| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
Hello, first I'm new here and my english is bad..
But my problem : I built D/A converter with CS8416+AD183. Alfter started problem, he's functionally now, sound is very nice. But he produces noise, left chanel more. I don't know whats wrong. I did double layer PCB, separate analog and digital ground. I have suspicion to power supply. I've used to digital power LM317 to 3,3 and 5V, ADP 3303-3,3 to 3,3V (low noise linear regulator form Analog devices) and for analog power the same ADP3303-05 for 5V. For output filter & buffers simply 7815/7915. Everywhere is quallity blocking cap. What's wrong ? DAC plays nice, but the noise spoils him
#2 |
线路板上的R15应该在AD1853#28PIN附近接+5V DIG.. 而且所有IC每一个供电PIN应该有10UF或更大的退藕电容.. CS8416和AD1853的+5V DIG用磁珠电感隔离一下..AD1853的AGND与DGND要相连..
SL2插座增加一个AGND连接LPF的GND.. Last edited by kimk; 29th October 2011 at 10:33 AM. |
#3 |
I try it, without change. It's still noisy :/
#4 |
Or, remove R1, then the CS8416 # 14PIN_NV/RERR directly connected to AD1853 # 23PIN_MUTE as squelch function use ..
其实,我不确定CS8416的NV/RERR是否是用来显示接收信号错误的功能,如果是,这个或许能做前面提到的那个静噪接法.. 如果还没有用,或者你描述一下噪音是如何的..? Last edited by kimk; 29th October 2011 at 08:16 PM. |
#5 |
抱歉楼主!
CS8416 # 14PIN_NV/RERR似乎只是S/PDIF专业应用部分AES3的版权检测控制输入端.. |
#6 |
new knowledge. I tried to disconnect all power supplies besides Analog 5V. No changes - still noisy
Is it possible AD1853 is demaged ?
#7 |
可能是I/V,LPF引起的?
#8 |
sorry, i don't know what do you mean I/V LPF. I must use google translator..Can you please write in English, please ?
#9 |
I / V is the current and voltage transformation, LPF is a low-pass filter ..
AD1853 analog output signal is current, you need to transform the voltage.. |
#10 |
yes, i used output buffers and LP filters from recommended circuit from datasheet AD1853. Outputs filt. + buff. without input signal are noise-free.
| Hifimediy DAA1853 DAC - AD1853/CS8416/OPA2134 | zog666 | Digital Line Level | 48 | 2nd April 2012 02:48 PM |
| Need help about AD1853 DAC. | shyliang | Digital Source | 7 | 13th July 2007 08:46 AM |
| It's my AD1853 DAC | Kochkurov Maxim | Digital Source | 8 | 13th July 2006 03:03 PM |
| Page generated in 0.08539 seconds (86.46% PHP - 13.54% MySQL) with 11 queries |
