Zen -> Cen -> Sen, evolution of a minimalistic IV Converter
Old 21st September 2011, 06:23 PM   #271
Joachim Gerhard is online now Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Here is a comparison between Fets and BJTs :
http://www.cco.caltech.edu/~musiclab...er-acrobat.pdf
Old 21st September 2011, 06:33 PM   #272
bcarso is offline bcarso  United States
diyAudio Member RIP
Jawohl! Boyk and Sussman is a great paper, and particularly notable for Boyk allowing that bipolars might not be so bad after all (if you recall, Jim had T shirts made that stated "Digital Finishes What The Transistor Began").
Now to test their simulations with real parts...
Old 21st September 2011, 06:33 PM   #273
IngemarR is offline IngemarR  Germany
Each of the 8 differential DACs has an output impedance of about 800 Ohms, but if you use the ESS9018 in stereo mode, like in the Buffalo2, you have about 195 Ohms, and 16mAp-p signal current max riding on top of 8mADC wehn using 0 Ohm load. In mono mode, the ESS9018 has its DACs in parallel giving twice the stereo mode current.
AFAIK, most people are using the ESS9018 in either mono mode or stereo mode.
Originally Posted by EUVL View Post
Joachim,
The ES9018 has a low output impedance of about 800R.
So let's go as far as we can and aim to do Zin < 1R.
Since it is CEN, the PNP & NPN are in parallel for the signal.
That is why I chose E153 as current source (15mA bias), so that Zin is about 0R8.
This has the same function as your BF245 with trimmer.
E153 are widely used in Japan for powering LEDs.
I am sure Davide would be able to get them if necessary.
I was hoping to get zero DC offset by perfect matching.
Anyhow, the schematics demonstrates how it can fulfill all the functional requirements.
Patrick
Old 21st September 2011, 08:41 PM   #274
bcarso, yes BJTs degenerated to the same Gm as J-Fets have less distortion nominally.
That is mostly because they have much more Gm to burn to begin with. Still some prefer the sound of Fets for other reasons
Old 21st September 2011, 08:44 PM   #275
EUVL is offline EUVL  Europe
Absolutely.
If Gm and / or THD is everything then audio would be simple and DIY would be dead boring.
Patrick
Old 22nd September 2011, 12:19 AM   #276
Itīs not so much the amount of Gm but the shape of it that is important for low distortion plus the correct topology that takes advantage of the Fets gain curve.
See the simulations on a circuit i designed with only one pair of Fets with EUVLs matching trick and my current mirror with cascode. We got -95dB, mostly 2nd harmonic with a gain of 60dB without any loop feedback.
File Type: png Naked_Truth_MC_Mirror_with_Cascode_2.1.TSC_-_thd2.png (143.3 KB, 1046 views)
Old 22nd September 2011, 04:45 AM   #277
What is the (current) signal amplitude ?
Patrick
Old 22nd September 2011, 06:15 AM   #278
staccatiss is offline staccatiss  Germany
Here is the datasheetīs information about the ESS9018 analog outputs.
In Stereo mode, you have 4X the currents, and in mono mode, 8X.
50-100mADC idle would be good to have for stereo mode.
Patrick
Last edited by staccatiss; 22nd September 2011 at 06:19 AM. Reason: Added Note 1 image
Old 22nd September 2011, 07:30 AM   #279
The question was to Joachim for what current signal he used in his simulation. (I read 0.1mA.)
Nothing to do with ES9018, the datasheet of which I have under NDA.
Also I wonder how distortion changes with signal amplitude ?
Thanks,
Patrick
Old 22nd September 2011, 03:17 PM   #280
One of you sent a email and wanted to purchase a apir of my IV's.
Thank you for your interest.
I do not sell them as finished circuits, but you may wish to consider subscribing for an evaluation kit which will make life somewhat easier for you to build them.
See :
http://www.diyaudio.com/forums/group...tion-pack.html
Patrick
Zen -&gt; Cen -&gt; Sen, evolution of a minimalistic IV ConverterHide this!Advertise here!
FOR REGA Turntable>>> The heavy weight + Vta adjuster+ceramic ball prooptiki Swap Meet 1 22nd May 2010 05:57 PM
Multi-DAC: Lynx AES16 -> DIR9001/SRC4392 (-> SRC4192) -> PCM1794A novec Digital Line Level 11 11th May 2010 11:57 AM
> Audio <> music <> quick <> synergy <> angst>? rick57 Everything Else 0 4th May 2007 04:03 PM
&gt;&gt;&gt; cheap 50,000uF 60V capacitors here &gt;&gt;&gt; Lubomir Swap Meet 0 1st February 2007 03:36 PM
