Zen -> Cen -> Sen, evolution of a minimalistic IV Converter
Old 27th July 2013, 08:54 PM   #1471
suburra is offline suburra  Italy
Thank you very much, Patrick
I tried my DCB1 but it have some problem
It's possible to buy PCB for Gerhard Buffer? Because now in my CDP have a 15V bipolar supply free (supplied previous output stage) so i can utilize it
for battery, may i use 24V? Cause i have 4 lead battery 12 V / 1200 mA and relative charger
Now i have 1nF parallel to resistor I/V, will try 680pF
Marco
Old 28th July 2013, 03:59 AM   #1472
EUVL is offline EUVL  Europe
You can contact Gogowatch. We have spare ones (JG filter).
For the JG Filter, +/-15V is specified. I would not go lower.
But there is no need to go +/-24V. You just burn energy for no performance gain.
For the IV, you may use 18~24V floating.
And 1nF as C_iv is also fine. But try and adjust value according to taste.
Patrick
xen-audio.com
Old 28th July 2013, 07:56 AM   #1473
RollE2k is offline RollE2k  Sweden
Patrick: how Do i calculate right decoupling cap size for the electrolytics? I'm running 240R R-iv and 220uf bipolar electrolytic. 6Hz filter frequency if calculating simple RC high-pass.
Old 28th July 2013, 02:52 PM   #1474
Use a MKP cap that gives you a HP at say 300~500Hz.
Patrick
xen-audio.com
Old 28th July 2013, 05:01 PM   #1475
Now i don't follow...
Are you now talking about what to parallell to the electrolytic-cap, if yes - then i already have 2,2uF MKP there.
Why i ask is because is because i remember you talked earlier about not using to little cap with lower r_iv and higher current. But what is "to little" running ESS9018 = 8mA and 240R R_IV per SEN?
Old 28th July 2013, 07:16 PM   #1476
Patrick
Hi
Today i tried to put my DCB1 (source impedance trimmed to 24Kohm ) between CEN and Pot
So, now the sound was a way better, bass rock solid, mid and high crystal clear, no more grain.
This I/V it's a wonderful piece.
I sended a PM to gogowatch for Gerhard Buffer PCB .
Marco
Inviato dal mio GT-S5300 con Tapatalk 2
Old 28th July 2013, 08:27 PM   #1477
Are you referring to post #1461 ?
If you have 8mA signal current, you should use 470uF or more for the bipolar caps.
Patrick
xen-audio.com
Old 30th July 2013, 05:49 AM   #1478
Yes, that is the one post! - i just thought i read it alot earlier in the thread.
Anyway, of choosing polarized caps (lite Silmic II) then 220uF would be fine, right? I have problem with larger size than that.
Old 30th July 2013, 06:22 AM   #1479
Just try it for yourself.
Patrick
xen-audio.com
Old 30th July 2013, 10:44 AM   #1480
I just have to order some new caps, which is why i ask. So i know what to put in my next Mouser order. The problem is my Sen PCB only takes 10mm caps, so i have to settle with 16v 220uF or 10v 330uF caps. But 10v seems almost a bit to close to the limit (running 17.5v to the circuit).
Zen -> Cen -> Sen, evolution of a minimalistic IV ConverterHide this!Advertise here!
FOR REGA Turntable>>> The heavy weight + Vta adjuster+ceramic ball prooptiki Swap Meet 1 22nd May 2010 05:57 PM
Multi-DAC: Lynx AES16 -> DIR9001/SRC4392 (-> SRC4192) -> PCM1794A novec Digital Line Level 11 11th May 2010 11:57 AM
> Audio <> music <> quick <> synergy <> angst>? rick57 Everything Else 0 4th May 2007 04:03 PM
&gt;&gt;&gt; cheap 50,000uF 60V capacitors here &gt;&gt;&gt; Lubomir Swap Meet 0 1st February 2007 03:36 PM
