Go Back   Home > Forums > Source & Line > Digital Line Level
Old 12th September 2011, 04:32 AM   #1
Default Novice DAC Repair help
Hi, so I'm pretty new to this whole diy thing and I need help identifying a part to be replaced. I started working on a Perpetual Technologies P-3A DAC to replace a few parts. I've identified a part that needs to be replaced, I just don't know what type of part it is (I'm really new to this subject) or where I can order it. I was hoping one of you could let me know what part this is. Maybe you could even tell me what part number it was. Any help would be greatly appreciated.
Old 12th September 2011, 05:25 AM   #2
Greg Erskine's Avatar
C = capacitor
Greg Erskine
Old 12th September 2011, 08:17 AM   #3
jonners is offline jonners  United Kingdom
jonners's Avatar
How do you know that part needs replacing when you didn't know (until just now) what it was?
Old 13th September 2011, 08:08 AM   #4
qusp is offline qusp  Australia
Sometimes a square peg fits a round hole just fine
qusp's Avatar
probably the slight scorch marks visible are some clue =) its difficult, yes indeed its a capacitor, but if its fried he cannot measure its value (if he indeed has a multimeter), although good chance its the same as the other caps surrounding it. without knowing the value its hard, its likely to be 10-100nf np0/c0g or x7r type 0805 size ceramic. np0, c0g and x7r are grades, not brands, the brand will be univportant, so if we can find the value it will be easy to find one at farnell, digikey, mouser, newark etc
Old 13th September 2011, 03:12 PM   #5
tamphist's Avatar
Looks like it's just a bypass cap.
It is not that important part.
Your DAC should work even with that part missing.
Don't pay too much. Buy 50 pcs of them from here:
http://www.ebay.com/itm/50pcs-SMD-C0...#ht_865wt_1033
Or 100pcs from here:
http://www.ebay.com/itm/100-SMD-Capa...ht_3209wt_1186
Old 13th September 2011, 05:38 PM   #6
firechief's Avatar
Does the DAC work? If you are "moding" this unit you really really need a schematic first. The comments so far are well made, you might be able to just ignore the cap or replace it with a common bypass cap value like .01 ufd, but wouldnt it be smarter to know? Did you install that yellow radial cap hung out in the air like that? Did you short something out in the process? I suppose that I sound a bit critical, but you are asking for answers without offering enough information.
"You can keep your insurance baby nothing is guaranteed" -Tom Petty
Old 15th September 2011, 06:41 AM   #7
Thanks for all the replies, guys. I was trying to replace the power jack, which had been broken and I noticed the scorch marks. This dac had been bought used and I didnt know if I had done the damage or if the damage had been there before I bought it. I can test the board with a multimeter, but I cannot verify that it works since I desoldered the jack so I could replace it. Also, I did not install the radial cap. My goal was to replace the jack and I was concerned about the scorch marks. Anyways, I will try to replace the jack and if the dac works, then I will leave it alone. I think I will try to do as little damage as possible as I learn how to work with electronics.
Old 15th September 2011, 06:54 AM   #8
If I wanted to measure the surrounding caps, what setting would I have to set the DMM at?
Repair of Pink Triangle Da Capo DAC William C Digital Source 17 11th January 2010 09:43 AM
Could anyone help a novice? sunnycue Full Range 8 4th August 2006 05:45 AM
DAC question from a novice fishwinker Digital Source 6 17th June 2006 07:41 AM
Novice in need of help skiermurph Solid State 2 22nd December 2004 01:52 AM
Audio Alchemy DAC-in-the-Box Repair dtm1962 Digital Source 0 2nd April 2004 03:47 AM
Page generated in 0.08781 seconds (79.69% PHP - 20.31% MySQL) with 10 queries
