| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
Been testing my DCX2496 with various SPDIF/TOSLINK inputs, and have had mixed results. Wondering if it is possible to tap into I2S, if it's even available at this stage in the DCX (prior to DSP).
My thought was to use a an external USB/I2S ASRC converter and tap into the output of the existing CS8420. It is not easy to understand the data sheet of the CS8420; I know it has I2S capability but not sure what it's set up for. Would this address any jitter problems that I current have with SPDIF inputs? I am not familiar enough with I2S to fully understand what I am gaining, but my understanding is it corrects the input signal perfectly, thereafter only being subject to the system clock to which it is feeding. |
#2 |
There are a number of clock kits and mods for the DCX. You could look into those either as a turnkey solution or as inspiration for your own if you want to get a lower jitter signal into the ASRC.
BTW, what sort of problems are you having with the digital input? It's AES, but tends to work OK with unbalanced SPDIF in. There is not Toslink, unless you've added one.
Take the Speaker Voltage Test! |
#3 |
Yes, I've read about all the clock mods on the DCX. Thing is, my problem appears to be with the quality of my SPDIF input, not with the internal clock on the DCX.
What I found is by ear and measurement various sources resulted in significant difference with analog output quality. An AppleTV's toslink in combination with Twisted Pear's converter was the worst (no fault of TP, I believe). A MacBookPro's toslink was improved quite a bit, with only a few glitches here and there (sounds like a hiccup in the audio stream). Finally, my M-Audio SPDIF is essentially perfect, so my assumption is I am dealing with an issue of SPDIF quality. I would rather not have to use my M-Audio for a source, so need to consider a source with an appropriate converter that eliminates the SPDIF quality problem. I could use a Mac Mini, which has USB output. The recent thread on the FIFO is interesting, but doesn't seem to really be going anywhere. Bypassing the CS8420 entirely is a consideration, but I don't know how difficult that is. |
#4 |
What about installing one of the MiniDSP Ministreamers with the possibility of using the I2S output, bypassing the CS8420 entirely?
miniSTREAMER | miniDSP I could try to post at the MiniDSP forum if that makes more sense. $55 seems reasonable if I can get I2S, using the internal clock on the DCX. |
#5 |
zigzagflux,
I am also interested in bypassing cs8420 in behringer with I2S input, so I watch this thread with care. |
#6 |
Scratch that idea; if I bypass the CS8420 and go I2S, I will need to ensure a 96 kHz stream, which I don't have. Since the MiniStreamer does not upsample, all I can do is use the SPDIF output and keep the CS8420. But if the SPDIF is improved over my existing sources, that is fine too.
What can be expected of jitter quality with the MiniStreamer, or for that matter anything that runs USB to SPDIF? Not familiar enough with what goes on in those products. |
#7 |
Zigzagflux,
go on this thread I have very valuable answers XMOS-based Asynchronous USB to I2S interface Hope it will help Zoran |
#8 |
Sometimes a square peg fits a round hole just fine
it sounds to me like your hiccups are probably caused by incorrectly setup device drivers wrt buffer size
#9 |
It would not surprise me; to be honest I wouldn't even know how to change things around to test this. You would think running optical out of a MBP would be driverless in a sense. What options do I have to change this? I can go into the AudioMidi app and change bit number and freq, but that didn't seem to make a difference (either worked or it didn't).
After further reading, it looks like the CS8420 is set up in hardware mode 1. Output is slave I2S 24 bit, which makes sense. Mode is 1A, which I don't understand. I would be interested in going to hardware mode 2, but this requires a number of board level changes to the CS8420 pins. Serial input can be set for I2S with IF2 setting. There is also a CUVEN choice that I don't understand. So it certainly looks possible, but would take someone with more knowledge than I to make sure compatibilities are sound. |
#10 | |
link for Twisted Pear Metronome: The Metronome ASRC Module |
| ASRC and Oversampling Filters | percy | Digital Line Level | 11 | 13th February 2009 06:39 AM |
| Question on LspCAD and Behringer DCX2496 | JonW | Digital Line Level | 7 | 26th September 2007 03:42 PM |
| DCX2496 digital input question | honfatboy | Digital Line Level | 11 | 31st October 2006 06:26 AM |
| Question for DCX2496 owners - Volume Control | Branwell | Digital Line Level | 6 | 3rd March 2004 02:46 AM |
| ASRC Comparison ? | ftorres | Digital Source | 4 | 20th February 2002 02:33 PM |
| Page generated in 0.10936 seconds (78.53% PHP - 21.47% MySQL) with 11 queries |
