Open Source DSP XOs
Open Source DSP XOs
Old 17th November 2013, 07:06 PM   #541
twest820 is offline twest820
Hmm, I should probably expand on the above---for clock read "pin clock". Data gets clocked out of the slice on the internal clock. So using an internal (slice) clock only works for implementing I2S receive if MCLK is available and even then you get some skew (you can't route a input slice to the PLLs to generate a zero delay clock from SCK). SGPIOs 8 to 11 can be pin (external) clocks and 12 to 15 slice clocks. The configuration of post 538 therefore doesn't quite work as SCK is bound to the SGPIO 14 slice clock and MCLK isn't necessarily available. Easier just to use an external clock for inputs and avoids skew problems as the outputs remain in sync with SCK in the case where it's looped back on the codec board.
Old 18th November 2013, 03:07 PM   #542
mhelin is offline mhelin
Yes, also SGPIO14 can't be SCK when if MCLK is used because it cannot be sourced by any slice clock.
Now it seems that J3 contains enough I2S0 pins so the input could be taken using it, would that be cleaner?
I2S0_RX_SCK H4 SSP1_SCK (J3)
I2S0_RX_SDA G6 GPIO5_9 (J3)
I2S0_RX_WS G5 GPIO5_8 (J3)
You can use DMA to copy the data to a buffer (or better to a dual buffer when you program two Linked List Items to point each to the other creating circular buffer).
Regarding SGPIO there are many things that should be considered. For an example the shift clock should be twice the bit rate. For an example for 96 kHz I2S the bit rate is 2x32x96 = 6.144 MHz, so the shift clock should be 12.288 MHz. Also the SGPIO input pins are synchronized by the SGPIO_CLK so that should be high enough. If MCLK is 4x SCK (24.576 MHz in this case) the SGPIO_CLOCK should be twice of that (49.152 MHz). It would be fine if this clock was external one from a good quality audio clock. Unfortunately the GP_CLKIN can be pinned with this device (LPC4370) only to H4 which is the same pin as I2S0_RX_SCK.
E: However, the K3 and K9 pins which could be muxed to ENET_TX_CLK which also can be used as external clock to BASE_PERIPH_CLK are available in test points (so some soldering needed). That's been discussed earlier in #120
Old 18th November 2013, 08:21 PM   #543
Cleaner is maybe individual preference. Don't think there's much question using the I2S0 peripheral rather than creating one's own with SGPIO is going to be simpler and less error prone when coding firmware.
Since any codec board I build will require I2C and control lines and therefore connect to J3 I've been considering exactly this option. Similarly, any codec board I build will send an MCLK copy to the microcontroller/DSC/DSP. In this configuration J8 would be used about like
  • MCLK - JTAG_TCK_SWCLK SGPIO11 - input
  • I2S_SCK - TRACECLK_RTCK SGPIO8 - output
  • I2S_WS - JTAG_TDO_SWO SGPIO10 - output
  • I2S_SDO_0 - TRACEDATA0 SGPIO0 - output
  • I2S_SDO_1 - TRACEDATA1 SGPIO1 - output
  • I2S_SDO_2 - TRACEDATA2 SGPIO2 - output
  • I2S_SDO_3 - TRACEDATA3 SGPIO3 - output
which happens to follow the I2S example in section 19.8.1 of the LPC43xx manual nearly pin for pin.
Old 19th November 2013, 09:59 AM   #544
The exception is that in 19.8.1 example slice clock from slice D (SPGIO12) is used. I'm just wondering what's the difference? SCK input is however an external pin clock. Difference is that MCLK is divided by four but SCK used as such, I don't know if MCLK can be used that way, can pin clock input divided at all?
"SCK master mode: SCK is supplied at pin 8, this clock falling edge is used as shift clock for all slices. No MCK is used."
The PRESETi is "counter not used" (it says not value zero) whereas for slice D in MCK master mode PRESET is set to 3: f=MCK/4, but then the other slices are set to use "SGPIO_MUX_CFGi / ext_clk_enable = 0 :internal clock" mapped to slice D in slice mode.
PRESET documentation:
"Each register contains the reload value for one slice: PRESET0 to PRESET15 contain the reload value for slice A (register 0) to slice P (register 15).
This register controls the internally generated slice shift clock frequency: frequency(shift_clock) = frequency(SGPIO_CLK) / (PRESET+1)."
Now is this setting only available for internal clocks (meaning SGPIO_CLK or slice clock)? The slice D on the other hand uses PRESET value 3 (/4) and seems to be configured similarly as SCK otherwise so it seems it could work.
Old 19th November 2013, 03:12 PM   #545
Yeah, figures 42 and 43 in the LPC43xx manual kind of disagree about how clocking works. 19.6.3 is pretty specific about CLKGEN_MODE so I suspect figure 43 is unclear in that external clock should read "clk_slice or clk_pin". Probably the manual just picked up some ambiguity around the definition of external clock through edits over time. This suggests PRESET = 3 in table 321 is incorrect---presumably that cell of the table should say not used---and the clock divide is accomplished by loading SGPIO12's shift registers with 11110000b. With an LPC-Link 2 in hand it's easy enough to check this with a function generator on SGPIO13 and an oscilloscope/logic analyzer/something like that on the outputs.
It is unclear from the manual if a slice can be used if its output is not assigned to a pin, though I don't see any reason why this would be required. So presumably post 543 could be implemented by making SGPIO11 a pin clock to any of SGPIO12 to 15 and then using the chosen slice as a slice clock for the I2S output SGPIOs. Worst case would be pin assignment is required, in which case SGPIO13 would have to be used.
Old 20th November 2013, 02:17 PM   #546
It's clear from the Fig. 43 in User Manual that the PRESET does not affect to external clock, just to SGPIO_CLOCK. Wonder what the pre-divider discussed here does mean:
SGPIO with DMA | www.LPCware.com
Old 21st November 2013, 04:49 AM   #547
My reading is predivider = PRESET. For the configuration we're discussing here a DMA request can be raised by I2S0 each time a sample is received (section 43.7.3) and it's desirable to use SGPIO14 or 15 to do the same each time a sample is sent and the shift registers exchanged on I2S_SDO_x. In the default I2S case of 32 bits per sample this should be straightforward to implement by operating one of the GPDMA slices in self loop from the SCK slice clock. The default pattern of 0x4000 0000 mentioned in section 19.7.6 should be fine.
However, I think this approach is limited to stereo receive or stereo send. If I'm reading the manual correctly it doesn't work so well with multichannel audio as SGPIO14 and 15 are the only SGPIO destinations available (table 327 got glossed over in post 57 of this thread). One of those needs to be loaded with the pattern to trigger DMA, meaning only the other is available as a DMA destination peripheral. This is fine if the DAC is in one line mode but problematic when operating two or more I2S_SDO lines in parallel as only one line can be a DMA recipient.
Presumably multichannel data is moved via the combined SGPIO interrupt which fires when a slice's REG and REG_SS shift registers are exchanged. This seems to be variously referred to as the capture clock interrupt, exchange clock interrupt, FIFO full interrupt, and POS interrupt depending on which part of the manual one's looking at. Since all I2S_SDO lines exchange registers in sync with I2S_WS the result should be just one interrupt per batch of left or right samples whose handler copies the next 32 bit word to each REG_SS in use.
Old 25th November 2013, 05:22 AM   #548
So, upon closer inspection, it may be desirable to leave U3 and U4 in their default directions on the LPC-Link 2. This enables the configuration below, which supports implementation of a 8 in, 6 out USB audio interface at the I2S level (it's not hard to make the marketing numbers higher---14 in 28 out would be fairly easy, for example).
I2S_IN0
  • J3 pin 3 - I2S0_RX_SCK
  • J3 pin 11 - I2S0_RX_WS
  • J3 pin 12 - I2S0_RX_SDA
I2S_IN1
  • J8 pin 12 - SGPIO8 - I2S_IN1_SCK - pin clock for rest of I2S_IN1
  • J8 pin 14 - SGPIO0 - I2S_IN1_WS
  • J8 pin 16 - SGPIO1 - I2S_IN1_SD0
  • J8 pin 18 - SGPIO2 - I2S_IN1_SD1
  • J8 pin 20 - SGPIO3 - I2S_IN1_SD2
I2S_OUT
  • J4 pin 16 - SGPIO9 - MCLK - yields 128fs pin clock to slice 15
  • J3 pin 5 - SGPIO10 - I2S_OUT_WS
  • J3 pin 6 - SGPIO13 - I2S_OUT_SCK - clocked from slice 15, yields 64fs slice clock for rest of I2S_OUT
  • J8 pin 4 - SGPIO11 - I2S_OUT_SD0
  • J8 pin 8 - SGPIO12 - I2S_OUT_SD1
  • J8 pin 10 - SGPIO14 - I2S_OUT_SD2 - or J8 pin 2 if U7 is used
The direction pin of U6 (or U7) must be pulled high to make SGPIO14 an output. The I2S0 + I2S1 configuration is useful for supporting SPDIF receive through a Wolfson WM8805 or such on I2S0 and a multichannel ADC on I2S1. If a multichannel codec is used it's useful to assign I2S_IN0 to the codec's input as that makes it easy to switch between the codec's ADCs and SPDIF receiver and I2S_OUT to the codec's DACs.
If the I2S0 peripheral is not needed then the single connection to J4 can be omitted and J3 pin 3 used as GP_CLKIN. In this configuration SGPIO9 is freed for use as I2S_IN1_SD3 as SGPIO13 can generate I2S_OUT_SCK through division of CLK_PERIPH_SGPIO. This would most likely occur with an eight channel ADC to, for example, mic a drum kit.
As usual for SGPIO the above pin assignments are tweakable. Most notably, SGPIO14 can be reassigned as an output if 6 in 8 out is preferable. Handy for quadamping.
Disclaimer: I've checked the above in the LPC-Link 2 pinout spreadsheet I've built up but might have made a mistake. Or missed a typo in putting together this post.
Old 25th November 2013, 07:10 PM   #549
Yes you could get more I/O using converters supporting TDM (sometime called "DSP") format PCM interface. 8 channel input or output / data line usually (at least if you limit the sample rate to 48kHz, otherwise two lines are required, though there might be exceptions to that). This doesn't apply to I2S I/O pins, but with SGPIO it would be possible.
Btw. I asked Embedded Artist about the TP locations and they wrote this one page document:
http://www.embeddedartists.com/sites...-locations.pdf
So if you would like to use the I2S0 which takes the GP_CLKIN signal @J3 pin 3 you could use some of the TP clock inputs supported by CGU (clock gonfig unit) - ENET_TX_CLK (K9) @ TP_P1_19 (or @ TP_CLK if you mux it to K3 pin) pin is one of them.
Old 26th November 2013, 01:54 AM   #550
Yah, hence my comment about there being plenty of ways to get higher IO counts. 6/8 in/out is upper midrange in the interface market. So there's not necessarily need to use I4S, I6S, or I8S (TDM). I happen to have both a Saffire Pro 40 and Scarlett 18i20 at the moment so I'm not exactly short on IOs. The most I use is 5 in 6 out at the moment, though 6 in 8 out might happen if I find a good deal on a C414 and also start using cans/buds and triamped monitors simultaneously.
I do find use of TDM attractive as it allows the 10 SGPIOs on J8 to form three InS links while leaving J3 open for a common MCLK. For example, WM8805 + CS5368 + CS4385 = I2S in+out + I8S in + I8S out = 10 in 8 out. Not bad for plugging a ribbon cable into a USD 20 microcontroller eval board. One can pack the 12 available SGPIOs more tightly to reach for maximum IO (something like 34 in/32 out, not counting MIDI or ADAT) but not requiring common SCKs and WSes ends up being useful for SPDIF or higher end parts. Everything through U4 needing to go the same way gets to be an issue too, so at some point it's easier to do one's own board.
As an aside, it's possible to roll a non-SGPIO I2S in+out on the LPC-Link 2. Goes like this
  • J3 pin 12 - I2S0_TX_SDA
  • J9 pin 20 - I2S0_RX_SDA
Thanks for the higher res LPC-Link 2 photo. The test points are also indicated the LPC-Link 2 schematic so they're on my spreadsheet. I didn't type up the ENET_TX_CLK options in my previous post for two reasons. One is simply brevity. The other is it's probably nicer to tap J4 as that offers better impedance control on the clock net and additional pins for things like a volume pot.
Open Source DSP XOsHide this!Advertise here!
Volume / Source selector - open source project ? AuroraB Analog Line Level 22 22nd September 2012 03:21 PM
Violet DSP Evolution - an Open Baffle Project cuibono Multi-Way 211 18th May 2010 03:26 AM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 08:33 AM
Open Source, Open Architecture! zenmasterbrian Digital Source 185 23rd February 2007 11:35 PM
