Zen -> Cen -> Sen, evolution of a minimalistic IV Converter
Old 21st April 2012, 10:16 AM   #771
TheShaman is offline TheShaman  Europe
Yeah I prefer the Ceramique myself. One less thing to worry about!
"You have a hierarchy: a mathematician, a physicist (which is a failed mathematician), and an engineer (which is a failed physicist)." - Andrew Jones
Old 21st April 2012, 06:27 PM   #772
EUVL is offline EUVL  Europe
Thermal conductivity for Silver is somewhat better.
Patrick
xen-audio.com
Old 22nd April 2012, 12:36 PM   #773
Patrick
Yeap.
When I run my Ceramique v.1 vs Silver tests on some older CPUs (i.e. Athlon64 era) the Silver stuff actually gave lower temps - but it was only ~2 degrees C lower. Not enough (at least in that application) to justify the extra hassle.
Old 25th April 2012, 06:41 PM   #774
I have been asked by PM to post a schematics of SEN IV using LU1014.
If you compare the DAO (standard) follower to a 2SK170 source follower,
you can use the same substitution in the SEN IV V18 circuit to make up your own schematics.
It is easy enough.
If you post it I shall have a look to see if I spot any obvious mistakes.
Otherwise I stick to my lessons learned and will no longer post any schematics without testing myself.
And I have no immediate plan for a DAO IV, unlikely this year.
Bear in mind you will need 48V 250mA floating supply or battery plus large enough heatsinks per single ended SEN IV.
Will undoubtedly be a spectacular project.
So don't let me discourage you.
I will be quite interest to see it working.
Patrick
xen-audio.com
Old 30th April 2012, 01:10 PM   #775
gadut is offline gadut  Indonesia
gadut's Avatar
Interesting design, especially those heatsink where do you buy it? I'm reading first pages, but still many pages to go
I still have around 40pcs 2SK170 from dcb1 project, and I just realize how expensive 2SJ74 so for AD1865, should built ZEN or SEN?
Old 1st May 2012, 04:59 PM   #776
If you have enough 2SK170s. Suggest you build standard SEN.
Patrick
xen-audio.com
Old 2nd May 2012, 07:05 AM   #777
NicMac is offline NicMac  Italy
NicMac's Avatar
Default SEN V18 current draw
I'm testing my new regulated XEN battery supplies for the SEN V18 and I'm looking for an appropriate dummy load. How is the approximate current draw calculated? The sum of the Idss of the FET's?
Nic
Old 2nd May 2012, 10:22 AM   #778
heb1001 is offline heb1001  China
Nic
I'm working on a battery supply. Have you actually tested that using regulators offers an improvement? What's the benefit?
Old 2nd May 2012, 11:21 AM   #779
NicMac's Avatar
Well - I have to make the regulated supply to compare - don't I
I don't expect anything dramatic as it is sounding so damn good right of the batteries. I had to make the charger circuit anyway and adding in regulation is really just for the fun of it. I doubt it hurts......
Nic
Old 2nd May 2012, 04:03 PM   #780
Yes, sum of Idss of the 2 FETs in parallel.
So about 40mA.
Patrick
xen-audio.com
Zen -> Cen -> Sen, evolution of a minimalistic IV ConverterHide this!Advertise here!
FOR REGA Turntable>>> The heavy weight + Vta adjuster+ceramic ball prooptiki Swap Meet 1 22nd May 2010 05:57 PM
Multi-DAC: Lynx AES16 -> DIR9001/SRC4392 (-> SRC4192) -> PCM1794A novec Digital Line Level 11 11th May 2010 11:57 AM
> Audio <> music <> quick <> synergy <> angst>? rick57 Everything Else 0 4th May 2007 04:03 PM
&gt;&gt;&gt; cheap 50,000uF 60V capacitors here &gt;&gt;&gt; Lubomir Swap Meet 0 1st February 2007 03:36 PM
