WM8805 upgrade board (cs8414 pins) - dissapointed
Old 13th November 2011, 12:15 AM   #11
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Raindrop_hui I think is the name of the seller - she lives in Shandong province. The designer/builder though is just a stone's throw from me, halfway to Shanghai. 'Hui' has many meanings in Chinese, the only meaning I know about is 'know' as in 'I know how to speak Chinese' (which I don't ).
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 13th November 2011, 01:45 AM   #12
mfrimu is offline mfrimu
Grounding is an interresting subject. On my dac-38 digital ground is connected to analog ground in one signgle location via a ferrite jumper.
What's the best ground philisophy on a dac?
Old 13th November 2011, 01:58 AM   #13
SoNic_real_one is offline SoNic_real_one  United States
Originally Posted by jean-paul View Post
Hi, WM8805 needs a 12 MHz clock for operation which includes dejittering the incoming signal.
Can you show EXACTLY where it is stated that that clock helps "dejittering"?
Because the data sheet says that PLL loop is used to extract the sample rate and the output frequency will follow the input one. There is no mentioning of any "dejittering".
The crystal just provides the free-running frequency of the PLL loop and also helps detecting the value of the incoming samplerate and signaling it further.
There should be no ferrite bead between the grounds. Grounds are tied toghether INSIDE the DAC anyway. Only beads on positive rails makes a difference.
Old 13th November 2011, 06:38 AM   #14
abraxalito's Avatar
I wonder why they used a ferrite bead for that connection? I presume the digital and analog supplies come from separate windings on the mains trafo? If so then there's at least one loop for RF via the interwinding capacitance of the transformer.
Same as the best grounding philosophy for an amp, pre or whatever. Rigorous star grounding to ensure (especially) that no digital, switching supply-related or mains hash currents get superimposed on the analog audio outs.
<edit> @Pano - I remembered after writing the earlier post that one of the other meanings of 'hui' in Chinese is 'community' - so perhaps Chinese and Hawaiian aren't so far apart after all.
Old 13th November 2011, 06:49 AM   #15
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
OK, it is the internet age and OK data sheets are sometimes hard to read but in this case: first page of the data sheet, first sentences under "description". Not info I "heard", "thought", "assumed" or "googled" . No, just reading the data sheet as we all did once before we made any statements. Contrary to other chips and old knowledge this one is quite sensitive on the quality of the used 12 MHz clock despite its PLL. Best is to use a low jitter XO and not simply a crystal.
While you are at it please check the whole data sheet and see why this chip is ahead of its competitors. Also the standard schematic works quite good. Using even less parts than in the standard schematic will not guarantee the features as described.
I don't work for Wolfson or something like that. It is just that they designed a very good chip which easily outperforms all other SPDIF receivers made till now that I know of.
It's only audio. Member of the non modular PCB design committee
Old 13th November 2011, 08:54 AM   #16
ThorstenL is offline ThorstenL  Germany
Previously: Kuei Yang Wang
It looks like the circuit does not use the crystal option on the wm8805, maybe that would improove performance?
The WM8805 CANNOT work without a crytsal or clock somewhere. This clock is critical in terms of PSU noise.
Also my Dac has a 'buffer' on the spdif input, not sure that would affect negatively the wm8805.
Yes, it will. The inputs on the 8805 expects SPDIF levels, you need to switch it (in software) to CMOS levels if you want to feed these.
Further, looking at your DAC, I am unsurprised that there is no appreciable improvement, given the design as it is.
One of the main "on board" jitter generators (the digital filter) is not addressed by re-clocking and many of circuit choices are extremely dubious, including the apparent lack of any competent HF decoupling for digital circuitry. To me this DAC appears like a ruddy waste of a rather decent chipset.
Ciao T
Old 13th November 2011, 10:56 AM   #17
If you would read PAST the first page (that page is just a advertisement of the product), you will found out when output is PLL derived (always in receiver mode), wgen is derived from a digital interface incoming clock (transmitter mode) and when is purelly Xtal derived (never).
Is like I quoted above - from page 21: "whenever the SPDIF receiver is ENABLED, it generates the clock for the PLL".
So, in the RECEIVEING mode, the output is tied to the input via PLL. It cannot work otherway.
When is used as a TRANSMITTER, then it requires an external source for clock reference (from the digital audio source).
NOWHERE on the rest of the data sheet is explained how that "dejittering" is done. Or if.
PS: They even give the same 50pS jitter as DIR9001. So they are better only compared with CS receivers (at 200pS).
Old 13th November 2011, 12:34 PM   #18
Actually, reading the WHOLE datasheet and understanding it would reveal that the clock is ALWAYS PLL derived when the WM8805 is clock master and that the PLL is a DPLL that uses the WM8805 Clock, this holds true for SPDIF receiver mode, transmitter mode and pass-trough mode.
In receiver mode the programming of the DPLL's output is controlled by the SPDIF receiver through a control logic that is derived from a FIFO buffer's fill state via a DSP lowpass filter which stands at 100Hz once locked, while in transmitter mode it is controlled in software.
In transmitter mode you CAN run the system on external clocks only, assuming your clock generator is much better than what is inside the WM8805.
As for the 50ps, a programmable clock using a DPLL has limits, as it synchronises a RC oscillator derived clock with the external reference clock by using a fractional divider. The 50ps are for typical applications.
The WM8805 has the PLL Clocks supply pins separately available so any noise here can be minimised by appropriate design and the reference clock can be supplied by a oscillator with arbitrary low jitter, so practical implementations can measure much worse than the 50pS jitter, it is also possible to do quite a bit better.
Secondly, the XXXpS specified for all receivers assume a source without jitter. Real sources easily clock in at several nanoseconds jitter, so much more crucial is the rejection of baseband jitter... As long as the jitter is of a level and frequency that can be rejected by the receiver and the design is competent, the specified jitter will be reached, if the jitter is of a frequency and level that cannot be filtered completely jitter will be increased over specification.
That said, given that ALL other receivers on the market have their source jitter rejection turnover at 10KHz or higher one could say that the WM880X is 100 times better than anything on the market.
Still, it is possible to do much better than the WM880X does, with respect to jitter, however it does need quite complex solution and fairly large amounts of memory.
My biggest dislike for the WM8805 is that it's external control interface to any MCU is extremely riddled with "undocumented features" (unlike the AKM Parts) and that 176.4KHz operation is unavailable in "standalone mode" (unlike the AKM Parts), so you MUST use an MCU no matter what.
Another gripe of mine is that it lacks a provision of "sideport" memory which would allow the corner frequency of the source jitter rejection to be lowered from 100Hz to 10z or even below 1Hz.
With AKM parts (and others) other solutions are needed to reject source jitter sufficiently of course.
The Cirrus Logic Parts tend to have so many bugs early on in their lifecyle, they are best avoided in self defence and TI/BB's receivers seem to do at least as bad...
Ciao T
Old 13th November 2011, 01:50 PM   #19
@ThorstenL:
Correct. Some people tend to attribute "magic" powers to pices of silicon just based on their guesses, instead of really reading the datasheets. They see that Xtal and they ASSUME that the output will have that Xtall stability. That's what WM wanted for them to belive too, that's why that wrote that first page like that.
As for the FIFO buffer inside the WM8805 - I think that is not present. They have that white paper that seems to indicate that, but that's it. Inside the 8805 there is no mention of a FIFO buffer. And surelly not one that can handle 20 ms of audio data (at 24bit/192kHz) needed for what they claim to do (100Hz corner).
It is just about using a lower-pass filter PLL. And that works great with good sources (but any receiver will work well then), but can lead to some frequency-following distortions for a source with higher jitter.
Old 13th November 2011, 02:36 PM   #20
Well, whatever is in there does appear to work in practice like what they claim (according to AP Sys 2722).
Also, you do not need 20mS buffer for 100Hz corner for jitter rejection at several UI (or nanoseconds) worth of jitter, you would be surprised how short such a buffer could really be to get this result.
The problem is of course, you cannot actually do that. As Cirrus logic found out in their CS8416 when it had around 10 times of the jitter of the earlier parts, it does not work as you might think it does.
Ciao T
WM8805 upgrade board (cs8414 pins) - dissapointedHide this!Advertise here!
Micro Jacks and Micro Pins for board-board connection jazzist Parts 2 25th July 2016 07:04 PM
FS: NOS Quad TDA1543 + CS8414 SPDIF DAC Board pftrvlr Swap Meet 5 8th June 2010 12:00 AM
FS: NOS Quad TDA1543 + CS8414 SPDIF DAC Board pftrvlr Swap Meet 3 20th April 2010 07:06 AM
FS: NOS Quad TDA1543 + CS8414 SPDIF DAC Board pftrvlr Swap Meet 0 26th July 2009 08:28 PM
Selling CS8414 to CS8412 converter board spencer Swap Meet 8 1st May 2007 07:08 AM
