Open Source DSP XOs
Open Source DSP XOs
Old 4th September 2011, 01:33 AM   #11
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Originally Posted by twest820 View Post
Interesting idea. Source code availability aside, what processing capabilities are needed which aren't already available from existing solutions (MiniDSP, SigmaDSP, VSTs such as Frequency Allocator or ReaEQ, rackmount platforms like the ones from Ashley and Behringher, or even Hypex's DLCP if they ever get around to shipping it)?
I had a brief look at SigmaDSP a while back but didn't invest time or effort because of not wishing to be locked into just one vendor (ADI in this case). Processing capability is a bit restricted going that route - its run at a fixed sample rate. The others I have no direct experience of. I don't doubt PC-based solutions have the necessary grunt in processing terms but I'm not a believer in the longer term ubiquity of the PC platform.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 4th September 2011, 02:45 AM   #12
twest820 is offline twest820
So you want something that can be easily compiled for a conventional instruction set as opposed to processor/family-specific DSC SIMD extensions or DSP instruction sets? Vinnie Falco's bits are worth a look. I'd describe the code as overly layered but it's faster to strip layers and port to C than to recode.
Personally when I looked at this space I concluded a SigmaDSP was the easiest way to meet my needs. The ARM Cortex parts and big AVRs have the MIPS to run a reasonable number of biquads (particularly if used as DSCs, though that violates the single vendor constraint) but the limited number of I2S peripherals makes them unfriendly to crossover operation. It's a bit more expensive to set up an Intel Atom fanless PC or a quiet laptop with an audio interface and run an ASIO based PC crossover but I found the time saving from not having to write a RTOS kind of core to move the data streams compelling in comparison---particularly as I already had the audio interface, VST host, VSTs, and old laptop to do the processing. Much easier than working with the xmon USB audio interface parts directly or paying the $$$ for a TC Dice license too. However, I'd ultimately like something more turnkey than a PC and the ADAU144x parts are quite attractive as they're cheap, available in DIY friendly packages, and have lots of I2S peripherals as well as onboard SPDIF and ASRC blocks. I figure that saves enough time I can probably migrate to another platform once SigmaDSP becomes obsolete and still come out ahead on the deal.
That said, I do have a C# project aimed at integrating DSP operations into rip+burn workflows which I plan to open source once I have enough coded for a meaningful release. It's been moving slowly since it's summer and my day job's been busy of late. The code's quite a bit simpler than Vinnie's and I've no objection to folks picking it up and porting it to C if they want. Just don't hold your breath.
Old 4th September 2011, 10:44 AM   #13
abraxalito's Avatar
No, I was barely thinking about instruction sets at all. Certainly wasn't thinking in terms of C. It would have most use ISTM if its just at the level of the conceptual block diagram of the filters - Direct Form I for example - with coefficients calculated for various cut off frequencies. LTSpice doesn't support anything close to C code. I'm a hardware guy and to me the best approach is to consider digital filters in the same way as analog ones - produce a schematic design and let individuals be concerned with the instantiation details.
Personally when I looked at this space I concluded a SigmaDSP was the easiest way to meet my needs. The ARM Cortex parts and big AVRs have the MIPS to run a reasonable number of biquads (particularly if used as DSCs, though that violates the single vendor constraint)...
I can see how in the case of AVR because that's solely Atmel, but how does an ARM DSC violate the constraint? At the present time the M4 is quite probably only available from Freescale (if they are indeed shipping real hardware?) but it won't be long before NXP's M4 comes along. Others are bound to follow.
... but the limited number of I2S peripherals makes them unfriendly to crossover operation.
Its been something of a limitation but less so with the introduction of NXP's M4 part where there are configurable sync serial ports.
Old 4th September 2011, 02:40 PM   #14
Seems the Bristow-Johnson cookbook is likely sufficient, then. FIR synthesis is less turnkey but there's not exactly a shortage of textbooks describing windowing, Remez exchange, and so on.
If a single vendor's IP licensed to multiple implementors is considered a multiple vendor solution well, then, that's obviously OK. I also find the NXP M4s attractive but, well, they're still in development and I don't have a solution for routing and soldering BGAs that fits in what I'd consider to be a DIY budget. Digikey has the Freescale M4s in stock.
Old 4th September 2011, 02:59 PM   #15
jcx is offline jcx  United States
IIR are the way to closely follow a analog continuous filter prototype - their "irregular" structure compared to FIR make most "DSP" instructions less useful
there is a requirement for extended word length intermediates/storage - particualrly as BiQuad corner frequency ratio to sampling rate becomes large - 32 bits aren't enough to avoid truncation/quantization effects at the 16 bit output level with subwoofer frequencies and hi res sample rates
Old 6th September 2011, 03:22 PM   #16
Trevor White is offline Trevor White  Australia
Has anyone looked at Audio Weaver from dspconcepts.com ??
Audio Weaver Designer 2.2 Intro - YouTube
DSP Concepts: Audio Weaver on Blackfin Processor Demo
DSP Concepts: Audio Weaver on SHARC Processor Demo
Old 6th September 2011, 04:42 PM   #17
boris81 is offline boris81  United States
I have looked into options for developing DSP crossovers. As far as hardware solutions are concerned I think miniDSP and Behringer DCX2498 are hard to beat. Any alternative solution would not be much cheaper and will take an enormous amount of development.
The most appealing goal of such endeavor as I see it will be a computer based solution that can improve ease of use and be offered at no cost. VST plugins are not flexible enough and the good ones aren't free. My vision is a Universal Audio Driver that utilizes the CPU or the GPU to process the signal before routing it to the sound card. The interface should allow the user to build configurations on the fly by connecting processing blocks similar to Console or Kx-Project. IIR and FIR implementations should be possible. The disadvantages are centered around possible platform dependance and having to use a computer but the driver itself should be flexible enough to accommodate a variety of sound cards and DACs.
Old 10th September 2011, 02:10 AM   #18
fb is offline fb  Australia
I'm not sure how powerful it effectively is for DSP use, but the latest core module used by the midibox.org project may be useful, especially because the firmware's already open source:
MBHP_CORE_LPC17 Module
That said I think it would be easier to work with miniDSP. I briefly spoke to them a while ago, and with the correct community based approach they MAY be open to allowing a custom programming interface to their boards. Something along the lines of sharing the communication protocol for their MCU, thereby allowing people to upload firmwares created with SigmaStudio.
Old 16th September 2011, 01:15 AM   #19
abraxalito's Avatar
Default Not exactly an XO...
Seeing as KC-P's LTSpice simulation idea is a little unconventional (discrete time filter being simulated in continuous time) I wanted to try out a fairly simple filter in it and see what the results looked like.
Here's the schematic for the first one I've tried. Its an FIR for sinc compensation, to use with a non-oversampled DAC in correcting the sinx/x roll-off inherent in such designs.
I originally used Audacity (its EQ function which allows a filter to be created from drawing lines on a frequency response graph) to create this but then when plugging it into MATLAB the results didn't agree with those in Audacity. So I figure Audacity may have some inaccuracies since when I put the same filter into LTSpice it more or less agrees with MATLAB. In due course I'll implement this in real hardware and the measurements will be the final arbiter. Until then if anyone wants to play with a simple (11 tap) FIR filter, here's my rather scrappy looking schematic. The scrappiness arises from it originally being a 21 tap filter which Audacity gave me which I found I could optimize down to 11 taps using LTSpice as the simulator - so the concept most certainly does work.
@twest820 - BGA is not the only available package for those NXPs - TQFP144 is shown too, a tad more DIY friendly. I see Freescale has just announced some 99c Kinetis K10/K20 M4s in small packages which they say will ship next year.
Old 19th September 2011, 06:46 AM   #20
steph_tsf is offline steph_tsf  Belgium
steph_tsf's Avatar
Originally Posted by abraxalito View Post
My initial (crazy?) idea is to get models of various XO components working in LTSpice using a delay line.
Do you really mean an analog delay line of 22 Ás ?
Will the results (amplitude, phase, time domain response) be the same as the real-world digital IIR or FIR ? Can you provide an example ? Looks very promising ...
I guess you need somebody exploiting the LTspiceIV netlist in text format, then converting it into DSP code. Looks also very promising ...
Which audio DSP platform are you targeting ? DSP56K maybe ? The Elektor DSP56374 board ?
See it here http://www.elektor.com/magazines/201....1810926.lynkx
IIR coefficients up to the 8th-order may be calculated using IIR_Lab : a design help for digital audio filters - see post #12
Open Source DSP XOsHide this!Advertise here!
Volume / Source selector - open source project ? AuroraB Analog Line Level 22 22nd September 2012 02:21 PM
Violet DSP Evolution - an Open Baffle Project cuibono Multi-Way 211 18th May 2010 02:26 AM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 07:33 AM
Open Source, Open Architecture! zenmasterbrian Digital Source 185 23rd February 2007 10:35 PM
