Zen -> Cen -> Sen, evolution of a minimalistic IV Converter - Page 166 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 10th April 2014, 05:56 PM   #1651
EUVL is offline EUVL  Europe
MarkLai will supply you PCBs and heatsinks if you tell him what you want precisely.
ONE SEN IV V2 PCB will serve 2 PCM1704 DAC chips.
Patrick
xen-audio.com
Old 11th April 2014, 02:29 AM   #1652
Patrick
Thanks Patrick! I have contacted him and now waiting with finger crossed!
Old 8th May 2014, 07:25 PM   #1653
RollE2k is offline RollE2k  Sweden
Patrick:
If using around 300-330R i/v resistors would 330uF bipolar electrolytics be enough? And how do i calculate what size i need there? it really becomes a "RC (CR) high pass filter" i take it, but what cutting frequency should i aim for?
Old 8th May 2014, 09:16 PM   #1654
> but what cutting frequency should i aim for ?
As low as possible. At most 15Hz.
So 330 300R is fine.
Patrick
xen-audio.com
Old 8th May 2014, 09:21 PM   #1655
Would you recommend bipolar like Muse ES over known good polarised ones like Silmic II?
Because i can fit either ES 330uF (real 165uF) or silmic ii 220uF on my boards...
Old 8th May 2014, 09:48 PM   #1656
It costs you nothing to try both out, right ?
Solder a socket on your PCB and do A-B test, and tell us your findings.
I am using bipolar, and Elna has a bipolar for audio :
http://www.elna.co.jp/en/capacitor/a.../pdf/rbd_e.pdf
ELNA RBD (Bi-polarized) : headfishop.com
The film cap in parallel takes over from ~1kHz onwards.
And remember what I said about Kirchoff's Law in the article.
Patrick
xen-audio.com
Old 12th May 2014, 05:57 AM   #1657
I already have 4x Silmic II's so i'll order another 4pcs, and also the 330uF muse es.
I'll parallell them with 2.2uF - so they will actually take in as low as around 250Hz. Don't know yet if the 12.5mm caps will fit my boards. :-)
Old 12th May 2014, 08:39 AM   #1658
I hope you are using MKP or FKP and not MKS for your 2.2F.
Patrick
xen-audio.com
Old 12th May 2014, 11:20 AM   #1659
I was thinking about the MKS - are the MKP or FKP better?
Old 12th May 2014, 02:09 PM   #1660
Many many articles by e.g. John Curl or Walt Jung on choice of capacitors.
Just search.
Patrick
xen-audio.com
FOR REGA Turntable>>> The heavy weight + Vta adjuster+ceramic ball prooptiki Swap Meet 1 22nd May 2010 05:57 PM
Multi-DAC: Lynx AES16 -> DIR9001/SRC4392 (-> SRC4192) -> PCM1794A novec Digital Line Level 11 11th May 2010 11:57 AM
> Audio <> music <> quick <> synergy <> angst>? rick57 Everything Else 0 4th May 2007 04:03 PM
&gt;&gt;&gt; cheap 50,000uF 60V capacitors here &gt;&gt;&gt; Lubomir Swap Meet 0 1st February 2007 03:36 PM
Copyright 1999-2017 diyAudio
