ESS9018 - try new, try more...
Old 14th November 2011, 01:46 PM   #121
Bunpei is offline Bunpei  Japan
As jcarr said, the vertical axis of the graph is the "phase angle" (theta, θ)
between voltage and current. You can measure the value easily using a LCR meter.
A group of advanced audiophiles in my hometown region is recently establishing such an empirical rule that "a capacitor that has a good phase vs. frequency plot yields a good sonic effect both on decoupling and coupling purposes in terms of unclouded sound."
In this context, "a good phase plot" means;
1. Fluctuation of phase value is small
2. No large phase value change appears in audio frequency range
Even if you feel anything doubtful on my report, I will not ram the capacitor or the empirical rule into your throat.(The capacitor is too large to swallow down, actually.) You have your thoughts and your ways.
I have one thing to make it clear. I have not removed any capacitors originally on board on the Buffalo II main board. A set of ceramic capacitors remains there.
Old 14th November 2011, 02:17 PM   #122
Coris is offline Coris  Norway
Coris's Avatar
I do not doubt your report and I do not feel like so... I`m just thinking and trying to find out why so an so... Explanations... That`s all.
By the way, thanks for your explanations.
Old 15th November 2011, 09:36 AM   #123
staccatiss is offline staccatiss  Germany
Bunpei, if I have offended you, I apologise.
Maybe I was too harsh in my comments. Having been in the electronic industry for many years and now being in the academic "world" have made me a bit skeptical when I see such a flat line among other "normal" curves.
Best regards,
S.
Old 16th November 2011, 02:35 PM   #124
Dear Coris and staccatiss,
Please do not be worry so much. I don't mind.
Even if the effect of the capacitors are out of your orthodox theory, I'd like to recommend you try those.
By the way, as staccatiss reported his comment on TPA transformer I/V thread, I think synchronous MCLK feed is very effective either.
Coris, why don't you try that method in your system?
Old 16th November 2011, 02:54 PM   #125
Coris's Avatar
Hi Bunpei
You know, I didn`t succeed yet to put together my Buffalo system... so, that because I didn`t tried yet the synchronous clock. My actually system do not permit me this, or all is too complicated. I will try it... as soon as I would have the possibility.
Old 27th November 2011, 04:19 PM   #126
I have tried a collective set of ceramic capacitors ( 100 microF x 10 ) at last.
Its sonic impression I felt was "clear". However, among Sanyo OS-CON, Panasonic electrolytic capacitor, a collective set of Tantalum capacitors, CDE film capacitor and a collective set of ceramic capacitors, I like the giant film capacitor manufactured by Cornell Dubilier Electronics best. (Naturally, each type has each characteristic.)
Old 27th November 2011, 10:51 PM   #127
Coris's Avatar
Thanks for your feedback! Good to know that are different sonic results in this case.
In the last time I found out about something interesting... Is about I/V & final stage (stereo) for ESS9018. I will search a little bit more before publish something.
Do you use in your system TPA I/V & final stage, or something else? For moment I use/run my own one...
Old 27th November 2011, 11:05 PM   #128
NicMac is offline NicMac  Italy
NicMac's Avatar
Please share
Old 28th November 2011, 04:12 PM   #129
... Do you use in your system TPA I/V & final stage, or something else? ...
As I favor a minimalist approach, I use no I/V stage. My way of monitoring is connecting a tweaked Etymotic Research ER-4S earphones to a balanced analog output of Buffalo II or Buffalo III board. Each earphone drivers is said to have 5 ohm impedance and a variable resister is inserted in serial. I believe no visible coupling capacitors are in the signal path. Therefore, I think I can monitor a raw characteristic of the DAC chip. (One exception is possible effects of the variable resister.)
Old 28th November 2011, 04:23 PM   #130
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
...and a highly inductive/reactive load (headphone coils).
ESS9018 - try new, try more...Hide this!Advertise here!
Copyright ©1999-2017 diyAudio
