Zen -> Cen -> Sen, evolution of a minimalistic IV Converter
Old 21st September 2013, 04:23 PM   #1501
EUVL is offline EUVL  Europe
Please consider to parallel your Wima MKS with Wima MKP2 0.1, and see if you hear any improvements.
Patrick
xen-audio.com
Old 21st September 2013, 07:45 PM   #1502
suburra is offline suburra  Italy
Patrick,
just do it...0,1 uF PPS and you are right!
Medium and High frequency are more armonics
Suond , before, was just a bit clinical...now more musical and more body
Marco
Old 23rd September 2013, 09:33 AM   #1503
samoloko is offline samoloko  Bulgaria
0.1 MKP Is better then PPS
even better Is 0.1 foil film
Old 23rd September 2013, 12:52 PM   #1504
Hi
to my ears, PPS was better then Wima MKP 2 in this place
And yes, Film foil for sure it's the winner, but too big for my PCB
I will try 0,01uF Film/Foil
Marco
Old 23rd September 2013, 01:07 PM   #1505
PPS is fine.
Patrick
xen-audio.com
Old 23rd September 2013, 01:12 PM   #1506
Yes
I ever use PPS instead MKP for this...very neutral Cap, no color add
Old 26th September 2013, 04:43 PM   #1507
you can try WIMA FKP3 0.1
Old 27th September 2013, 06:18 PM   #1508
triode_al is offline triode_al  Netherlands
triode_al's Avatar
Originally Posted by EUVL View Post
Your "drift" is very likely due to leakage in your capacitors.
Patrick
By formatting the caps before use you can reduce this to almost zero: take a Vb of the rating of the cap, connect the cap with a 100k or maybe 10k resistor, you will see the voltage go up very slowly, and at the end, maybe a day later, the voltage remains stable.
Formatting configures the layers in the cap. And ensures a smoothing of the boundary layer (giving less shot-gun noise also aggregately seen as leakage).
SPU --> tube MC/RIAA;
Pass buffer -->300B SE + DN2540 CCS/Buffer; --> 165GMF in TQWT; working on a HYPEXed sub.
Old 3rd October 2013, 12:22 PM   #1509
ENSen is offline ENSen  Sweden
I have been using 500R as R_iv in my SEN for a while without problems but yesterday I changed to 680R as recommended for es9018 and then I get heavy clipping on some tracks. Could it be that 680R is too much or do you think I have some other problem?
Old 3rd October 2013, 12:40 PM   #1510
needsp is offline needsp  United Kingdom
Hi
I think 680R was intended for use with each individual DAC. The ESS9018 contains eight. I use it in stereo mode, four DACs per channel (Twisted Pear Buffalo II), and so, with four times the maximum current, a value of 150R is more appropriate- to prevent possible overload, and set the output to standard level
Paul N
Zen -> Cen -> Sen, evolution of a minimalistic IV ConverterHide this!Advertise here!
FOR REGA Turntable>>> The heavy weight + Vta adjuster+ceramic ball prooptiki Swap Meet 1 22nd May 2010 05:57 PM
Multi-DAC: Lynx AES16 -> DIR9001/SRC4392 (-> SRC4192) -> PCM1794A novec Digital Line Level 11 11th May 2010 11:57 AM
> Audio <> music <> quick <> synergy <> angst>? rick57 Everything Else 0 4th May 2007 04:03 PM
&gt;&gt;&gt; cheap 50,000uF 60V capacitors here &gt;&gt;&gt; Lubomir Swap Meet 0 1st February 2007 03:36 PM
