Go Back   Home > Forums > Source & Line > Digital Line Level
Old 6th November 2011, 12:55 AM   #21
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
Originally Posted by counter culture View Post
You need it all to be built to run synchronously with adequately low jitter. The LPC1343 board is an unknown quantity in terms of jitter, it might introduce a requirement for reclocking.
It may be unknown to you but its not to me. Jitter's noticeable (measurable) but not a problem with this chip or I'd not have recommended it.
When a measure becomes a target, it ceases to be a good measure. C.A.E. Goodhart
Old 6th November 2011, 02:20 AM   #22
Everything for a digital input and cheap. Only fly in the ointment is the power pad package, but I think it'll go OK in my toaster oven.
I placed large hole on the bottom of TAS5706, then soldered from back of the board.
Yes this chip accepts I2S and drives speaker. great.
Please care for the power supply.
Old 6th November 2011, 11:34 AM   #23
Sounds cool!
What I've understand, this TAS5518 needs external clock?
And how do i implement the Biquad filter coefficients to the TAS5518?
I guess I need separate AD converters to the inputs of the TAS5518 SDIN's?
Old 6th November 2011, 02:57 PM   #24
TAS5706: single chip, 2 speakers. no aditional clock.
TAS5518: PWM controller, up to 8 speakers, requires separated Driver IC, external 50MHz.
Biquad parameter: https://sites.google.com/site/koonau...8-full-digital
on the bottom you can find C source code to calculate LPF/HPF Biquad parameter.
I understand this thread is for Active Speaker, if the speaker has Digital In and Analog In, the speaker will have CS8416 for SPDIF receiver / ADC for Analog In / switch and data selector like 74HC157.
Old 6th November 2011, 08:49 PM   #25
Good stuff! Is your program also compatible with TAS3108 (can program it using I2C), I think it's got the same DSP core inside?
I'd like to design a PCB for the Crystal S/PDIF receiver (CS8416, or rather a sample rate converter chip to avoid S/PDIF jitter to go all the way to the converters) and TAS3108 using Asus Xonar H6 (http://www.asus.fi/Multimedia/Audio_Cards/Xonar_H6/) as analog output board.
Old 6th November 2011, 09:29 PM   #26
mhelin,
TAS3108 looks like generic DSP, combined with TI's software?
"The devices use an efficient, custom, multi-instruction programming environment optimized for digital audio processing algorithms."
PurePath Studio Graphical Development Environment (GDE)
I saw TAS3103, it has configurable Biquad filters.
Setting procedure should be very different from TAS5706/TAS5518, but calculation for Biquad will be the same issue.
Old 6th November 2011, 11:38 PM   #27
Now you say.
Old 7th November 2011, 09:53 AM   #28
I don't know if I've get it right but, do I use a evaluation board to implement the filter coefficients to the TAS3108?
Is it some sort of connection on the evaluation board where I attach my TAS3108?
Old 7th November 2011, 11:50 AM   #29
Boden is offline Boden  Netherlands
Dear All,
It seems you are all talking hardware now.
The real problem lies in proper programming software for whatever platform you are using. Standard filter curves will not produce acceptable results, since the invidual SPL characteristics of the drivers-in-box have to be taken into consideration, and therefore must be measured first. Then the measurement results must be imported into the software.
Finally, filter+acoustic raw driver output must be calculated such that a chosen target. e.g. 4th order LR output is produced acoustically, not electrically.
Only a handfull of software packages can do both DSP programming and filter optimization, but SoundEasy, LSP CAD 6.1.and LEAP can. To my best of knowledge, the standard Behringer DCX 2496 software cannot do this, thus producing acoustically undesired results.
Eelco
PC based digital crossover with dolby digital live preiter PC Based 64 25th April 2012 08:14 PM
OEM Digital Crossover now Available to Diy Market Daytona50 Swap Meet 16 16th January 2009 11:45 PM
Progress report - digital crossover as a DAC - digital all the way to the amps Ken L Multi-Way 0 26th November 2006 11:42 PM
digital crossover w/digital output? ezkcdude Multi-Way 30 3rd August 2006 01:01 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
