math behind logarithmic volume control?
Old 18th October 2011, 03:33 PM   #1
sddiy is offline sddiy  United States
Exclamation math behind logarithmic volume control?
First, I am a software guy and know little to nothing about audio. I was tasked with converting a linear volume scale to a logarithmic one on an existing system. I'm not sure this is the right place to ask this, so please point me in the right direction if it is not.
As an overview, my software runs in a DSP, which sends a 16 bit value to a DAC. From my understanding, the DAC converts it to voltage and that goes to an amplifier and then that goes to a speaker.
The volume control is just a multiplier to the 16 bit value. There are 9 volume levels which correspond to a table lockup of 9 multipliers. The values go from 0 to 1, in increments of .125. That is the linear volume scale. I need to make this into a logarithmic volume lockup table. Does that make sense? What equation do I need to use?
From just asking and research, the following are my guesses. I think I want to relate voltage to dbA (sound pressure level). But I don't know how to do that.
Old 18th October 2011, 06:54 PM   #2
lcsaszar is online now lcsaszar  Hungary
In a logarithmic scale you need to define the step value. Common is 3 dB, which is a clearly audible volume difference. The problem is that the range between the lowest and highest volume will be only 30 dB if you use 10 steps. This is not sufficient for audio volume control in general, you need at least 60 dB and a bit finer resolution (1.5 or 2 dB). That means 30 to 40 steps. 1 dB = 20 * log (V2/V1). You can do it in the digital domain, but you will lose the 16 bit resolution at low volume level. (BTW shifting the 16-bit word to the left yields 6 dB attenuation). Better do do it in 24 or 32 bit arithmetic, and then truncate to 16 bit.
Old 18th October 2011, 07:23 PM   #3
DF96 is offline DF96  England
For a rough approximation to a log scale, use 1000, 0110, 0100, 0011, 0010 etc. as multipliers. This gives alternate steps of 3.52 dB and 2.50dB, which are close enough to 3dB and have the advantage that multiplication will be quick - just a shift, or two shifts and an add.
Old 18th October 2011, 07:43 PM   #4
I think we would use 6db steps. The audio we produce is alarms for equipment, so it doesn't need to be that great of resolution. In fact, I think once the volume is set, it probably is never looked at again. So at 6 db, 9 steps would be 54 db range. I think we go up to about 80 dbA. So I would make step 0 be 0 db and step1 be ~32 db and then go 6db every other step.
It sounds like left shifting is nearly what I want. But I want a look-up table, not an algorithm. How do I make a look-up table that does the same thing as a left shift?
Old 18th October 2011, 08:01 PM   #5
I think I didn't give enough information in the OP. The original 16 bit number i start with is already at full volume. The look-up table decreases the volume by multiplying times a fraction. So I don't think left shift or multiplying works in my case I need to divide or right shift?
So will my table will look like { 0, 1/128,1/64, 1/32,1/16,1/8,1/4,1/2,1}???
But that doesn't make sense to me since the last two steps since too great a difference. The current table has .5 as the 4th step. ({0,.125,.25,.375,.5, .625, .75, .875, 1})
Old 18th October 2011, 09:15 PM   #6
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Here's a table worked out for the Goldpoint Attenuator:
Old 18th October 2011, 09:18 PM   #7
nightuser is offline nightuser  Russian Federation
May i help? :-)
First, calculate lookup table in MS Excel. 1 dB step is overkill, 3 dB is not accurate. For power(!) dB = 10*lg(P1/P0). As i understand, P1/P0 (or, may be U1/U0) is equal to volume control register content. Try 1 dB step, at minus 60 dB disable DAC output (MUTE function).
Old 18th October 2011, 09:21 PM   #8
simon7000 is offline simon7000  United States
The standard 10 position attenuator uses 3 db steps except for the last three which are 6, 6 and off. A normal carbon control has 45 db range then essentially off.
So values of 1, .707, .5, .35, .25, .18, .9, .045. 0, would give you smooth sounding values from full on to off.
Old 18th October 2011, 09:30 PM   #9
counter culture is offline counter culture  United States
According to some authorities, 10dB represents a halving or doubling of perceived volume.
I would think 6dB would be a not unreasonable step.
Left or right shift is a question of bigendian or littleendian, regardless you would want to divide by 1, 2, 4, 8, 16, 32, 64, 128. This will still leave you with a reasonable number out of 16 bits.
This isn't something with an absolute hard-and-fast solution, so you can just pull the numbers out of your imagination, try the effect, and tweak the table if you don't like the result.
You could do worse than look at the Dallas/Maxim linear -> log digipot appnote, AN3996. Although it is specifically about digipots, it's a mathematical treatment of a related subject.
Old 18th October 2011, 09:58 PM   #10
I gave you values for approx 3db per step - you can zero pad at either end as necessary. For 6db per step it is even easier: 1000, 0100, 0010, 0001, 0000. Just multiply the number by the relevant entry from the table.
I'm not sure what is puzzling you. As a software guy I assume you can think in binary? When I wrote code I had to think in octal and hexadecimal too.
math behind logarithmic volume control?Hide this!Advertise here!
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 07:20 PM
Remote control Passive Volume Control with Display ua100k Swap Meet 2 31st May 2011 03:01 PM
Replacing broken volume control with digital volume control Gunawan W Solid State 19 15th December 2010 10:46 AM
i need preamp schematics w/o tone control or volume control hernanstafe Parts 7 30th January 2008 03:12 AM
remote control motorised control for volume pot/knob CharlesY Parts 0 25th July 2005 11:12 AM
