Zen -> Cen -> Sen, evolution of a minimalistic IV Converter
Old 13th September 2011, 05:59 PM   #151
EUVL is offline EUVL  Europe
The floating supply does not float more than the output across R_iv.
So if you are not afraid of twisted wires at the output, you should not be afraid of any capacitance of the supply lines to Gnd.
In the test PCB we measured at Jan Didden's, we did not paid any attention to wiring and have them all over the place.
Yet the performance is there for all to see.
Patrick
Old 13th September 2011, 06:02 PM   #152
If you don't like using floating supplies (I use them for circlotrons all the time) and insists on using fixed rails,
you can build the CEN Current Mirror circuit, with 10 transistors in total, higher noise and distortions.
Easy enough to modify my published PCB layout and make one yourself.
As said, Joachim's idea. So no PCBs from us for the CEN CM.
Patrick
Old 13th September 2011, 06:48 PM   #153
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
I showed a mirror with approximately the same amount of distortion as your circuits. The noise issue can be solved too with cascoding but then it is not simple any more.
I agree that a floating supply is not a problem to make. The easiest are buffered batteries or accumulators.
Somewhere in my files i have a design for a floating low noise supply that can be fed by a conventional mains transformer. When i can dig it up i will publish it if you like.
Old 13th September 2011, 06:51 PM   #154
That was what I used at Jan's place.
Please. 100%.
I think many others would be interested also.
Patrick
Old 13th September 2011, 07:37 PM   #155
guglielmope is offline guglielmope  Italy
Hello Patrick,
I red your posts about high current Dacs like ES9018, and I'd like to know if you can sell also Sen or CEn with more pairs of Jfets?
Guglielmo
Old 13th September 2011, 07:56 PM   #156
silbermann is offline silbermann  Germany
... very interested, indeed!
Old 13th September 2011, 08:02 PM   #157
2 Pairs of 2SK170/2SJ74 or 2 pairs of 2SK369V is AFAIK sufficient for ES9018.
This is already supported by the current PCBs.
Patrick
Old 13th September 2011, 08:05 PM   #158
For the basic principle something as old as me.
Old 13th September 2011, 10:17 PM   #159
stinius is offline stinius
Or using a few more parts.
Old 13th September 2011, 11:01 PM   #160
rsdio is offline rsdio  United States
Interesting.
The circuit on the left would not be covered by U.S. Patent 2,895,059 because it doesn't have the dummy load and does not use the center tap as ground. However, the circuit on the left is the one that I would intuitively build.
The circuit on the right does indeed look like an actively regulated version of 2,895,059 because there appears to be a dummy load (active, at that) and ground is taken from the center tap like in the patent. ... EDIT: Oops, that's not a dummy load. The circuit on the right is also not similar to the patent mentioned above.
Both examples would have leakage current to ground which patent 2,895,059 minimizes with its dummy load.
Zen -> Cen -> Sen, evolution of a minimalistic IV ConverterHide this!Advertise here!
FOR REGA Turntable>>> The heavy weight + Vta adjuster+ceramic ball prooptiki Swap Meet 1 22nd May 2010 05:57 PM
Multi-DAC: Lynx AES16 -> DIR9001/SRC4392 (-> SRC4192) -> PCM1794A novec Digital Line Level 11 11th May 2010 11:57 AM
> Audio <> music <> quick <> synergy <> angst>? rick57 Everything Else 0 4th May 2007 04:03 PM
&gt;&gt;&gt; cheap 50,000uF 60V capacitors here &gt;&gt;&gt; Lubomir Swap Meet 0 1st February 2007 03:36 PM
