| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
I am in the process of constructing the best "bang for the buck" computer-based audio system for my dorm room. I have purchased and installed the following:
-Crown Comtech 400 with PIP-AP input card -2 25 ft XLR cables, 100 ft of 14 and 16 guage speaker wire (14 to the LR speakers and 16 to the subwoofer) -X-fi Titanium -Jamo 250 Subwoofer -Pioneer BS41-LR speakers When I got everything installed, I was disappointed to find that the sound from this system was still sub-par. Bass was booming and not well-controlled, mids were muffled, and highs weren't apparent. In order to troubleshoot, I tested out my friend's FIIO 7 Dac and I was floored by the difference in sound quality. It's hard to describe, but everything sounded much crisper through this $80 DAC. Since this small DAC made such a big difference in audio quality, I could only estimate that I'd see a much bigger booster with a better DAC. What type of DAC should I be looking for? Should I build an Ebay DAC kit? I'm trying to find something with a SNR of 105 db or greater and a THD of .05% or less (something that will exceed my amplifier in specs). I was looking at the Musical Fidelity V-DAC, however at $250, it is a big step up from my friends's $80 DAC in price. Thanks |
#2 |
heh - I use a Fiio d3, and find it to be superb, and without things you dont want - such as a volume control for headphones.
For $30 or so, its worth a try and could solve your problem. In my system, it virtually completely eliminates the hiss that was present when using mobo onboard sound or from a 5.1 DSP. In fact, unless the volume is at ear shattering levels, the speakers are completely silent. |
#3 |
Sometimes a square peg fits a round hole just fine
those 25' xlr cables probably arent helping, if they arent very low capacitance you could be losing quite a bit of bandwidth there.
i'd be waiting till after rmaf, wyred4sound have a few small dac products that sound interesting they will be launching there; in the meantime check out the ackodac aku23 async usb dac kits |
#4 |
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Tight bass is unlikely to happen with 100ft of speaker cables. You'll want the amps much closer to the speakers. Highs might start rolling off too with so much series inductance and skin effect losses.
I think ideas are what you want to get rid of. I don't really like songs with ideas. - Leonard Cohen Last edited by abraxalito; 7th October 2011 at 03:12 AM. |
#5 |
Hey, thanks for the responses.
I hooked the bb input pip card (bare leads) to my amplifier and ran regular speaker cables back to my computer. I immediately noticed an improvement in sound quality even though the cables that I ran were each 20 feet long. The problem is that I would ideally like to have my amp in my closet (which is situated diagonally across my room from my computer... about 20 feet). If you guys think that I should move my amp closer, I guess that I could place it under my bed so that my speakers would only be about 5-8 feet away. Currently, each speaker is 25 feet of speaker cable away. I didn't think that this would be necessary since this particular amp is designed for installations in large rooms lol. Do you think that it would be worth moving it much closer to my computer? I also followed DJK's suggestion in one of my previous topics and installed a 22uf capacitor in parallel with each of the large 6300uf capacitors in the amplifier and bass was MUCH tighter after doing so. I checked out Ackodac and it looks interesting, however I might look into installing a new OPAMP on my sound card first. The current one is only capable of a 3v/ms slew rate! O.o Last edited by techbiker; 7th October 2011 at 04:31 AM. |
#6 |
The thing to do is trust your ears - move the amps temporarily and find out if you can hear the difference between 5ft and 25ft of cables. If you can't, then you're fine.
Longer balanced interconnects are not a problem for sound quality - after all check out any recording venue where there are microphone wires going everywhere. Mic signals are much smaller than line level, so if long balanced cables gave any sound quality problem, we'd all be hearing it on recordings.
I think ideas are what you want to get rid of. I don't really like songs with ideas. - Leonard Cohen |
#7 | |
#8 |
Ah good point - unbalanced cables pick up more interference the longer they are because they introduce loops into the audio path. The screen (which picks up the interference) is also doing double duty as a signal carrier. Result - interference mixed in with signal. I would not worry at all about 90dB SNR, that's pretty good - better than the hiss level on many CDs.
#9 |
Having descriptions in addition to product names would help understand your situation. What is all of that stuff?
I think by X-Fi you might mean a cheap internal sound card. Upgrading to most external sound card might help, as there's a lot of stray RF inside a computer case, especially those with lots of fans. Firewire cards are generally superior to USB. |
#10 | |
The Comtech 400 is my amplifer (250 watts per channel). The speakers are Pioneer BS41-LR's with 5.25 woofers and 1 inch tweeters (these have gotten excellent reviews online). Finally, the pip-ap is a modular input card that can be installed in a Crown amplifier. I swapped it out for a BB pip card (an input card that accepts bare leads). Thanks |
| My Perfect DAC | jordo81 | Digital Line Level | 3 | 9th August 2011 11:01 PM |
| F/S PS Audio Perfect Wave DAC and Transport | rubicon | Swap Meet | 0 | 28th December 2010 05:21 PM |
| USB tube DAC£¬High-quality£¬Perfect design | Jacky Ling | Vendor's Bazaar | 12 | 8th August 2009 08:44 AM |
| Near perfect accuracy 16bit DAC idea | Bernhard | Digital Source | 26 | 3rd November 2006 05:35 AM |
| Lost finding perfect oscillator for my DAC | OliverD | Digital Source | 6 | 1st December 2002 09:07 AM |
| Page generated in 0.13187 seconds (83.03% PHP - 16.97% MySQL) with 10 queries |
