Open Source DSP XOs - Page 51 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 27th October 2013, 02:08 AM   #501
Somehow the links don't work for ebay listings. Type this number into ebay 151041890711
Here are the details:-
TMS320F28335PGFA (package: 176-LQFP), Development board, TI DSP
Model:F28335-Pi
Product shipping list:
1. TMS320F28335PGFA development kits(JTAG14 Interface), with cables
2. DB9 SCI communication cable
3 .Power cable(usb cable)
4. Codes and Files are sent through email(the requesting email address will be sent with the board together)
5. Hardware email tech-support free for three months
Hardware Resource(Out of Chip) List:
1.256K16-bit extern SRAM(which could be updated to 512K16bit);
2.8M16-bit extern FLASH
3.Serial 64k EEPROM(AT24LC64);
4.RS232 SCI Interface;
5.2 Way CAN2.0B Transceiver circuits;
6.2 LED,2 keys ,1 reset key;
7.Set aside TMS320F28335 start the configuration interface, a great user more flexible development。
On chip resources(more reference please turn to Analog, Embedded Processing, Semiconductor Company, Texas Instruments - TI.com)
1.DSP Processor TMS320F28335PGFA,32 Bit Floating Processor, clock:150MHZ
2.DSP On chip 256K16-bit FLASH
3. DSP On chip 8K16-bit Boot ROM
4.DSP On chip OTP ROM:1K16-bit;
5.DSP On chip 34K16-bit SRAM;
7.DSP On chip A/D:28Channel,12-bitResolution,80nsConversion time、0~3V Input Range;
8.DSP On chip PWM:12 Channel Output,6 channel high resolution PWM (HRPWM);
9.2.54MM Pins Leads all function pin of TMS320F28335
More information about TMS320F28335 Chip please refer :C2000 32-bit Real-time Control MCUs - C28x Delfino Floating-point MCUs - TMS320F28335 - TI.com
Supporting Material:
1, schematic(PDF format),: correspond exactly to the board
2, user guide
3, sample programs of all the hardware resource in the board
4, Protel format schematic library, Protel format PCB footprint library
Note:
this development kit need a Emulator to use, the emulators includes:XDS100V2, X/TDS510,560, or any Emulator which support TI C2000 DSP
Old 27th October 2013, 02:25 AM   #502
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
Current consumption roughly 400mA at 150MHz? No, thank you.
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Old 27th October 2013, 02:56 AM   #503
400mA at 3.3V or 1.32 Watts !! Are you kidding me !!
And that's with all of the peripherals running as well !!
And there is more !! 60 bucks for an ICE. Ebay number 350473496337. Check it out
XDS100 XDS100V2 TI DSP Emulator ARM9 Cortex A8 TMS320
Description:
The XDS100v2 USB JTAG Emulator is the second release of the XDS100 JTAG emulator technology supporting debug of a variety of TI devices. It allows the user direct access between the host computer and the DSP through a 14-pin JTAG header. It is compatible with Code Composer Studio (CCS) V4 and compatible with Windows XP/Vista/Win7.
Features
Support for the following processor cores: TMS320C28x, TMS320C54x, TMS320C55x, TMS320C64x+, TMS320C674x, ARM 9, ARM Cortex R4, and ARM Cortex A8.
Debugging function(connect / disconnect, read / write memory, read the register, load the program, run, stop steps to support the breakpoint debugging, real-time mode)
Supports On-Chip Flash Programmer(e.g. C2000)
Support targets with 14-pin TI JTAG connector as used by Texas Instruments embedded processors.
Support for USB2.0 High Speed (480 Mbit/s)
Compatible with +1.8V or +3.3V JTAG interfaces
Support for Code Composer Studio v4 and newer (Does not support Code Composer Studio v3.3)
Support for power-off test and Adaptive Clock
Support for Windows XP/Vista/Win7
Old 27th October 2013, 03:04 AM   #504
abraxalito's Avatar
Is this a question?
Again, no. Steph's XMC4500 Relax board with two CPUs on it is under half that price here. As well as much lower power consumption.
Old 27th October 2013, 04:29 AM   #505
Is this a question?
the price and power is not an issue at all at 1 watt and you know how it is, there will always be someone who wants a 4-way active crossover
Old 27th October 2013, 09:59 AM   #506
abraxalito's Avatar
Why would that someone want an XO though that consumes more power, rather than less?
Old 27th October 2013, 10:05 AM   #507
steph_tsf's Avatar
OK steph, you got me interested in the XMC4XXX range now.
Time to practice with the sole and only member that's curently available, the XMC4500? Time to buy a few XMC4500 Relax Lite Kits from Hitex? XMC4500 Relax Lite Kit
Old 27th October 2013, 10:08 AM   #508
that's like asking what is the price of fish is on mars. The power has no relevance whatsoever unless you are running it from batteries which I don't think is a requirement here. There are plenty here who run dsp crossovers on their PC hardware. What power do you think they consume ? A lot more than a TMS320F28335 !!
The TI dsps are well documented and well supported and have been for decades which is more than I can say for these cortex M4 devices.
Old 27th October 2013, 10:20 AM   #509
abraxalito's Avatar
I'm not following you. Perhaps explain the steps you used to reach this analogy?
Why not go for the lowest power and lowest price, all other things being equal? Don't just assert, explain why power isn't relevant. In any case even though you don't find it relevant, I most certainly do and it was you pitching the product.
So what? Plenty of people leave windows open with the aircon running.
Relevance? TI will be dead long before ARM gives up the ghost - have you checked the relative corporate performance of the two any time recently? Investing effort in learning TI proprietary hardware isn't a long-term investment at all.
Old 27th October 2013, 10:24 AM   #510
abraxalito's Avatar
I found a seller on Taobao for 180rmb so I'll go that route for now. However I have something of a back-log of devboards here....
Volume / Source selector - open source project ? AuroraB Analog Line Level 22 22nd September 2012 03:21 PM
Violet DSP Evolution - an Open Baffle Project cuibono Multi-Way 211 18th May 2010 03:26 AM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 08:33 AM
Open Source, Open Architecture! zenmasterbrian Digital Source 185 23rd February 2007 11:35 PM
Copyright 1999-2017 diyAudio
