Open Source DSP XOs
Open Source DSP XOs
Old 6th May 2014, 10:22 AM   #571
steph_tsf is offline steph_tsf  Belgium
steph_tsf's Avatar
Originally Posted by peufeu View Post
steph, try googling : Frequency-Warped Signal Processing for Audio, Warped Filters, frequency warped FIR
VERY interesting. I'll try a few implementations using Flowstone. Do you know Flowstone?
Old 3rd June 2014, 08:02 AM   #572
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
I might be a bit late cottoning on here but Infineon now has a fairly comprehensive list up, with pricing of both its M0 and M4 offerings. The M0s (32MHz) start at 57 eurocents (1k) and the M4s, 2.7 euro. The 80MHz M4s come with some rather cool hires PWM generators (150pS nominal resolution) - they might be a great basis for a PWM DAC without need of noise shaping since at 44k1 that's equivalent to around 17bits. They all support what looks to be 4 channels of I2S.
32-bit Industrial Microcontroller based on ARMŽ Cortex?-M - Infineon Technologies
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 16th July 2014, 04:51 AM   #573
abraxalito's Avatar
Mouser has the latest ST marketing/dev boards in stock (Nucleo) and the one featuring the STM32F411 looks to me to be a slam-dunk for digital audio XOs with its 5 I2S ports (2 of which are full duplex). I haven't checked yet if all these interfaces are actually pinned-out on the 64pin package fitted to this board but I'm about to....
100MHz operating speed at 13.2mA CPU current - what's not to love?
NUCLEO-F411RE STMicroelectronics | Mouser
Old 31st July 2014, 09:50 AM   #574
abraxalito's Avatar
Having just acquired the cheapest yet Cortex M0 (STM32F030) to play with I went in search of an IDE which supports this relatively new chip. Coocox doesn't yet list it but Keil does. It turned out their 32k limit full IDE (around 300Mb) is available for free download here : https://www.keil.com/demo/eval/arm.htm
Old 5th August 2014, 06:59 PM   #575
mhelin is offline mhelin
Strange that Keil doesn't support STM32F411 yet, though support F429 on the STM32F429I DISCOVERY board (one with the 2.4" touch screen LCD).
Old 3rd September 2014, 12:53 PM   #576
STM32F411 chips seem to be no-existing, you can get them only with NUCLEO kits. However, also the SMT32F427 (available in LQFP 100 in smallest format) would be another good choice with 2x I2S + SAI interfaces, and it is readily available at least on Farnell (2333369).
For DIY kit you could use the bare MCUCARD PCB from MIKROE - "EasyMx PRO™ v7 for STM32 Empty MCUcard HP 100pin TQFP" (that should support STM32F4 also), MikroElektronika - EasyMx PRO? v7 for STM32 ARMŽ - MCU Cards supports STM32 microcontrollers
Datasheet for the PCB: http://www.mikroe.com/downloads/get/...schematics.pdf
Old 3rd September 2014, 01:51 PM   #577
Looks someone is in the process of designing a Beagle Bone form factor board called "STBone" using the STM23F427:
Link: STBone
Old 25th September 2014, 06:22 AM   #578
abraxalito's Avatar
STM look to be among the first to have a product based on ARM's latest M7 core - http://www.st.com/st-web-ui/static/a...DM00116941.pdf
Of note is an on-chip S/PDIF receiver (4 selectable inputs).
Old 27th September 2014, 05:40 PM   #579
The Wolfson Audio Card though originally designed for Rasperry Pi actually contains multichannel CODEC which could be easily interfaced with Nucleo or STM32F429DISCOVERY boards (using either I2S or TDM interfaces). Actually the Wolfson codec support also multichannel I2S modes where like four 16-bit channels can be wrapped inside single stereo I2S frame. Don't know if STM Cortex chips support 32-bit mode though.
WOLFSON AUDIO CARD - WOLFSON MICROELECTRONICS - AUDIO CARD, FOR USE WITH RASPBERRY | CPC
In addition to onboard analog converters (ADC 96 dB SNR, DAC SNR is >110 dB) there is a WM8804 S/PDIF transceiver. The analog outputs are line, headphone and speaker outputs (with 2x2W Class-D amplifier, might be usable with some high efficiency tweeters or compression drivers maybe). There is also a DSP with some selfing and parameter EQ's and HPF and LPH filters).
Btw. Cirrus has just acquired Wolfson Microelectronics.
Old 27th September 2014, 06:14 PM   #580
Well, not "just" but actually just a month ago:
Cirrus Logic Completes Acquisition of Wolfson Microelectronics
Open Source DSP XOsHide this!Advertise here!
Volume / Source selector - open source project ? AuroraB Analog Line Level 22 22nd September 2012 03:21 PM
Violet DSP Evolution - an Open Baffle Project cuibono Multi-Way 211 18th May 2010 03:26 AM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 08:33 AM
Open Source, Open Architecture! zenmasterbrian Digital Source 185 23rd February 2007 11:35 PM
Copyright ©1999-2017 diyAudio
