed to switch between 192K, 176.4K, and other sample rates when the chip is in software control mode. Instead I will use a CS8416 in slave mode. I have two XOs, one for each sample rate group, but only one will be powered-on at a time. A synchronous counter will provide all the DAC clocks and export a word clock to the PC. A micro will read the sample rate from the S/PDIF channel status and select the appropriate XO and divider.
Old 20th August 2012, 04:03 AM   #218
Hi guys,
Linuxfan - what will trigger the re-write ? Is there anything in the wm8805 that can be exploited so the re-write is done automatically ? I thought that the mcu only writes at start-up (I'm pretty sure that is what happens with these ebay boards), so we would have to disable the wm and then start it up again to write from a different mcu ? Have I missed something ?
Also, I'm pretty sure the PLL is not straightforward, so the ONLY frequency when R is an integer (8, the same as N, so K =0) is 192khz with a 24.576 xo. There's a table in the datasheet that gives suitable values for 22.5792 and 24.576 xo's. I remember looking at that and thinking that the best xo is not necessarily any particular freq, but simply the one with the lowest phase noise etc. If the cchd-957 was available in 12Mhz, I'd just go with that.
Anyway, I'm still undecided about this so I'd like to get some input from a programmer and/or someone with experience about this .... anyone ? Little help ? 2 xo's or one ? Which freq(s) or doesn't matter ?
For the 192/176.4 issue, well it looks to me like we need two options - auto select and manual select. When auto select doesn't work, we can just manually select any of the possible incoming freq from 32 - 192. Hopefully the manual select can be used as a trigger to re-write.
Linuxworks - I've made a great effort to avoid parts like the cs because of their high jitter. I would probably not be interested in any solution that adds jitter and then later tries to take it away, unless it can be shown that this is fully effective. What do you think ? Will using the cs degrade the spdif signal in any way ?
cheers
Old 20th August 2012, 06:31 AM   #219
the cs would not BE in the signal path! it would be there as a flagman, just saying how fast the traffic is moving. as a clue to the cpu, who would then know what speed to set the wolfson at.
in short, a control element, not in the audio path in the least.
Old 20th August 2012, 06:36 AM   #220
if you have to resort to manual select, it seems like an admission of failure
has anyone contacted wolfson and found out how its -supposed- to work? I have not done that yet but I would not be shy in doing so once I've run out of ideas.
my first idea was to examine the ebay board and watch what it does. sadly, it seems it 'punts' and does not support all the rates, anyway. studying it won't help me at all, I don't think.
I still have not dived deep enough into the specs, but I wonder - would a strategy be to scan between the 'confused' rates (if you can't tell between A and B, at least you know its one of those 2 and not any other) and watch for errors? one would be swamped with errors and the other would not. no?
FS: NOS Quad TDA1543 + CS8414 SPDIF DAC Board pftrvlr Swap Meet 5 8th June 2010 12:00 AM
FS: NOS Quad TDA1543 + CS8414 SPDIF DAC Board pftrvlr Swap Meet 3 20th April 2010 07:06 AM
FS: NOS Quad TDA1543 + CS8414 SPDIF DAC Board pftrvlr Swap Meet 0 26th July 2009 08:28 PM
Micro Jacks and Micro Pins for board-board connection jazzist Parts 1 12th May 2008 03:02 PM
Selling CS8414 to CS8412 converter board spencer Swap Meet 8 1st May 2007 07:08 AM
Copyright ©1999-2013 diyAudio
