Zen -> Cen -> Sen, evolution of a minimalistic IV Converter - Page 61 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 18th March 2012, 04:08 PM   #601
merlin el mago's Avatar
Thanks again for your very good advice, I will try first with two 9V alkaline batteries first.
If I understood well your schematic: I need to connect a 10R + 100pF polystyrol between each DAC output (10R) + (100p) to AGnd ES9018 (Agnd is gnd in the AVcc TP module?)
First I need to learn what is a horse, thanks for support Patrick.
Felipe
Old 18th March 2012, 06:45 PM   #602
EUVL is offline EUVL  Europe
You need 2x 9V battery for one single ended SEN.
So for 2 channel balanced, you need 8x 9V battery altogether. Still less than 10 Euros.
Once working you can decide whether to go rechargeable, or mains based floating.
Correct. You may also use 100p silver mica if you wish.
And you should do this close to the ES9018 PCB from whatever supplier.
The purpose is to shunt some of the HF components of the i_out of the DAC.
Wish Nic will show you some photos soon.
Patrick
xen-audio.com
Old 18th March 2012, 07:41 PM   #603
Patrick
can you share a charging circuit for NiMh battereis to be used with Sen
Old 18th March 2012, 08:05 PM   #604
Originally Posted by samoloko View Post
Patrick
+1
Old 19th March 2012, 04:05 AM   #605
Some time this week.
Build the SEN first.
Your motivation will increase exponentially for the charger.
Patrick
xen-audio.com
Old 19th March 2012, 12:13 PM   #606
Here the schematics again properly drawn.
Unless I made some careless mistakes, they should be the same as that of post#593.
I have removed the 10R-100p at the current outputs of the ES9018.
They are most likely to be not very effective there due to the low Zin of the SEN IV V18.
You should instead experiment with C_iv in parallel with R_iv, starting with 100p.
Charger circuit later in the week.
Patrick
xen-audio.com
Old 19th March 2012, 12:42 PM   #607
Thanks Patrick
Felipe
Old 19th March 2012, 02:13 PM   #608
CeeVee is offline CeeVee  Portugal
CeeVee's Avatar
can't wait to get my heatsinks from Mark for the 2sk372Vs i'm going tu use for this ..
Old 19th March 2012, 02:24 PM   #609
CeeVee's Avatar
Patrick
You can probably see something very similar if you look for the O2 portable headamp in the Forum
Old 19th March 2012, 03:24 PM   #610
jambul is offline jambul  Belgium
Dear Patrick,
Can we apply your sen for es9018 sen for pcm1794?
What need to be adjust?
Thank you for your kind assistance
FOR REGA Turntable>>> The heavy weight + Vta adjuster+ceramic ball prooptiki Swap Meet 1 22nd May 2010 05:57 PM
Multi-DAC: Lynx AES16 -> DIR9001/SRC4392 (-> SRC4192) -> PCM1794A novec Digital Line Level 11 11th May 2010 11:57 AM
> Audio <> music <> quick <> synergy <> angst>? rick57 Everything Else 0 4th May 2007 04:03 PM
&gt;&gt;&gt; cheap 50,000uF 60V capacitors here &gt;&gt;&gt; Lubomir Swap Meet 0 1st February 2007 03:36 PM
Copyright 1999-2017 diyAudio
