Go Back   Home > Forums > Source & Line > Digital Line Level
Old 2nd February 2012, 10:07 PM   #81
beau2317's Avatar
You could use something like that. I just built a simple thing from a transformer, bridge rectifier and capacitors. DIY is the name of the game
Moskido (Hybrid Aikido/Mosfet); Verumecce (biased interconnects). Buffalo III with Unbalancer tube output; Magnepan 3.6R
Old 2nd February 2012, 10:23 PM   #82
dirkwright's Avatar
Originally Posted by qusp View Post
i would use a couple of common gate mosfets in place of the transformer for coupling the tubes in order to present a lower impedance to the dac. i suppose the same could be said for certain transformers vs tubes? tubes are pretty alien to me so just a hunch.
beau, what cathode/IV resistor value did you end up going with?
@ gillib: are you planning to do an 8 channel tube output stage with the AKD18P? if so, wow thats gonna need a chassis and a half
If he has his heart set on tubes he can use a pair of ground grid tubes directly driving a pair of white followers. I can scan in a sketch... maybe.
Old 8th February 2012, 09:28 AM   #83
gillib is offline gillib  Austria
Now my DAC is finished. I changed some values at the first tube.
Ra is now 50kOhm, Rs for LM334 is 15 Ohm.
The sound is amazing.
Here are some pictures:
Thanks to Acko, Lorien, Paul Hynes and the great work of Allen Wright (posthumous).
regards
Bruno
Old 8th February 2012, 10:18 AM   #84
beau2317's Avatar
Cool. It always strikes me as kinda funny that there's all this supporting circuitry, and this tiny little DAC chip in the middle, doing most of the work.
Did you have the same DAC with a solid state output stage before? If so, how would you compare the tube version to the SS ?
Old 8th February 2012, 10:33 AM   #85
No, i did not try a solid state output, I enjoy tubes.
Bruno
Old 8th February 2012, 12:11 PM   #86
tmas is offline tmas  United States
Gillib,
What tube output stage did you use here?
Old 8th February 2012, 10:46 PM   #87
beau2317's Avatar
I understand it was an Unbalancer as I described in this thread, but he used different tubes - ECC802 and ECC99
Actually gillib, I tried ECC99 and it sounds pretty good, but found the 6H30-pi a bit better. But they are a lot more expensive.
Old 9th February 2012, 07:26 AM   #88
@tmas At the moment I use ECC802 and ECC99. I followed Mr. Browskie's article:
The Unbalancer
I will give the 6H30p a try.
But I think the most important part of the tube stage is the HV Super Regulator (http://www.vacuumstate.com)
You can find the cicuit in 'The Tube Preamp CookBook' http://www.vacuumstate.com/index.tpl...907.3461467244
Old 9th February 2012, 07:31 AM   #89
beau2317's Avatar
Note that the heaters are different on the 6h30. Also they take more current. But I found that the cathode resistors can be the same.
Old 9th February 2012, 07:41 AM   #90
The Unbalancer
But I think the most important part of the tube stage should be the HV Super Regulator
You can find the circuit in the The Tube Preamp CookBook.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
kvardas
Dual I/V stage implementation for Buffalo II & III pinnocchio Analog Line Level 19 16th October 2011 01:18 AM
Implementing Dual I/V for Buffalo II/III - Legato/IVY + Tube I/V pinnocchio Digital Line Level 2 7th September 2011 07:27 PM
FS:Buffalo DAC II with tube output stage Nikola Krivorov Swap Meet 2 12th February 2011 06:08 PM
Tube output stage for Buffalo Saber 32-bit DAC? Curly Woods Tubes / Valves 0 23rd July 2009 02:18 PM
Tube output stage for DAC ackcheng Tubes / Valves 10 14th January 2004 12:13 PM
Page generated in 0.07981 seconds (84.02% PHP - 15.98% MySQL) with 11 queries
