Zen -> Cen -> Sen, evolution of a minimalistic IV Converter - Page 4 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 30th August 2011, 10:29 AM   #31
EUVL is offline EUVL  Europe
Take the specs of ES9018 and PCM1704K, which are about as high end as you get these days for Sigma delta and for R2R DACs.
ES9018 specs says -120dB THD, and PCM1704K says 0.001%, or -100dB.
Even at a transimpedance of 2700R, which is factors higher than anything this simple in discrete circuits that I know of, the simulated distortion for SEN IV is 0.0012% (-99dB), and is largely 2nd harmonics. In balanced mode, it will go well below -100dB, i.e. matching that of a PCM1704 K grade.
There are tricks described in the article to reduce this by a further factor of 3.
And so far I have not seen any discussion of how the circuit functions. The key to its performance is that it functions totally different from say a ZEN IV. Only when you understand how it works would you aprreciate its elegance.
If you only want to chase after THD numbers, you should not make anything discrete and just use high open-loop gain opamps.
I build discrete because they sound wonderful.
Patrick
Old 30th August 2011, 10:31 AM   #32
If you want to use a DAC to build a functions generator, the only way you can get decent performance (below -120dB) digitally is IMHO to notch filter the DAC output.
You can of course always use voltage out DACs with built-in opamps (on top of the notch filtering).
It does not need to sound nice, just low distortion.
Patrick
Old 30th August 2011, 10:54 AM   #33
The noise floor on the SEN is lower by about 3dB because there I had 2 JFETs in parallel.
Well known trick to lower JFET noise.
Patrick
Old 30th August 2011, 12:31 PM   #34
Patrick
So that means that you would be able to distinguish between the sound of your I/V circuit and the sound of an op. amp. based I/V converter that has the same or better THD performance (i.e. better than -100db) ?
Obviously the rest of the audio chain would have to be identical (the same digital source, DAC, amp. and speakers).
Old 30th August 2011, 02:29 PM   #35
Here are the schematics as published in Linear Audio, courtesy of Jan.
CEN for complementary, SEN for single ended.
Patrick
what is the input impedance as seen by the DAC ??
doesn't it have to be ultra low to be effective as an IV converter ??
I can't see how source impedance of two JFETS could be very low unless they were biased very high.
regards
Trev
Old 30th August 2011, 03:06 PM   #36
15R as per schematics published.
It can be halved by changing the 2SK170BLs to 2SK369BLs in SEN IV, at a slight increase in distortion.
Again, all discussed in detail in the article.
Patrick
Old 30th August 2011, 09:50 PM   #37
rsdio is offline rsdio  United States
The DAC chips that I've worked with want 25 Ω or less.
Old 31st August 2011, 06:03 AM   #38
My experience with the ESS9018 DAC, which has lowest THD with 0R load, is that sonics is not only dependant on the load (no surprise I guess). I have used 10R load with the ESS9018 and it can sound fantastic with that load. I have alsu used transformers with the ESS9018 (and PCM1792) and sonics can be just amazing with loads up to several k ohms.
/IR
Old 31st August 2011, 06:18 AM   #39
With discrete designs you can make such elegant solutions and using chip OPmaps is not much of a challenge/fun.
One can make a discrete OPamp with THD as low as you wish (almost), but they tend to be complex, and using top notch components then make it rather costly. Thus, a simple discrete solution with the best components is a great solution.
EUVL, you have made an outstanding elegant IV converter - hats off for you!
I am not eagerly awaiting my copy of the magazine
/IR
Patrick
Old 31st August 2011, 05:40 PM   #40
A few of you asked about details of the subscription of the evaluation kit.
You guys are really impatient.
Firstly the cost.
4 quad JEFT heatsinks plus 4 dual JFET heatsinks alone cost 30 Euros.
For the small quantities we are making, there are no alternative to wire cut EDM.
Extrusion might have been cheaper, but we need to do 1000kg min !!
Plus 4 PCBs, we shall set the cost at 50 Euros per kit including registered post world wide.
Other courier at extra cost, on request.
Delivery is as usual FOB. We are not responsible for postal losses.
Matched 2SJ74BL's (Idss match only) is limited to 40 pairs on first come first serve basis.
And limited to one pair per person.
See also post #7 for alternative source.
Secondly subscription
I shall open a GB thread around mid September.
By that time you should have had a chance to read the article and decide whether it is worth trying.
As long as we go over 60 kits, I shall start collecting money and then order the PCBs and the heatsinks.
Expect 3-4 weeks for the sinks. The PCBs are usually much quicker.
JFETs are all ready matched.
And we hope you like the results as much as we do.
Patrick
FOR REGA Turntable>>> The heavy weight + Vta adjuster+ceramic ball prooptiki Swap Meet 1 22nd May 2010 05:57 PM
Multi-DAC: Lynx AES16 -> DIR9001/SRC4392 (-> SRC4192) -> PCM1794A novec Digital Line Level 11 11th May 2010 11:57 AM
> Audio <> music <> quick <> synergy <> angst>? rick57 Everything Else 0 4th May 2007 04:03 PM
&gt;&gt;&gt; cheap 50,000uF 60V capacitors here &gt;&gt;&gt; Lubomir Swap Meet 0 1st February 2007 03:36 PM
Copyright 1999-2017 diyAudio
